Go to page : Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
View previous topic View next topic Go down  Message [Page 7 of 13]
301Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 11, 2019 5:33 am
lol thanks guys
and yes Blakey I have seen those posts about green frames ...in fb ...bevel heaven  and so many pages
the soda blasting has created a whole new challenge to get it back to shiney stuff ….giggles
302Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 11, 2019 7:49 am
Charlie - if you can find someone who does vapour-blasting, that would solve the problem. I've had three engines vapour-blasted from scratch i.e. just the grease and shite removed from bare alloy (no good if they're painted).
83-84 engine cleanup  - Page 7 Pt28_1
The good thing about the finish, particularly on a sump, is that vapour-blasting actually closes up the pits and pores preventing corrosion from getting easily restarted and stopping crap from sticking so easily.
303Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 11, 2019 8:14 am
83-84 engine cleanup  - Page 7 112350
great result Dai
don't know the resources in this country town yet , but will keep looking
304Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 11, 2019 8:32 am
One you get it all perfectly cleaned and assembled you should entomb it in a large clear acrylic block so that it can't even get dusty. Very Happy
305Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sat Jan 12, 2019 12:57 am
spent a good few hours on those parts today
what do you think ?
83-84 engine cleanup  - Page 7 20190117
83-84 engine cleanup  - Page 7 20190118
83-84 engine cleanup  - Page 7 20190119
83-84 engine cleanup  - Page 7 20190120
given the option for soda blasting , and finned bits , I would have to say ,  maybe not again ???
306Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sat Jan 12, 2019 3:01 pm
Looks pretty good Charlie!
307Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sat Jan 12, 2019 3:44 pm
You're going to have to start wearing sunglasses when working on that motor.
308Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sat Jan 12, 2019 4:54 pm
just on the off chance
I have to change the serial number on the sump , so that my serial number here in aussie is registered
does any one have the right stamps for this , loan or buy …..  just need  the number "7" and the number "0"
309Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sat Jan 12, 2019 7:26 pm
Some good advice Charlie, don't change the serial number it can lead to disastrous consequences if it is picked up.
310Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sun Jan 13, 2019 4:59 am
engine covers update , made satin some 2 years  ago , took out some sandcast marks and a bit brighter now , there are still some legacy deep marks in the crank cover (typical stuff with fairings and rubber mating against the aluminium , drop events etc )
still some polishing to do , ...after its assembled , will do
should fit in well with the updated sump eh ?
83-84 engine cleanup  - Page 7 20190121
311Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Mon Jan 14, 2019 1:49 am
shims for valves arrived today ..woohoo ...so decided to do a bit more work
83-84 engine cleanup  - Page 7 20190122
cut off old and hardened rubber from the cover bolts and installed new
83-84 engine cleanup  - Page 7 20190125
reassembled the timing gear and rolled it over a couple of times ...all ok and valve clearances are good to go
83-84 engine cleanup  - Page 7 20190123
83-84 engine cleanup  - Page 7 20190124
so then replaced the timing cover and cam cover ….with a sneak peak at the theme i'm hoping to achieve
83-84 engine cleanup  - Page 7 20190126
83-84 engine cleanup  - Page 7 20190127
yeah ok …..for all you northern hemisphere types (who cant read upside down )   right side up, by photo manipulation
83-84 engine cleanup  - Page 7 20190128
what do you think ...looking the goods ….yes ?
next the output shaft sump etc
312Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Mon Jan 14, 2019 11:22 pm
sump and output shaft back together
83-84 engine cleanup  - Page 7 20190129
83-84 engine cleanup  - Page 7 20190130
couple of screws to do up on the water pump , but heres the idea any how
313Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Mon Jan 14, 2019 11:35 pm
I truly appreciate your efforts towards cleanliness being next to godliness, Chaz. I, on the other hand, leave perhaps too much of yesterday's devilish grease and oil while I impatiently see how it all fits together.
314Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 18, 2019 8:54 am
brought old Gerty to her new home today  by visiting brisvegas again
thanks to Matt , the old girl started straight up , after removing a battery tender attached by Matt
thanks heaps Mate !!!
Gertys new home ...plush to say the least …"oh the serenity "
83-84 engine cleanup  - Page 7 20190132
also acquired some bolts for gearbox to bell housing (enough for 2x applications ) from my favorite bolt shop
I showed the attendant pics of their stock supplied by them and installed to the motor that I have been working on ,  and she instantly recognised the  k100 head , which she also has , installed to a mini project she is working on ...great affinity indeed .. she was impressed  to say the least .
also some new head - steering bearings arrived , ( jap brand at least ) so the project moves along
83-84 engine cleanup  - Page 7 20190131
315Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 18, 2019 10:05 am
Charlie, out of curiosity, did you replace those awful Torx bolts with capheads when you bolted the bellhousing back on? What the hell were BMW thinking of when they did that?
316Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sun Jan 20, 2019 6:37 am
hiya Dai .. yes cap head bolts into the bell housing will be allen heads
83-84 engine cleanup  - Page 7 20190133
today spent a few hours  with smithy , repairing a frame bridge crack , now rewelded with some steel support
83-84 engine cleanup  - Page 7 20190134
and replaced the steering head bearings , the lower yolk bearing being particularly hard to remove .
now with new jap bearings fitted , this bit ready to go
83-84 engine cleanup  - Page 7 20190135
a bit of fiddling about repairing paint defects and injuries (from rough handling , bumps etc )  will happen this week , followed by a good layer or two clear coat , should have the frame ready for taking parts next week
will give me time to refinish the bell housing and fit it back up with a later version of the sprage clutch
83-84 engine cleanup  - Page 7 20190136
317Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sun Jan 20, 2019 1:07 pm
Reckon that silver against red is gunna have a classical look to it, Chazza. I don't know your ultimate direction, but if using an RS fairing, what colour have you chosen for the panels?
318Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sun Jan 20, 2019 1:39 pm
just a reminder , something like this mate
83-84 engine cleanup  - Page 7 20170510
319Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 2:43 am
bit of bump and tickle to the bell housing late this afternoon
83-84 engine cleanup  - Page 7 20190137
83-84 engine cleanup  - Page 7 20190138
still upside down ...alas …  brush finish only ...so far
too much ? or should I polish it also ????
thoughts please ?
320Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 6:13 pm
Polishing eh?
I had a fat-tank 860 Ducati and made the fatal mistake (young and stupid) of poishing the cases so they just about glowed in the dark.
Boy, did I make a rod for my back!
I had to keep them polished as they just looked crappy otherwise!
Good luck with whatever you decide.
321Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 6:22 pm
I dunno much about finishes, never been my forte, but after all this elbowing, would a shot of clear keep it lookin like lickin?
Last edited by Two Wheels Better on Tue Jan 22, 2019 6:34 pm; edited 1 time in total
322Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 6:32 pm
yeah your right guys
the sump oil pump etc is clear coated . likely the top of the motor also
side panels , cam cover, timing cover and crank cover will be Cornubia waxed as they are easy to get to  and suffer from exposure issues ,so easy to keep  wiping it over
effort this morning has the bell housing  taken from brush - scotch bright finish ,  to polished , not a great deal of appearance difference to the camera , but smooth as a babys bum
clear coat to go on later
thanks for the replys ….appreciate the opinion
83-84 engine cleanup  - Page 7 20190141
83-84 engine cleanup  - Page 7 20190139
323Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 6:42 pm
It's amazing the different paths people take. I applaud your genuine effort as the real deal. This K11 I bought a coupla years, the basket case, well the bloke spray painted everything black. He musta used a spray gun coz it's a thick, durable layer. Trub is the wanker sprayed over the rubber boot on the Paralever, hose clamps, even wheel weights.
Spray Job Special.
324Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 6:50 pm
Only trouble Charlie is once it's finished you wont want to ride it, because it's soooo pretty.
325Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 6:52 pm
83-84 engine cleanup  - Page 7 44271
dang , I feel your pain
we do have a pretty good paint stripper out here , poly stripper , which is miles better than many other brands at removing tough paint
if using some other product be aware that if unsuccessful first application  there is no way back , it hardens the paint a great deal and nothing less than sanding etc will remove it , just a heads up
eager to see what becomes of the old basket case …  a great deal younger than my attempt
326Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 8:19 pm
MartinW wrote:Only trouble Charlie is once it's finished you wont want to ride it, because it's soooo pretty.
I don't think ill have any trouble with that martin ...giggles , after all it could turn into a very shiney "Rat Bike " 83-84 engine cleanup  - Page 7 44271
327Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 22, 2019 9:28 pm
Charlie NOOOOOOOOOOO ARHHHHHH. 83-84 engine cleanup  - Page 7 167893
328Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Thu Jan 24, 2019 3:04 am
bell housing fitted up , and clutch basket inserted to check if the newer type seal is making the right contact
ill tighten this baby up tomorrow and move onto refurbishing a gearbox bearings and seals (and other stuff)
got to make a stand for the engine , and transmission line in the coming days also
83-84 engine cleanup  - Page 7 20190142
83-84 engine cleanup  - Page 7 20190143
329Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Thu Jan 24, 2019 12:48 pm
Chocolate
Chocolate
Hallo Mcharlie99 wrote: … boxing day cleanup of gasket area and pistons ,diready for the head I cleaned up back in july , 86 model with the different seats below
83-84 engine cleanup  - Page 7 20180752
should be all buttoned up a little later today sometime
Hello #charlie99 !
Well done and nice, is your kitchen as clean , haha.
A German fried would very much like to know how you have cleaned this part.
He rebuilds a lot K bike but doesn’t get it as clean.
Would be great if you could explain !!!
