Go to page : Previous  1 ... 9 ... 14, 15, 16, 17, 18  Next
View previous topic View next topic Go down  Message [Page 15 of 18]
701Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Sep 09, 2014 9:20 pm
merps
hey floyd, et. al., just had to join because - well - of my rebuild - and to give thanks to all you gents for the wealth of information that you've all provided floyd - thanks all and I hope to reflect upon this pool of wisdom for my rebuild..
KUDOS!!
702Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Wed Sep 10, 2014 1:52 am
floyd
floyd
merps wrote:hey floyd, et. al., just had to join because - well - of my rebuild - and to give thanks to all you gents for the wealth of information that you've all provided floyd - thanks all and I hope to reflect upon this pool of wisdom for my rebuild..
KUDOS!!
Cheers merps and welcome aboard mate. Hope you find some nuggets of gold in this long winded ramble.
And I will join you in once more thanking the incredibly generous and knowledgeable old souls who (at times) baby stepped me through alot of this journey.
Im bored in the arvos now that I dont have a bike to rebuild so let me know if you need a second set of hands, as I see your in Sydney. Ive just moved to Maroubra. Loving the beach again.
703Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Thu Oct 16, 2014 6:59 pm
floyd
floyd
WOW!!!
WOW!!!
WOW!!!
Yesterday I had the greatest motorcycle ride of my life....on a brand new bike.....for free.....wanna know more??
Well, i just finally got around to messing with my RAM shock and stiffened the sucker right up and MY GOD!!! I now have a brand new bike!!
I can not believe the massively dramatic difference it has made to the entire bike. IT CAN NOT BE UNDERSTATED. my mind is blown!! I can see why people spend heaps on good suspension and set up. (confession time - I had the Mrs and some luggage on the back and the bike was handling like a pig. I pulled over, cranked up the preload and off we went again. Was great. Returned home, unloaded mrs and gear and went riding again without touching the suspension from my previous adjustment. AND IT IS FREAKIN UNREAL! Cant wait to see what its like when its really setup properly!)
The last week has also been a week of 'set up'. I stripped the bike down, throttle bodies off, fuel lines out, wiring all exposed, and got down to fixing all the hundreds of tiny things I had noticed could be better, or I had done wrong the first times.
Stuff like re routing the switch gears wiring,
re routing the clutch/choke/throttle cables to more suitable paths etc.
painting and fitting side covers
insulating fuel lines
adjusting TPS
adjust all control cables
sort out some wiring issues
cut down the sides of the front fairing even more for less potential area to get damaged in a drop (pics to follow)
Pulled the plugs just for a look, they look pretty good.
Got some new odo gears to fix mine ($100 for 4 gears!)
Ordered a Jensen MS30 marine stereo to be dash mounted. Need to fabricate an aluminium dash plate/box to hold it and the ignition.
Wiring in car lighter charger and USB charge ports.
Wiring in aux fuse block to handle headlights, stereo, chargers etc
One of the biggest issues I discovered had to do with the K1100 throttle cable that actuates the K1100 TB's. The outer plastic and wound metal sheath of the cable had to be shorted to enable the set up to work on the K100 engine. I did this back during the rebuild but a few days ago discovered I had not trimmed off quite enough and the TB butterflys were not closing all the way to the stop. The slightly to long sheath was not allowing the cable to return all the way and thus was holding the TBs open ever so slightly when the throttle was closed - resulting in a slightly high idle (1100rpm) that I couldnt tune out. Well, now thats all fixed and the throttles operate perfectly.
Fitted a Hepco and Becker pannier and rear rack which is fantastic. Very happy with this acquisition. Will be welding on some modifications and some strengthening bits.
About to go by some camping gear and then the next few Summer months will be spent travelling the countryside looking for farm and harvest work while generally pointing myself toward Indonesia.
704Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Thu Oct 16, 2014 9:38 pm
floyd
floyd
Around the World On a K100 - Page 15 Img_2018
Around the World On a K100 - Page 15 Img_2019
Bob just decided to take a piss by the looks of it....
I lost the front section of the K1100 front fender at speed some where? New one on the way.
Only had matt black rattle can on hand for the side covers, but it looks better then the factory blue did with my absurd combo.
Need to repair the cracked fairing (how?) and repaint all the green bits.
