1 No current to fuel pump Sun May 19, 2024 10:10 pm
lucki
Hi all
I'm in a bit of a pickle!
My k75, 1987 was running a bit rough at idle especially when cold the fast idle in position one and two when cold it would hunt up and down not an even rpm as in the past. A bit of a miss at lower rpm but ran strong at 90kph and up!
Today would not start. No current to pump, pump bench tested fine.
What colour wires are for the pump on the 4 wire connecter going to the tank.
Do the relays fail?
Cleaned the plug with detox.
Not sure what to do next, help appreciated.
Do the relays fail?
