101 Re: Will I Never Learn? Fri Dec 13, 2013 3:21 pm
AJ.Valente
MikeP wrote ". . . I'll be fitting K100/K75C handlebars, once I've painted them, so I've started to get the controls ready for removal. I've never stripped the bars from a K1100LT before and had never really noticed that the end-weights have a plastic cap covering them. . . . "
Mike, this is the first posting I've seen where someone is lowering the bars on an LT.
I'm currently planning the same on my RT (also installing heated grips at the same time).
The big question is; why are you doing it?
Second, won't the lower bars interfere with the faring?
And thirdly, what are you doing with the slack accumulating in the cable, brake line, and wiring?