Around the World On a K100 - Page 15 Img_2020
For the life of me I just can not find either one of my two lefthand side engine protection bar mounts....? when one turns up my chrome 'drop' bars will go on.
705Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 4:41 am
good onya Floyd
have fun mate
706Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 7:00 am
Around the World On a K100 - Page 15 44271 Not laughing at you Floyd; just your reaction to fiddling with the suspension. Way too many people throw shedloads of money at a bike to make it go/stop faster and ignore the twisty bits in the middle. One of the first things I did to LFB was to junk the original BMW suspension and fit Hypro progressives at the front and a made-to-measure RAM Shok at the rear. As you say, new bike... plus regularly scraped boots and I'm sure that with a bit more effort, scraped footpegs too.
707Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 11:44 am
Reg
Reg
Check the manual before trying to open any bolts, they may have threadlock, applying 120c heat gun before removing breaks it down, otherwise you p1ssing against the wind. worthing hitting them all with a bit of heat before trying to remove.and a bit of a whack with a hammer helps. good luck with the project..
708Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 11:46 am
Reg
Reg
feck sorry..just realised you have 15 pages..sorry ignor me, I think I ll just crack open another oneAround the World On a K100 - Page 15 Icon_biggrin
709Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 8:29 pm
I notice that you don't have an outer support for the lower bolt on the rear shockie. Where you are apparently planning to go it would be a good move to fit one. Just a bit of insurance.
710Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 9:12 pm
floyd wrote:Need to repair the cracked fairing (how?) and repaint all the green bits.
Use the techniques outlined in this West System fibreglass repair manual to fix the crack.
711Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Oct 17, 2014 9:25 pm
I've had a quick read through that Rob and I'd like to add one thing to make life easier: where it recommends scraping out a shallow crack with a modified can opener (or similar), I found that a Dremel with a ball grinder in it is perfect for the job.
712Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Oct 28, 2014 3:07 am
floyd
floyd
RicK G wrote:I notice that you don't have an outer support for the lower bolt on the rear shockie. Where you are apparently planning to go it would be a good move to fit one. Just a bit of insurance.
Yeah Rick, I totally want one. I will buy one off you if you can make me one. Also one of your tank filler cap riser mod thingys too. Seriously. Also, how are you with sheet metal work?... see bellow Wink
Cheers mate.
If anyone has any ideas on some 'fairing protection bars' like on modern big enduro adventure bikes, let me know....
713Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Oct 28, 2014 3:08 am
floyd
floyd
Design ideas sought....
(To clarify my ramblings....I dont care where the stereo/USB/ignition mount in relation to each other on the dash. Also, the stereo has 2 female threaded mounting points on its base. )
714Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Oct 28, 2014 6:10 am
Jez
Jez
Hey Floyd,
Have you considered mounting the radio in one of the lining panels that go between the fairing and the tank. Say the marine radio on the left, ignition (although it would require extension) and USB OPs on the right.
Honestly dunno either the ergonomics you're seeking or the do-ability, but there's one thought either side o' the box.
Good luck with it.
Jez.
84 K100 RS
Chassis number     0080546
715Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Oct 28, 2014 12:32 pm
Kyle10
Kyle10
Floyd,
What's the back of the stereo receiver (?) look like? Through up a pic, if you would.
The former ignition hole: affix a stem through it and mount a ball mount swivel? Ref. 'Ram' products.
You're idea utilizing the 'bar mounts to support a mounting bar could work but take care in maintaining proper bolt thread depth and torque.
Best of luck and keep us posted.
1985 K100rt 0052183
1983 Honda VF750 007713
716Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Oct 28, 2014 5:55 pm
floyd
floyd
Kyle10 wrote:Floyd,
Hi mate,
Back of stereo is flat, with 2 x 4mm (approx) female threaded holes.
Ive had a few idea over night. If I had some bits of scrap laying around like out at the farm it would be much easier to figure out. But when you have nothing on hand to make use of...then the design becomes as much about figuring out to acquire and use as it is about the actual design.
Thinking im just going to go uber simple for the time being, until I get around to install an AUX fuse block and some other bits and bobs.
Will get some flat plate or some angle iron, bolt that down using the handle bar mount bolts. So, picture this.....just a flat plate bolted down onto the top of the handle bar mounts....then, the stereos rear mount threaded holes can be used to bolt the stereo to the flat plate. (well, i guess You would attach the stereo first, then bolt the stereo/plate combo onto the bar mounts.
