202 Re: 83-84 engine cleanup Sat Jul 07, 2018 2:33 pm
203 Re: 83-84 engine cleanup Sat Jul 07, 2018 5:29 pm
Charlie I have a valve spring compressor that goes on over the spring and them you screw it down. It is meant to be used with an air fitting that screws into the spark plug hole. Air is supposed to hold the valve up while you screw the compressor down. I also have and older one if I can find it similar to the one in the picture. I am in the process of sorting and rearranging my garage so I do know where it isn't. Let me know and I can bring them to the Lowood swap meet.
204 Re: 83-84 engine cleanup Sat Jul 07, 2018 5:46 pm
thanks martin
its here , just in a box to drag out later ...
205 Re: 83-84 engine cleanup Sat Jul 07, 2018 7:16 pm
Charlie I misread your post I thought you needed one.
206 Re: 83-84 engine cleanup Sun Jul 08, 2018 3:51 am
207 Re: 83-84 engine cleanup Tue Jul 17, 2018 5:23 am
208 Re: 83-84 engine cleanup Tue Jul 17, 2018 8:28 am
MarcS
A man of your tallents will have that behaving its self in no time
K100rt ex plod bike 5/1990.
I have no problem with authority. Just some of the morons that are paid to enforce it.
209 Re: 83-84 engine cleanup Tue Jul 17, 2018 8:47 am
ill give the deoxit a day or so to work
then cleaners and deoxit again
210 Re: 83-84 engine cleanup Thu Jul 19, 2018 8:25 pm
With so many little dremel knockoffs on the market. A trip to Bunnings or a reject shop can yield plenty of little match stick sizes grinders. I know they are meant for the replica dremels but a lot of the little carbide impregnated bits would be just useful between thumb and forefinger to clean up some of those little sockets joints.
211 Re: 83-84 engine cleanup Fri Jul 20, 2018 4:14 am
good idea keith
I have a few various pc board drills here also which will help with the small internal type fitting sockets
after a couple of days ..the deoxit has worked quite well so far
a clean up with flux remover and electronic cleaning solvent and toothbrush or similar may restore - clean the surface without using some abrasive materials
followed by the deoxit when mating up , later on in the build
212 Re: 83-84 engine cleanup Fri Jul 20, 2018 6:41 pm
Charlie - you're gunna hate me for this - junk it and build a new one. The PVC sheathing in that loom is, by now, looking for somewhere really inconvenient to split on you.
213 Re: 83-84 engine cleanup Fri Jul 20, 2018 7:12 pm
214 Re: 83-84 engine cleanup Mon Jul 23, 2018 2:32 pm
bit of a clean up on a modified exhaust , care of Al Pennykid
its been a bit bumped about this one , with years of crud bonded to the underside and hard to get at exposed areas
before
during
and near the end
still some deep scars of corroded stainless exist ...but cutting them back is hard work indeed … may get inspired to dig deeper yet … but don't want to go any thinner on the metal just in this spot , just under and behind the foot peg plate , fortunately the 84 footpeg plate doesn't have the additional guard section just there
may even cut the last two silencer cover plate nut retainers off as well before a bit more polishing
before
during
and near the end
215 Re: 83-84 engine cleanup Mon Jul 23, 2018 8:15 pm
Markosaurus
Love your work Charlie👍🏻
216 Re: 83-84 engine cleanup Mon Jul 23, 2018 9:12 pm
I'm seriously impressed by the standard of work you do Charlie.
Good on ya!
But...if it's clean to start with, you are going to have to keep it clean...all the time...week in, week out...year after year after year.
Good on ya!
217 Re: 83-84 engine cleanup Tue Jul 24, 2018 12:26 am
Now you've done it, you are now going to have to polish the engine to match.
218 Re: 83-84 engine cleanup Tue Jul 24, 2018 3:48 am
geez …
thanks guys ...positive comments keep this old bloke trying hard to make the best of what has been contributed from some awesome folks around the country
even some overseas help has arrived ...sometimes quite unexpectedly ..along with the odd, negotiated small parts finds …. thanks
you know who you are
and I feel blessed that I have friends like you all
219 Re: 83-84 engine cleanup Wed Jul 25, 2018 11:49 pm
jmccrary
Charlie, you keep making the rest of us look bad. I do not think any K rolled off the grimy factory floor looking half as clean as your bike is. Keep up the awesome work and maybe one day I will have something as nice as you are making everything!charlie99 wrote:geez …
220 Re: 83-84 engine cleanup Thu Jul 26, 2018 4:04 am
MartinW wrote:Now you've done it, you are now going to have to polish the engine to match.
oh ? you haven't seen this yet martin ?
possibly earlier posts and pictures may have disappeared ?
