602 Re: 83-84 engine cleanup Thu Jan 09, 2020 2:05 pm
I've successfully used thin plastic (food containers/ ice cream) or cut down food /drink cans in conjunction large worm drive hose clips with plenty of lubrication.
603 Re: 83-84 engine cleanup Thu Jan 09, 2020 2:28 pm
Too complicated for me. I'll stick with two screwdrivers and a pair of thumbnails.
604 Re: 83-84 engine cleanup Thu Jan 09, 2020 4:58 pm
Rockman
I've used a hose clamp with success on several R series motors. The wide ones just cover all 3 rings.
605 Re: 83-84 engine cleanup Fri Jan 10, 2020 3:02 am
cheers guys , all good suggestions
the problem im having is locating the pinned rings whilst clamping up the device .a progressive clamp process will let me do that , instead of a clamp designed for minimum of 75mm (the pistons are about 66mm )
ill get the right thing ,in time
meanwhile, all silicon coated surfaces have been cleaned up and ready for a new reassembly .
one lives in hope ....
606 Re: 83-84 engine cleanup Fri Jan 10, 2020 3:51 am
Try clear plastic with hose clips.
607 Re: 83-84 engine cleanup Sat Jan 11, 2020 12:17 am
608 Re: 83-84 engine cleanup Fri Jan 17, 2020 5:26 am
609 Re: 83-84 engine cleanup Sat Jan 18, 2020 4:21 am
610 engine clean, actually born again bike Sat Jan 18, 2020 5:13 am
daveyson
11/1985 BMW K100RT (late model) Vin. 0090567
~120,000 km
611 hopeful wishes Sat Jan 18, 2020 5:34 am
caveman
I tip my cap to you sir! You patience, attention to detail, and persistence is unbelievable.
I have never bin deep inside a brick engine. Are the piston rings pinned or have any crazy orientation being a horizontal stroke?
612 Re: 83-84 engine cleanup Sun Jan 19, 2020 3:29 pm
Good going, Chazza! I look forward to hearing it purr to life and catching up with you down the road in a coupla months' time.
1977 R75/7-100, '93 K11/K12 Big Block, '93 K1100RS, '95 R100 Mystic, '96 K1100RS, 2 x '98 K1200RS, '06 K1200R & '09 K1300GT
613 Re: 83-84 engine cleanup Tue Jan 21, 2020 6:37 am
caveman wrote:I have never bin deep inside a brick engine. Are the piston rings pinned or have any crazy orientation being a horizontal stroke?
it seems there were some changes ..likely after 1988 ...I have an 88 motor here ,likely from an LT , with the same pistons etc as the 86 variants (first real change to a few things internal and external like foot plates , drive shaft etc )
the motor I used from Rickg has different piston design , including a thinner first compression ring , and pinned second compression ring , approximately the same size in thickness , some folklore also indicates that the pistons in the redesign were a little lighter as well . cant be sure on that one at this point , as I didn't do a weight comparison ....bugga .... but ii did notice that the balance holes (taken out of the crank ) seemed to be less in number and depth ...this could just be a particular crank balance thing , but surmising that there may be some compensation for the engineered expected weights of the piston gear as well ?
you have to remember that after 88 the k100 rs also sported 16 valves ...but in a parallel production path lt versions - 8 valve rather than 16 valve .. were still being made
in any case assembly of motor to frame went well , and quickly
with cables, fluid pipes final drive etc all done by days end , ready for a start , which I postponed until the next day ,with just battery and efi computer to connect up
I chose to not use the starter motor relay for the initial start as I thought the stalled (and relatively tight big end bearings ) torque of the motor to turn it over would be significant and could possibly weld the starter relay .
a very thick cable was attached to the starter motor with direct battery connection (by hand ) attempted . this way I could run the fuel pump continual till I was assured fuel pressure was sufficient ..
amazingly after just 3 attempts he fired up ....note a dry sprag clutch was causing concern with it not engaging at all for several attempts ...but on rotation of the motor ..at last on the third attempt he fired right up ....lots of smoke from build lubrication eventually cleared
an engineering ride around the area on some of the back roads today had me cruising at a little under 3,000 revs for a few hours , just to make sure that the engine crank and conrod parts bedded in somewhat
final panel parts to attach , fairing lowers and radiator cover , knee pads etc to go on tomorrow after todays success
keep in mind there are three items that haven't run together in the same engine before , output shaft , sprag clutch mechanism , and the crank output gear , so hoping that they will wear to each other over coming days and miles travelled for a quieter sounding motor
first impressions .....sweet !
thank Darren ...looking forward catching up ...be safe till then ol mate
614 Re: 83-84 engine cleanup Tue Jan 21, 2020 10:59 am
O-o-o-o-o-h Nice!