Still not sure how Ill mount the ignition switch as I need to figure out a way of grabbing hold of it. Is there a name for round clamps that could be used to grab the ignition barrel?
Jez, I have significantly hacked back my front RS fairings and dont think the 'liners' will fit anymore. dont really want to use them anyways. However, it does make alot of sense what you suggested....
717Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Oct 28, 2014 8:17 pm
Kyle10
Kyle10
Maxiloc Tube Connectors (AU)
Excrement loads (family site) on the referenced page.
Hover over prods. for images on the right. Nice machined stuff; avoiding the 'threw-it-together' look, perhaps.
1985 K100rt 0052183
718Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Thu Oct 30, 2014 7:47 pm
floyd
floyd
Kyle10 wrote:Maxiloc Tube Connectors (AU)
Wow! Thanks mate.
This will do for now.....
Coat hanger left behind on road in the aftermath lf the garbage pick up...
Love the colour
Around the World On a K100 - Page 15 Img_2021
719Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Thu Nov 06, 2014 4:31 pm
floyd
floyd
Going to set up an auxilliary fuse block today, along the lines of ducks guide.
Before I start cutting and soldering, will this work?
Around the World On a K100 - Page 15 Img_2010
720Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Thu Nov 06, 2014 10:42 pm
Move the fuse to the leg between the start relay and your switching relay.  Otherwise OK.
721Back to top Go down   Around the World On a K100 - Page 15 Empty LED Blinks Thu Nov 06, 2014 10:50 pm
Jez
Jez
Hey Floyd,
Sorry bit off topic at the mo' but your front indicators are LED yeh? I'm assuming then that the BMU will deal with the different loads fore and aft and not give a "bulb out" double rate indicator indication?
Just looking ahead for going down the LT bar route and ditching the RS rearview/indicator pods.
Jez.
84 K100 RS
722Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Thu Nov 06, 2014 11:15 pm
Be made
Be made
May have been asked before but . .  where to get this cover ??:
Around the World On a K100 - Page 15 PO0001
723Back to top Go down   Around the World On a K100 - Page 15 Empty Decals? Fri Nov 07, 2014 12:05 am
Jez
Jez
Just came across these,
https://app.box.com/s/j2qqn2hvzau8jqhk1d1j
just a thought for an army green K from Oz doin' the OS rounds. Not that I'm a jingoist.
84 K100 RS
724Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Nov 07, 2014 4:46 am
floyd
floyd
robmack wrote:Move the fuse to the leg between the start relay and your switching relay.  Otherwise OK.
Thanks mate
Jez wrote:Hey Floyd,
Jez.
LEDs up front, stock indicators in the rear. As soon as you change even one of them over to LEDs the BMU knows and flashes faster....
Around the World On a K100 - Page 15 Img_2013
Be made wrote:May have been asked before but . .  where to get this cover ??:
Motorworks Injector Cover UK
725Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Nov 07, 2014 4:57 am
floyd
floyd
Found this ABS 'safety case' at Jaycar that looked to be about the right size for my new 'dash'.
Mounted up pretty easy but required cutting which means its no longer water tight (which I may remedy) but the stereo is waterproof.
Used the mounting points for the original dash pad.
Next is to cut a 3'' hole for the stereo and holes for the ignition switch and the USB charge ports.
Pretty happy! Its solid as bro.
Around the World On a K100 - Page 15 Img_2015
Around the World On a K100 - Page 15 Img_2016
Got these puppies fitted up today too...didnt think they would fit but I got them on. Very solid. Should same me a few levers.
Around the World On a K100 - Page 15 Img_2017
Also got my brand new odo gears correctly installed and the odo is now working correctly! Just need to remember this engine has 126,000 kms more on it than indicated....  affraid
726Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sat Nov 08, 2014 4:15 pm
floyd
floyd
The area of knowledge and skill that this forum and project has taught me the most about is bike electrics. I knew basically zero about this topic prior to embarking on this project and you mob have been so helpful. Thank you thank you thank you.
Yesterday I was able to successfully wire up a relay-switched auxiliary fuse block. I now have 4 extra fuses conveniently located on the right side of the relay box. I also moved my headlight relays into the relay box where I had intended for them to be all along. It all works wonderfully
There was no room for me to mount it on the other side next to the original, as the flasher relay is in the way. There is heaps of room on the right under the starter relay though.
