1 Fuel pump or relays ? Thu Jan 31, 2013 2:49 am
ausbrick
Hi all . I have had trouble with my latest family member (86 k 75 c )on my first long run it conked after350 ks of a very enjoyable days testing , I decided it was the fuel filter clogged up and did a flush of the tank and new filter which seemed to sort things out until recently it cut out again. Wondering if any one has had trouble with relays after the pump has cut out due to overheating from a blocked filter , can this sort of epiode damage the relays. My friend has had a similar problem with his 85 k100 rs both these bikes had been parked for extended periods and stopped after several hundred ks now they cut out intermitantly usually after running for an hour. (lesson always flush tank and install a new filter on a long time unused k). any ideas on the cause as its made me a bit hesitant on using it for long runs .pity as its a really pleasant little bike to ride.Cheers Brick
