1Back to top Go down   Loss of speedometer and tachometer. Empty Loss of speedometer and tachometer. Wed Mar 13, 2019 7:47 pm
TheJoker
TheJoker
I've had a recent problem where I've lost the speedometer and tachometer, now I've got several sets of clocks and 2 k100's and a k75 that the clocks have been tested on. The Tachometer works on all and so does the speedometer so I know that's not the problem.
However on my daily k100 1984, I've lost the speedometer and tachometer as in the needles don't move at all. I've tested the power connection to the speedometer pulse wire that connects into the final drive and there doesn't seem to be any power at all. At the moment I'm pretty stumped on what to check next. All earths that I know of (under the tank, back of the fuel rail, to the left of the bike from the battery) are all clean. The pesky starter motor is clean and the bushes were replaced two months ago.
My only idea at the moment is the cable that goes straight into the clocks itself which is part of the main harness. Does anyone happen to know which wire it is for the speedometer and tacho.
Or any other suggestions on where to look next; if it was mechanical it would be easy to sort with it being electric I'm stumped.
EDIT>>>>
I've also lost the right hand indicator front and rear everything else works, locally can't get DEOXIT so I've had to order it online. I've been using normal electrical cleaner for now.
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
When you turn the key without starting, does the charge indicator work?
It's the black wire, coming from the alternator to the dash.
Connected when you turn around the breadbox, it's pin 9, the fourth from left under.
Loss of speedometer and tachometer. 03_TellerSet
(It's Dutch, but in case I can translate...)
Other possibility is, that the brushes of your startermotor are too far gone.
At 6 or 7 mm they go bad, and give these kinds of problems.
Loss of speedometer and tachometer. Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
TheJoker
TheJoker
Well I've found my problem seems to be the plastic connector is brittle and falling apart. With this being a BMW specific connector it looks like I may have to go down the route of a new loom or replacing the connectors with good decent ones.
Loss of speedometer and tachometer. Receiv11
Ow dear, the good old flat pins, haven't seen them since my K100 years ago.
Maybe find replacement in big electronics online, such as Conrad, Reichelt, etc.
Not BMW specific and not that expensive to replace.
https://uk.rs-online.com/web/p/pcb-connector-housings/5091708
https://uk.rs-online.com/web/p/pcb-connector-contacts/5091994
You do have to buy more than you need, but last time I bought some I was able to offset the cost by passing on sets of connectors + pins to other members on the forum.
TheJoker
TheJoker
Thank you Dai, with BMW and the little plugs that are on the end of the ignition for example; mistakingly I assumed they were specific.
I'll order some then help anyone out in the UK if they need to replace there's.
Arlina wrote:When you turn the key without starting, does the charge indicator work?
FYI: The wire from the alternator to  the cluster is blue, not black.
Dai; thanks, didn't know there was a replacement. No need for me, just learning Smile
Duck; got it from the diagram from Bert, that one is black for the K100.
It's blue for all of the classic K bikes:
Loss of speedometer and tachometer. HUCXoak
I'm going to argue with both of you: the two wiring looms I stripped were black/blue to the tachometer. One was an '83 K100 and the other an '86 K100. Haynes shows black/blue too but (and I'll get in first) their reliability is sometimes suspect.
I have some wiring harnasses here, will check tomorrow with daylight.
Very Happy bounce cheers
I remember on my K100RT 1986 it was black.
That diagram indicates Black/Blue. :BW:
Last edited by Laitch on Thu Mar 14, 2019 8:14 pm; edited 1 time in total (Reason for editing : To increase syllable count.)
Black/blue is from the coil to the tacho.
Black is from the alternator to the charge indicator/12V to speedo and tacho.
Arghhhh!!!! I just re-read Duck's answer and wondered where the hell I got sidetracked. Yes, the alternator control wire is blue. Go take a look at the back of the alternator - it's very visible.
Sorry Duck.... Embarassed Embarassed
18Back to top Go down   Loss of speedometer and tachometer. Empty Re: Loss of speedometer and tachometer. Thu Mar 14, 2019 10:55 pm
Twisted Evil Got my eye on it Very Happy
19Back to top Go down   Loss of speedometer and tachometer. Empty Re: Loss of speedometer and tachometer. Thu Mar 14, 2019 11:48 pm
Bert F..cked up!
I can see my mistake: On the original black and white schematic, the color is marked "BL" which is Blue or Blau in German.
I simply mixed my English and German and interpreted BL as Black. Embarassed Sad
Loss of speedometer and tachometer. Frog15Loss of speedometer and tachometer. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
But for sure we use your diagrams Smile
(even though we lost many bikes due to the black or blue wire..... Loss of speedometer and tachometer. 44271 Loss of speedometer and tachometer. 44271 Loss of speedometer and tachometer. 44271 )
21Back to top Go down   Loss of speedometer and tachometer. Empty Re: Loss of speedometer and tachometer. Fri Mar 15, 2019 10:04 am
Dai wrote:I . . . wondered where the hell I got sidetracked. . . .
I don't know about you but I got distracted by the thread's title and and a flare-up of cabin fever. Smile
22Back to top Go down   Loss of speedometer and tachometer. Empty Re: Loss of speedometer and tachometer. Fri Mar 15, 2019 10:48 am
Crazy Frog wrote:Bert F..cked up!
As I'm sure you know, black is schwarz (SW) in Cherman.
Loss of speedometer and tachometer. May-the-schwartz-be-with-you
23Back to top Go down   Loss of speedometer and tachometer. Empty Re: Loss of speedometer and tachometer. Sat May 11, 2019 10:23 am
I finally found my original files and made the correction on the main diagram.
Looking at what I made 10 years ago was a big project! But as people use it, it wasn't wasted time.
Loss of speedometer and tachometer. K100-e10
24Back to top Go down   Loss of speedometer and tachometer. Empty Speedo no go Sat May 11, 2019 9:17 pm
daveyson
daveyson
Hi Bert,
Just want to say a huge thank you for the wiring diagrams. I'm new to bricks and this forum, I thought Gregory's wiring was the easiest, until recently when I found yours. These diagrams are a big time saving tool and a huge asset for understanding.
 ~120,000 km
Thanks daveyson.
I made them when I was trying to understand the K bikes electronic.
Now, I use them all the time.