The 2 head light relays are there 'floating' in the middle of the spaghetti. The new switching relay is the relay 2nd from the right on the bottom row (in the perspective of this pic) I raided a relay connector from another 'parts' wiring loom and relay box I have.
Also fitted this rubber bung in the base of the realy box. The relay box I was using did not have one, but my 'spares' one did.
Around the World On a K100 - Page 15 Img_2022
727Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sun Nov 09, 2014 4:52 pm
floyd
floyd
- Starter brushes added
- Wiring done for stereo/chargers/driving lights
- Dynamat installed
728Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Wed Nov 12, 2014 4:58 pm
floyd
floyd
floyd wrote:Going to set up an auxilliary fuse block today, along the lines of ducks guide.
Ok, for those interested in attempting something like this.....
The single inline fuse should be moved to the leg between the starter relay and the new relay. (thanks robmac)
The switching wire for the new relay should come from the green/black wire @ fuse #1
(if its done like I have drawn above, the relay will only switch the new fuse block on if the parking lights are switched on too.
729Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Nov 14, 2014 4:31 am
floyd
floyd
Around the World On a K100 - Page 15 Img_2011
730Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Nov 14, 2014 4:49 am
looks good Floyd ,,,bit bulky ...but functional for sure ....
love mods that fit the riders needs
731Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Nov 14, 2014 4:58 am
floyd
floyd
bit bulky indeed. but in the flesh it doesnt look out of place (to me).
for now....it will do
for $30.... it will do
i my friend....have some riding to do!
Cheers Charlie
732Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Nov 14, 2014 6:55 am
Dai wrote:Around the World On a K100 - Page 15 44271 Not laughing at you Floyd; just your reaction to fiddling with the suspension. Way too many people throw shedloads of money at a bike to make it go/stop faster and ignore the twisty bits in the middle. One of the first things I did to LFB was to junk the original BMW suspension and fit Hypro progressives at the front and a made-to-measure RAM Shok at the rear. As you say, new bike... plus regularly scraped boots and I'm sure that with a bit more effort, scraped footpegs too.
Dai,
This very valid comment brought back some memories.
Many many years back when I had a Honda CB500-4 I loved to read bike tests penned by a certain L J K Setright. Fast forward 30 years to about 2001 or so I purchased a then new magazine called 'Mercedes Enthusiast' to discover one of their team was the very same L J K Setright. I was addicted again. Not so many years pack I was saddened when he passed away. His articles were always so very well written and although he might be riding/driving machines that were exotic to the majority of us he always wrote in a way that did not make you feel small for having something less exotic.
In one of these there was a serious article about high performance cars and the cost of achieving the performance. Very wise words written said that it was much more productive to learn to put what you already have on to the road instead of lusting after more power. Two things, one being driver training [on the track] and the other was simply making sure your power train and suspension were fully up to the spec. A few simple suspension/tyre mods were all that might be needed and the rest was on learning to put down what you already have through training and having confidence in your machine. Those of us who had the Honda CB500-4 had rapidly discovered on the twisty Irish roads of west Cork and the Atlantic seaboard that they were significantly faster than either the CB750 or even the Kawasaki Z1 that followed, simply because the 'less power' could actually be used to its full potential. You could deliberately take a curve with the sides scraping and not feel tickles up your spine.
The K probably only has 50-60% of the power that some newer bikes have but most of us find its so much more usable. All that's needed is to put more of it on the road with less rider effort. That suspension post sums it all up and its a lot cheaper than trying to get more out of the engine. Funny now I enjoy the K a lot and after changing a dodgy rear shock for a new one the day before going to France last year am thinking of going this road too. Not to get more speed out of it [a few sighs of relief over here] but simply to improve it and make longer trips even better.
I would sum it up as getting the balance right. As in balance between power, road and rider. I think its referred to as Nirvana. Its lovely to read when someone discovers it!