Cheers :-)
330Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 25, 2019 3:52 pm
hmm , not hard to do chocolate
first off valves were removed to start with
ports were cleaned up with a Dremel tool  reshaping the short curve radius as to reduce any sharp corners with a sanding barrel type thing
valves were cleaned up on the face and rear using a wire brush on a drill
hemispheres of the combustion chamber were cleaned up with wet and dry paper , finished with the Dremel type tool and wire brush
head surface was refinished with a standard stone used for sharpening knives etc ….when brand new they are particularly flat and make for a good grinding stone , all by hand
careful not to make any big differences in the surface , uniformity is paramount
valves were them lapped to the seats with grinding paste ,
it took quite a while to get it to look like that
hope that helps
331Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Fri Jan 25, 2019 3:56 pm
Your description of the process gives the impression it's all in a relaxed Sunday arvo, when in fact it's a heap of time - and patience - required to achieve those results. Well done, Mr Semi-Retired. I'll wager the stack of tinnies in the corner can tell the tale.
332Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Sat Jan 26, 2019 8:03 am
Chocolate
Chocolate
charlie99 wrote:hmm , not hard to do chocolate …
Thanks Charlie, that helps.
333Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Mon Jan 28, 2019 5:22 am
first coat of clear coat on the frame , late in the afternoon , nearly night time
and some other bits getting the Charlie treatment
thanks to smithy for the extra parts  (oops overlooked a couple of bits needed )
83-84 engine cleanup  - Page 7 20190145
83-84 engine cleanup  - Page 7 20190144
334Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 12:58 am
flipped the motor right way up and started on induction system
83-84 engine cleanup  - Page 7 20190147
rubbers matched to the ports
83-84 engine cleanup  - Page 7 20190146
some grubby - modified tbs
83-84 engine cleanup  - Page 7 20190148
and thinking about the top rubbers clamps ….hmm .. the Suzuki thin types with screws perhaps ???
335Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 2:59 am
threw some bits on the frame , just to see what it looks like , and really to start assembling the wiring loom , with the mods that I will be using
83-84 engine cleanup  - Page 7 20190149
83-84 engine cleanup  - Page 7 20190150
83-84 engine cleanup  - Page 7 20190151
mostly will be unseen  once fairings , panels , tank etc are installed
336Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 3:13 am
It's bringing back memories of my first new bike a Ducati. Bought from Pratts in Melbourne delivered by a BMW with a flat cargo chair. Could of been an omen of my future.
83-84 engine cleanup  - Page 7 Ducati10
337Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 8:55 am
Gauntlett
Gauntlett
Hi Charlie, if your rubbers are in good condition and supple. I have found that tie wraps will do the job, of course on a faired bike you will want to be extra careful checking for leaks before covering them up
338Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 9:33 am
339Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 12:06 pm
5mm tiewraps... now that is a good idea if the rubber hasn't gone hard. If you can get them on from the inside that will definately improve the look of the bike in that area.
- just as long as they're not white ones. Twisted Evil
340Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 11:13 pm
um translation please
tie wraps ?  would we know them as zip ties
or a pic would be good
341Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Tue Jan 29, 2019 11:17 pm
Yes Charlie. Correctly translated.
342Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 5:43 am
robmack wrote:Yes Charlie.  Correctly translated.
thanks mate
interesting how we have different terminology at times …..  but just by asking ….resolved !!
given the heat and uv and obvious unknown age of cable ties - zip ties before installation ...ill be looking for something of a longer lasting solution , but a good thought at least ,,,thanks for the suggestions
343Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 6:36 am
Charlie Bunnings have packets of stainless cables ties.
344Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 7:33 am
hmm nice option martin
ill think on that one for sure
345Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 8:49 am
MartinW wrote:Charlie Bunnings have packets of stainless cables ties.
But are they white or black? 😉
346Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 9:08 am
Colour can be changed with the aid of marker or paint pens. So pink is a distinct possibility if you want. 83-84 engine cleanup  - Page 7 652573
347Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 9:09 am
One of the problems with zip ties in stainless is the width of the tie. It's generally too wide for the ridge provided on the bushing and won't sit quite properly. The Suzuki band clamps are the correct diameter and width and fit much better. You'd have to check the ties you have available to you to see whether they fit.
348Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 9:15 am
MartinW wrote:Colour can be changed with the aid of marker or paint pens. So pink is a distinct possibility if you want. 83-84 engine cleanup  - Page 7 652573
Pink it is. Looking forward to seeing that, Charlie.  Embarassed
349Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 4:08 pm
Rob I haven't checked them out lately but I believe they can be had in a couple of widths. I was going to substitute the OEM ties for stainless. After a bit of cogitation I concluded that they would be a pain to remove on the side of the road if needed.
350Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Wed Jan 30, 2019 6:14 pm
more top end works
oops … bloomin old and hardened rubber , too easy to do
 but found another
83-84 engine cleanup  - Page 7 20190152
getting there
83-84 engine cleanup  - Page 7 20190153
83-84 engine cleanup  - Page 7 20190154
351Back to top Go down   83-84 engine cleanup  - Page 7 Empty Re: 83-84 engine cleanup Thu Jan 31, 2019 1:57 am
panel damage ...such a pain !!! ...happened whilst moving in plastic storage containers …. not enough packing and too many things in the same box  … the lower panels came off worse ...but blemishes and scratches abound .
oh well... time for a fresh coat of paint and finally  clear coat in a few days
83-84 engine cleanup  - Page 7 20190155
83-84 engine cleanup  - Page 7 20190156
View previous topic View next topic Back to top  Message [Page 7 of 13]