but sump coming off now for a output shaft change over ( its got a bit of movement im afraid ) and the water pump issue ...now found
and of corse stainless screws to go back in on the non structural covers and plates ...and a bit more work to come
222 Re: 83-84 engine cleanup Sat Jul 28, 2018 5:44 pm
223 Re: 83-84 engine cleanup Fri Aug 10, 2018 5:25 am
224 83-84 engine cleanup Fri Aug 10, 2018 7:08 pm
Charlie PM me about some bits I might have. Cheers Tom
225 Re: 83-84 engine cleanup Fri Aug 10, 2018 8:16 pm
226 Re: 83-84 engine cleanup Sat Aug 18, 2018 12:51 am
bit more playing with the motor today
finally pulled the sump and output shaft
unfortunately the sump is buggered , the face of the pump assembly is had it ...there are deep scores around the large gear (that was bound into the housing ) and it has scored the bridge between the ventricles of the two gears -pump
there s a bit of a clue to how this may have happened whilst looking at the pump end of a very worn output shaft
of corse the old antibacklash spring is bound into the rivet heads and cut-worn a new grove in the spring at the retaining point
the rubber buffers in the buffer housing have shrunk markedly allowing lots of movement (expected ) ...and about 2mm movement in the fixing rivets
fortunately smithy has loaned me an output shaft fit for purpose , with a replaced and newer version antibacklash spring , no noticeable movement in the rivets ...but the buffer rubbers are a close fit rather than a tight fit …
may have to machine a grove into the later version sump I have here (with good pump faces ) to allow the old style bearing on the output shaft
so on we go ...
so on we go ...
227 Re: 83-84 engine cleanup Sun Aug 19, 2018 8:45 pm
MarcS
That's some serious mechanics you have going on there. Awesome job mate
228 Re: 83-84 engine cleanup Sun Aug 19, 2018 9:17 pm
thanks mate
i better look at the crank bearings etc before going further , there maybe signs of crap that has entered them ...but maybe the filter has caught it before going further fingers crossed ? nothing would surprise me at all with this one .
229 Re: 83-84 engine cleanup Thu Aug 30, 2018 2:51 am
gutted ...all that nice white paintwork for the red frame project ...is going brownish ....
likely the poxy clear coat that i used over it ....i should have known better than to use the septone version …
i have found a new version of clear coat from a different supplier …
compare the helmet and the fender ...were the same colour once upon a time not long ago
...the difference is the different clear coat ...
has affected the main fairing . rear cowl and everything else i did back then ....
i guess rub it all back to base colour and start again ........
will wait a few weeks till the temperature has settled into the 20s overnight instead of 4 and 5 c
230 Re: 83-84 engine cleanup Thu Aug 30, 2018 7:17 am
That is... not funny. At all.
I've no idea what the grill is on the floor Charlie, but it gave me an idea (and I bet you've already got there). I replaced the mesh on the radiator guard with stainless steel. No more rusty bits.
231 Re: 83-84 engine cleanup Thu Aug 30, 2018 12:49 pm
Aw, that's a crying shame Charlie after the huge amount of effort you put into the paint job. Still, the silver lining is, with all that extra rubbing down, the end product will be even more fabulous than it was before. I hope you didn't use that pesky clear coat on any other bits that may not have been exposed to that gentle Queensland sunshine yet.
Paul
"Gretel" K100LT 1989 (
"Donor" K100LT 1990 (Red) (VIN 0178091 Engine gone to Dai) - 6th & final owner (crash write-off now donor bike). June 2012 (73,000 miles) to November 2013 (89,500 miles)
232 Re: 83-84 engine cleanup Sat Sep 01, 2018 1:18 am
233 Re: 83-84 engine cleanup Sun Sep 02, 2018 5:33 am
234 83-84 engine clean up Sun Sep 02, 2018 11:42 am
norton71
Gees Charlie I hope you also get some high density foam for the the seat or you may need heaps of Preparation H...
235 83-84 engine clean up Sun Sep 02, 2018 12:54 pm
norton71
or learn to enjoy this https://youtu.be/M8J8urC_8Jw
236 83-84 engine clean up Sun Sep 02, 2018 1:04 pm
norton71
based on the Nutcracker "Seat"
237 Re: 83-84 engine cleanup Fri Sep 14, 2018 11:13 pm
238 Re: 83-84 engine cleanup Sat Sep 22, 2018 1:31 am
239 Re: 83-84 engine cleanup Sat Sep 29, 2018 2:13 pm
getting closer to wiring a loom together
arrived yesterday some loom tape
2 x types. the normal tight weave tape and another what is called a "fleece tape"
just to wait on some suitable 4mm cables of different colours for some extra wiring options ie repurposing the ignition switch to operate a relay for ignition things
240 Re: 83-84 engine cleanup Sun Sep 30, 2018 11:33 pm
whilst cleaning stuff this week ...and with some reasonable results to footpeg plates
thought to pull out the swing arm for the red frame project , the clear coat darkening over time , now removed
bit of a clean up before attempting similar to Gerty , call it research
also did the starter motor
I guess wax maybe the way to keep it clean ???
241 Re: 83-84 engine cleanup Mon Oct 01, 2018 6:51 am
Present for you Charlie. This is the diagram I use for commercial builds.