A word of warning though. On the way you dumped the missus off the bike......!! You might need to retrace the steps a small bit. On that I have a great memory of a 2 up trip up into the Wicklow mountains on that same Honda, with a good friend after midnight as we were going to watch a night stage of the Circuit of Ireland car rally. We knew the mountain roads so very well and had serious lights and so we made good progress. Footrests and side scraped on the way up [he was a great pillion, each of us well under 10 stone] and it was one of those iconic trips you remember for life. His comment after we got home was the bike trip was much better than the rally. When we meet so many years later he still talks of that trip with a gleam in his eye.
733Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sat Nov 15, 2014 4:24 am
floyd
floyd
Mlostly all back together again....and geting better all the time.
Been working on it for about 2 weeks doing all manner of little tweaks, mods and fixes. way to many to list....but the result is a bike I love to own and ride more and more Smile
A bit agricultural...indeed. A tad ugly...you bet. But thats exactly the point! ; :afro:
Around the World On a K100 - Page 15 P10600104
Around the World On a K100 - Page 15 P1060011
734Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sat Nov 15, 2014 3:38 pm
well done Floyd ...
735Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sun Nov 16, 2014 3:18 am
Jez
Jez
Nice work Floyd,   cheers
84 K100 RS
736Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sun Nov 16, 2014 5:55 pm
floyd
floyd
Friends made this and put it on top of my birthday cake! Wink
Around the World On a K100 - Page 15 P1060016
KLR - at least there is a K in there.
737Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sun Nov 16, 2014 11:02 pm
Jez
Jez
Happy Birthday.
Around the World On a K100 - Page 15 502531
84 K100 RS
738Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Tue Nov 18, 2014 8:04 pm
martyman
martyman
Looks great!  the windscreen looks like it would work fine...
739Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Wed Nov 19, 2014 3:39 am
happy birthday Floyd
enjoy mate !
740Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 6:23 pm
floyd
floyd
Having done nearly 10,000kms up and down the east coast of christmas and the start of the year, Im now back in Dural to do some minor repairs and upgrades....
The bike performed flawlessly and I love it more then ever....a few niggling things that shit me though....
Just a quick list of the things ive done this week.
- full service, replacing all filters and oils
- checked torque on many nuts and bolts
- FINALLY got the clutch cable routed correctly.
- rebuilt the GPI. now works beautifully
- My RT instrument mount shattered on a corrugated road, so I welded a K1100RT mount onto my K100 headlight brackets. The 1100 headlight bracket had been butchered by P.O. This now works great.
- Installed my Apmlirider Amp into my stereo box (love this thing)
- Checked valve clearances - all in spec
My biggest complaint at this stage is the pathetic fuel range. Im lucky to get 280kms to a tank. For an 'adventure bike' this is faaaar from adequate.
When fully loaded and riding hard I get 14.5kms/L and when unloaded I get 15.5km/L. Hows this compare with you lads?
741Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 6:45 pm
Unfortunately. . . Its about right. I had some posts a while back about increasing range by placing a 5 litre secondary tank in the battery location. Not done it yet.
742Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 6:56 pm
floyd
floyd
92KK 84WW Olaf wrote:Unfortunately. . . Its about right. I had some posts a while back about increasing range by placing a 5 litre secondary tank in the battery location. done it yet.
Yeah Rick is doing something like this, and it would certainly be something id like to do, but its a rather large project involving relocating the battery, EFI computer, and re doing the wiring to enable this....Id be up for it but its a big job.
The other option would be getting the tank modified like this one:
Around the World On a K100 - Page 15 K75
Make it taller and wider I suppose. Then one day do the aux. tank mod too and get closer to a GS's range....
I wonder:
A) how expensive it would be to get the tank modified (as I cant weld aluminium or do anything sheet metal related...
B) modify a GS tank to fit....
743Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 7:18 pm
I was not planning to move the computer. Too messy and risky. Metal tank with a recess or space on top for it roughly where the storage space is. Li battery in rairing or behind seat. Also relocate coolant bottle.
744Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 7:53 pm
I was going to use a lithium battery until I found out about the explosion and resulting fire which is difficult to extinguish without a foam extinguisher. Not that this happens very often but I was going to use one so it could be placed in the same sealed box as the electronics.
I have been told that if you split the tank down the centre through the cap hole the tank can be opened out easily. I'm not too sure of this but have a few old tanks and one will soon be given the treatment so I will let you know.
I am considering using a 8-10 ltr tank in place of the relay box etc and turn the battery sideways to make more room.