615 Re: 83-84 engine cleanup Tue Jan 21, 2020 3:55 pm
:1B:Looking goooood.
616 Re: 83-84 engine cleanup Tue Jan 21, 2020 4:19 pm
A great result Charlie. Amazing how the insides of the engine vary, depending on when it was manufactured. Having had a 83 and a 87 K, sitting them next to one another, the number of changes were incredible. Now we know a bit more about the insides.
1983 K100 basic vin 0003960 colour red GONE
617 83-84 engine cleanup Tue Jan 21, 2020 9:02 pm
G'day All, Charlie, keep up the amazing work.. The bitsa looks fantastic.
Tom
Tom
618 Re: 83-84 engine cleanup Wed Jan 22, 2020 3:55 am
cheers guys ...thanks for commenting
its a bit hard to even wash FRED with current water restrictions ..(level 5 here - emergency)
meanwhile the engineering ride took me east yesterday , and in amazement the dried up creek beds that I have been seeing for the last 12 months , actually have some water in them ...at last ...yippee ...lets hope there is some follow up in the coming weeks
619 Re: 83-84 engine cleanup Wed Jan 22, 2020 5:14 am
caveman
Good to hear! FRED lives!
620 Re: 83-84 engine cleanup Wed Jan 22, 2020 6:10 pm
621 Re: 83-84 engine cleanup Wed Jan 22, 2020 8:23 pm
no , this was at a small lookout above Emmaville north of Glen Innes , the background was particularly pleasing with some greenery in the scene
we were through there a few weeks ago travelling towards Torrington , and the land was mostly dust , still haven't washed Gerty since , other than parking her out in the rain this week ...yeah a sorry state of affairs but once fred is proved reliable , Gerty is in for some tlc to the output shaft and gearbox
622 Re: 83-84 engine cleanup Thu Jan 23, 2020 5:44 am
Woodie
Great to see Fred back in the game Charlie!
1985 K100RT 52667
1990 K75RT 6018570 (project)
"Keep your stick on the ice. We're all in this together." Red Green
623 Re: 83-84 engine cleanup Thu Feb 20, 2020 11:24 pm
just an update
leg is healing from the Gerty drop event on the way to Karuah river rally
still 5 weeks to go in the moon boot
input to gearbox bearings were too tight and made some noises , so stripped it out and replaced , with hopefully good preload this time
Fred back together and ready to rumble over to the Delungra bike show this weekend
yes walking stick is attached ,, well I cant walk without assistance eh ?!!!
624 Re: 83-84 engine cleanup Fri Feb 21, 2020 1:18 am
You don't need the rear brake anyway Charlie. Good luck with the ride.
625 Re: 83-84 engine cleanup Fri May 15, 2020 9:01 pm
seeing that everything is in lockdown
decided to chase vibration whilst at cold idle on Fred ,
I don't remember having the stop disc installed to the output shaft - clutch basket during the last engine rebuild ,,,and the one I found on an old clutch basket assembly is cracked ...blast !
oh well , brass came to mind for fabrication ....so several weeks later a piece of brass turned up (100 x 100 x 1 mm)
over to a mates workshop and onto his new to him lathe
producing this , one for Gerty and one for Fred alongside the original article (cracked )
wont be long and ill have it installed , but pity the mail was so slow getting here , oh well
being experimental id expect that some fretting could happen over time with the movement of the two assemblies
but definitely worth a try .
626 Re: 83-84 engine cleanup Fri May 15, 2020 10:27 pm
Jeez that view of the engine rear looks familiar
Hope that works well for you it'll be a great fix if it does
88....May contain nuts!
K75RTP - 1994
627 Re: 83-84 engine cleanup Fri May 29, 2020 5:45 am
been a while with Fred off the road , but today reassembled the rear end , and now looking far more like a bike again .
startup noise was greatly reduced with little or no noise evident from flogging of the output shaft mechanisms
a quick ride around the block a few times shows promising results as well
ill have to put some miles on the beast locally before attempting a good long distance venture , but sounds and looking good so far
628 Re: 83-84 engine cleanup Fri May 29, 2020 7:33 am
Nice job again Charlie
Still gonna put some BMW badges on Fred?