242 Re: 83-84 engine cleanup Mon Oct 01, 2018 8:28 am
cool thanks Dai
all similar details to be applied in my loom
but the key switch will switch a relay back in the electrics box , so some of the wiring will be duplicated in some areas , but that's not an issue I can see causing any problems ,
but a few more relays to go in there , to make room, the bmu will go , etc
some extra control cables from dash back there as well (aux lights , fan control , voltage indicator , usb output and more )
a few cables to be replaced with same - similar colour with a bigger cross section ...etc
different connectors to tank and a few other locations …
the list goes on mate
243 Re: 83-84 engine cleanup Mon Oct 01, 2018 4:00 pm
The company actually mounts the sidecar electrics box in the seat well - the body design makes it easy to get at and it puts it in a weatherproof area. I use these (or similar) as the fuseboxes, simply because its an immediate failure indicator:
https://www.ebay.co.uk/itm/4-Way-Blade-Fuse-Box-with-LED-Indicator-Fuse-Block-for-Car-Boat-Marine-H8K2/323477011607?hash=item4b50bb7c97:g:YEkAAOSw1ZBbrivM
I put another 5mm setscrew in one corner to use as the common earth point. Also, the electronics box I use has a transparent lid so you can see the fuses. If you don't want to put a box in the sidecar, there's more than enough room to put relays and fusebox on a plate in the sandwich box (seat hump! ).
Also, I see that the forum software is having problems displaying the headlight high beam wire. On my original diagram I use a very light grey (slate) as a stand-in for white: it should be attached to pin 87a on the headlight relay.
244 Re: 83-84 engine cleanup Fri Oct 05, 2018 11:43 pm
got some "Ultrabond " for repairs on the fuel tanks , and a portagas type burner
initial results were very poor , as I couldn't get enough heat into the metal on the tank ,,,, it just spread the heat out away from the area
so armed with some MAPP type gas rather than butane , and lots of patience it finally got to heat ,,,just
just enough for a good tinning process and a good flow of material to cover the small and large holes apparent
still to do a pressure type test, but looking like it should work out ok
nearly cant see that its been done from top side
245 Re: 83-84 engine cleanup Sat Oct 06, 2018 8:13 pm
Charlie... I don't want to scare you BUT... I find with that stuff (also call Durafix) you need to get the area at least 50% hotter than flow rate and you need to apply around 50% more than you thought you'd need. Really, really double-double-double check it; if you can see the slightest hint of an edge, try levering it off because there's a large chance it will depart when you least want it to. And let me ask a stupid question: you did clean the weld area with a stainless steel brush? If you used an ordinary wire brush then there's a large chance you may have contaminated the weld because the ordinary brush will leave microscopic iron filings behind. The stainless one doesn't.
Yes, I've had what appeared to be a perfectly good weld fail on me because I didn't follow the instructions exactly... Fortunately it wasn't somewhere critical.
For anyone that's interested, here's Durafix' website: http://durafix.com/
246 Re: 83-84 engine cleanup Sat Oct 06, 2018 11:58 pm
dai the tinning process went right to the edge ,,, later the pool overlapped the tinned section
I have jiggled it pulled at it , filed it and sanded it with an orbital sander ,,and it doesn't budge at all ...pretty hard stuff to work actually
at the moment I have the tank sorta sideways so that some vinegar is sitting where the four holes (2 x above the tank weld , more pin pricks and 2x larger ones on the under side ) waiting to see if there are any leaks .
ill get a fuel sender seal in there and attach the sender and double up the send and receive fuel spigots and shunt the breather tube , maybe make a sealing lid filler hole for the so that I can get a bit of pressure in there for a test ,,, should be able to use the breather tube as a inlet ?
might push a slight ding in the top right hand side out eh ?
thanks for the heads up mate ...appreciate it !!
247 Re: 83-84 engine cleanup Sun Oct 07, 2018 6:56 am
You're welcome. I'd rather set off a panic now than have you find a hole miles out in the bush.
248 Re: 83-84 engine cleanup Sun Oct 28, 2018 1:13 am
a couple of wins at the swap meet yesterday …
first a cooler ,
then some mx bars ,all pretty and anodised ....yeah right …
then the mx bars cleaned up …
should give me a wider stance , similar to rt bars with the risers on the head ...(50mm up and back )
the bars used to measure 22.25 mm now about 22.05 mm ...should fit ? or close to …
the throttle tube over the bars is smooth at least and doesnt catch
first a cooler ,
249 Re: 83-84 engine cleanup Sat Nov 03, 2018 4:03 am
some more work today , attempting to clean off the black paint on those levers
its pretty hard stuff with no chemicals able to shift the black stuff off (that I have found yet )
so resorted to abrasive methods as usual
looks ok
and dug out a clutch lever for similar treatment …..still to find a perch yet ...but will be found
looks ok
250 Re: 83-84 engine cleanup Sat Nov 03, 2018 9:25 am
Charlie, I'm pretty sure those levers are powder coated. If you can't find a perch locally, I have a couple in my spares pile. You are welcome to one of them for the(not insubstantial) postage to Oz.
251 83-84 engine cleanup remove powder coating on levers Sat Nov 03, 2018 9:54 am
norton71
Similar topics
