1 Non Start K 75 Mon Feb 18, 2013 1:35 pm
George R
Hi All - Looking for help with my problem. Bought this running - dodgy clutch 1996 K75 Ultima last year and started to get it going properly. Got ABS sorted , then in January removed gearbox, binned oily clutch, replaced with new and all new seals. Now after a bit of illness I have got to the electrickery and have found the following problem - Petrol tank installed and connected, Ignition on - lights in dash light up correctly but gear position indicator not lit. Put in gear and light still off. Gear number visible in display and changes with pedal operation.. Checked off switch to both sides and seems to be working correctly. Press start button and still no light change or fuel pump click and no sound from starter. Have power to the starter relay. Bulb in dash working.
Apart from the ABS and disconnect and connect the Gearbox position switch, I cannot think of anything else I have disconnected.
The electrics are the same as the K100 so if anyone on that part of the Forum can help please get in touch as well.
Any assistance greatfully received