K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
629 Re: 83-84 engine cleanup Sun May 31, 2020 7:21 am
i have a mind for some personalized - designed badges for the tank Arlina , more details on that as i get some good software for the design ...had a friend who has laser etch and cutting ability , locally , but has moved on a bit .... so will plan for something in the future out of 3 or 4 mm aluminum (to keep the theme ) and find another engineer - fabricator to cut the design
took a ride on the improved cold start knocking sound ...(or lack of ) beast, south today to discuss some issues around with our mate smithy and just a good catch-up indeed ... he (Fred) ran sweet as could be .....for me still disturbing ...the lack of engine noise emanating from the exhaust ...but i guess il get used to it , but do have a couple of other substitute mufflers for a good grunty "zorst " in the future
some pics along the way
and winter is just about upon us , with decidedly cool temperatures along the way ....brrrrr
630 Re: 83-84 engine cleanup Sun May 31, 2020 9:34 pm
Looks great Charlie. Love those flashes on the exhaust sheild.
K75RTP - 1994
631 Re: 83-84 engine cleanup Mon Jun 01, 2020 12:22 am
I recognise the first two locations, so where is the third photo taken Charlie?
Assuming that Fred is a boy and Gerty is a girl, do you expect there to be a dominant one in the relationship? As Fred has been getting all the TLC recently, is not Gerty going to be a little jealous? Senior partner and all that......
Good to see it all coming together.
632 Re: 83-84 engine cleanup Mon Jun 01, 2020 3:26 am
633 Re: 83-84 engine cleanup Mon Jun 01, 2020 3:57 am
Fred is actually a tranny.
Freds frame was originally one of my sidecars named the black girl.
Charlie has transformed a black girl into a white boy named Fred.
'93 K1100LT
634 Re: 83-84 engine cleanup Mon Jun 01, 2020 4:14 am
Oh, Geesus. I don't see this relationship ending well.AL-58 wrote:Fred is actually a tranny.
635 Re: 83-84 engine cleanup Mon Jun 01, 2020 8:23 am
hi dave ...the last pic was at the Ben Lomond turnoff on the new england highway (about 4000 and a bit feet elevation )..looking east .. about 1 k south of the speed camera location ... was getting a little cool about then (for this old fella used to coastal temperatures .....but acclimatizing ...erm somewhat slowly )TacKler wrote:I recognise the first two locations, so where is the third photo taken Charlie?
im reminded that will crean sent me a comment and reminder in another place about layers of clothing ...mind you, i only had the summer jacket on at that time , such a good day as i set off . but a trap for later afternoon riders who didnt plan ahead ...lol .. i beter put that top box on him so i can carry a bit more than minor items in the pockets i created ...(such a god send that idea with mobile devices used often ..actually )
poor old gerty has been in repair after the Karuah trip ....so not ignored at all ..with further plans for output shaft fix and a frame work to reduce evident corrosion on all the exposed areas and likely a colour change , likely later this year , as soon as i can prove reliability on fred as a daily ride ...
Gerty is also currently going though a seat cover change after a few years of service and before renewal of rego this month (seat cover is cracked but not all the way through . more uv damage hardening than anything else as you know she was exposed to radical sun exposure for al the time i had her in q/land outside the awning )
lol martin ....far too much Black .....giggles
lol Al ..i can say without doubt that Fred is defiantly a boy now .... he's been ground ,stripped , recovered . set-upon by disgusting hands and thoroughly converted to a totally different feel in both ride and stance on the bike ....i just hope he now accepts this ...and wont try to buck me off in retaliation any time soon ...
636 Re: 83-84 engine cleanup Tue Dec 08, 2020 3:20 am
just an update ...Fred made it into the Motorworks 2021 Calendar , just a couple of 100x 60 mm snippets of the engine , (right way up this time ) and a late afternoon shot the day club rego was gained , back in the bowels of the calendar (may and december )...many thanks to motor works for the calendar pack received just today .
637 Re: 83-84 engine cleanup Tue Dec 08, 2020 3:28 am
Suzi Q
Congrats re. the calendar!
Hang on to it - they may become collectable.
638 Re: 83-84 engine cleanup Tue Dec 08, 2020 5:53 am
was hoping to see your contributions of excellence chris in there as well ...or did i miss something ? perhaps i need to re read all those amazing pics ?
639 Re: 83-84 engine cleanup Tue Dec 08, 2020 3:42 pm
International recognition for all your hard work, congratulations.
Similar topics
