1 K100 dies when closing throttle.. Only starts after completely stopping Fri Jan 11, 2013 5:41 am
Rendrag
So I've had the week from hell. Bike died at Goulburn, on the way back from a round trip from Home (Newcastle) to Canberra. I thought it was water in the fuel tank, as it's had this issue before.. - Roll off throttle, or start going downhill, and the bike dies. Wait till the engine has completely stopped, and it'll restart no problems. Usually it's water in the fuel, and because of the way the fuel filter sits, if it's got enough water in there, it covers the 'face' of the filter and blocks fuel flow. I've had that happen to the car a few times, except that it happens after turning a left corner, because the fuel filter is facing across the car.
I totally drained the tank, emptied the filter, I did have a bit of water in it, but not enough to cause a problem.. Fuel pump seemed a bit weak though. That'd explain the bad idle i've had for the last couple of years, d'oh. After a 4 hour wait for a tow truck, and the mrs driving down to pick me and the trailer I'd bought in canberra up, and then a second trip down immediately after to get the bike home, I proceeded to spend the rest of the nights after work this week making sure the tank is clean, replacing the fuel pump, new filter, new hoses, etc etc.
Took her for a ride, and WOW. Starts on the FIRST press of the starter, idles perfectly, revs smoothly from 1000rpm to 9000rpm, it's a totally different bike! Hasn't ridden like that in 3-4 years!
BUT. 9 times out of 10 when I close the throttle (NOTE: *once* the bike is up to running temp.. when it was cold, it was fine! Going to go unplug the temp sender in a minute and see if it 'comes good' to narrow it down..) the bike dies. I have to pull in the clutch, wait a few seconds, then hit the starter - and I have a 1 in 3 chance of starting it.. It may just fire and die immediately two of those times..
I don't suppose that sounds like a 'known' problem?
Thanks,
Damien
Thanks,
Damien