Seal the main tank and vent it to the aux which will make the aux syphon into the main as fuel is used and also make a no loss system for the overflow. The electronics all but the ICU will be in a sealed box under the carry rack behind the single seat with the frame work for the carry rack being to protect the electronics box, strengthen the rear section of the frame and mount soft panniers and top box.
I would like to use a motronic ECU but have yet to figure how to make it work with the 3 cylinder ICU. The motronic ECU only ever was used with a 4 cylinder so has only two ignition channels where the K75 would need 3.
And I will be painting it yellow and black but have fears of a giant bumble bee attacking me.
745Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 8:12 pm
floyd
floyd
Hmmmm
fuel economy woes.
on one hand it seems my 15.5km/L (6.45L/100km) is about average....but then there are people getting 19-22km/L....
So I guess I need to rebalance the TB's as I didnt get it perfect last time...new Bosche plugs, new HT leads (mine are ancient) would be a good start.....
Then eventually getting the head refreshed....
Then maybe learning more about the dark workings of the AFM....
Any other obvious things Im missing?
746Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 9:34 pm
Rick,
Have you thought about using the Aux Tank as a trap tank and installing the fuel pump in it, being the lowest point for fuel pick up?  Then routing the pipe work through the main tank, as per usual.  It would all depend on the size of the aux tank and if a fuel pump would fit inside.  Even though the aux tank would be above the gearbox, I don't see excessive heat as a problem as there is plenty of airflow without the side covers fitted.  There is still protection for the fuel tank in case of crash.
Years ago I saw a CB750(?) with an aux tank in place of the ducktail behind the seat.  Made just so he could ride straight through to Bathurst and did not interfere with the stying of the bike.  No good on a chookie during a crash though.
747Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 9:48 pm
I have thought of that but there is more involved with making the aux tank and not a lot of space as the tank will be about 5 in wide at the widest point.
748Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 11:22 pm
You might look into a fuel cell to get extended range.  There is a person (Gwen) on Motobrick that fitted a fuel cell to her K1100RS.  The thread is here.
749Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Fri Mar 06, 2015 11:42 pm
I did see that when Gwen was posting here but that is where my top box will be. I don't want the range for non stop riding that Gwen does but to get between fuel outlets so I can do more remote places. I am sure you get the same in Canada as we have here like 400km between roadhouses and more if you leave the well travelled routes.
750Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sat Mar 07, 2015 1:35 am
k-rider
k-rider
floyd wrote:Hmmmm
fuel economy woes.
hey floyd
have you checked the temperature sensor on the aluminium stub ,behind the radiator on the left side ?
k-rider
751Back to top Go down   Around the World On a K100 - Page 15 Empty Re: Around the World On a K100 Sat Mar 07, 2015 2:48 am
floyd wrote:.....
Hi Floyd. Firstly, if your odo is out you won't get accurate fuel consumption readings. I check mine periodically against Google Maps. I know some will say Google maps is unreliable but I've used it over a few years in various vehicles and found it to be pretty accurate. Over 1,000 klm my odo and Google maps are within 1 or 2 klm.
The biggest gain in f/c I've got was from setting valve clearances. My exhausts were way out tho.
I also cleaned my injectors and got nearly 0.5 lit/100 better.
BMW say that a K100 should get 5.1 lit/100 and I've heard some say they get that and better (??) but BMW also recommend the use of fully synthetic engine oil ( Shocked uh oh ) and 100% synthetic can better f/c by around 5% (I've no proof of that apart from what I've read).
My f/c is a constant 5.6 lit/100 (5.6 to 5.7 loaded up) in freeway mode and providing I ride sensibly. Laughing  I'm coming up for an oil change next month and I'm switching from Penrite MC4ST 10W-50 semi synth to Shell HX7 15W-50 synthetic. I'm hoping to realise about a 2.5% gain that will bring my f/c down to about 5.4 and a realistic range of over 370klm with a couple of litres to spare.
Another thing to consider is the battery. A lower spec'd or under performing bat can load your alternator which will affect engine output and f/c.
Also have you considered if the off road tyres you're running are affecting f/c? For your setup 6.45 lit/100 might be about right.
Just some thoughts... every little bit helps.
 Around the World On a K100 - Page 15 Austra12    Fuel:  95 Octane
View previous topic View next topic Back to top  Message [Page 15 of 18]
