1 hard to start, but wants to start but dies shortly, or dies when opening throttle... Mon Apr 20, 2020 5:20 am
Noisey
Brought the bike as a winter hack (very cheaply)...
The guy claimed he had just replaced the fuel pump, but I wouldn't trust his word on that, after the state of the bike...
It ran, as I rode it home..
Fixed head bearings (grease had solidified) and rear brake (seal gone)...
But since, the sprag starter keeps letting go... I've put in some diesel Turbo oil to try to clean the sprag, hopefully without having to strip it...
Sprag doesn't correct with wheeling backwards in gear... it is better after being stood but after a few tries it returns to just letting go...then every 3rd or 4th try sticks long enough to get the motor trying to start...
BUT it just wont start, it wants to, if I can get the sprag to stick.. it runs for a short period (just a few seconds) then dies.
Similarly if I try to open the throttle, to get it to run, it dies...
I managed to get it started a while back and ran it for half an hour, (under virus lock down so no riding), it ran rich, but it ran.
Although I had to start it on the choke, even though 23 °C....
Strangely the gear indicator LCD, has gone from a nice font, to as if the LCD is bleeding , so the gear numbers are blotchy, as if written on blotting paper..
Could this be the pressure regulator ? Somewhere here I read you can remove the vacuum connection and it will run ok ?
I don't want to spend loads on this, swapping parts in & out, to get a fix...
I have other bikes, so could do with the room , if this is a bust, will just sell for parts... I was hoping to just have a nice winter hack...
I am not confident electrically, I have a volt meter, so can check continuity, voltage etc, but nothing technical...
Any idea ?
Any idea ?
Last edited by Noisey on Mon Apr 20, 2020 10:04 am; edited 1 time in total (Reason for editing : more info)
