1Back to top Go down   fan not starting when hot Empty fan not starting when hot Fri Apr 05, 2013 2:28 pm
emilios
Hi
I own a k100rs 1988
I had a problem with the radiator and i remove it to fix it..
When i put it back the fan that it was working before now it doesnt...
I disconnect it from its fuse and connect it on a battery and its working...
So..the fan is working...but not when its connected on its fuse and the engine get hot....
Can someone help me here...from where to start checking?
2Back to top Go down   fan not starting when hot Empty Re: fan not starting when hot Fri Apr 05, 2013 4:59 pm
emelios
there have been many questions about this....
many have found electrical connections to be the main problem
have a look at this one
https://www.k100-forum.com/t2198-cooling-fan
3Back to top Go down   fan not starting when hot Empty Re: fan not starting when hot Fri Apr 05, 2013 7:32 pm
Albyalbatross1
Albyalbatross1
I have seen this before as well.. (Hey.. Lunch Box rider!! Wink Laughing) Sometimes its as simple as shall we say...forgetting to plug the fan back in!!!
