1Back to top Go down   Mirror Housing on LT/RT Empty Mirror Housing on LT/RT Tue Apr 10, 2012 10:13 am
GARYSTIGER955i
GARYSTIGER955i
Q. Is it the same principle on removing the mirror housing from a K100RT/LT as the K1100, its probably been asked before but trawling the site I have only found the quote below, Im only asking as I dont want to break the casing, I know the procedure on removing the glass, its just the mirror housing from the fairing.
To disassemble K1100RS/LT mirrors from their housings, such as might be
required to replace a broken mirror or to prepare for painting:
  1. Remove the mirror housing from the bike by striking the top outer
    corner with the heel of your hand while holding it with the other hand
    so that it does not drop to the ground.
2001 Triumph Tiger 955i....
1987 Suzuki GS850G.... for sale
1989 K100 RTIC.....
http://www.gas-motorcycle-couriers.co.uk
2Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 11:00 am
Avenger GT
Avenger GT
Yep, that's it. Or try dropping the bike and you will see how easily it comes off!!! Laughing
3Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 11:05 am
GARYSTIGER955i
GARYSTIGER955i
Avenger GT wrote:Yep, that's it. Or try dropping the bike and you will see how easily it comes off!!! Laughing
Nope I dont fancy that.... it might cost an arm and a leg Laughing
1989 K100 RTIC.....
4Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 11:11 am
lol
did it on the weekend gt
predictable huh ?
saving grace ...i was on a dirt track halfway up a mountain ....tracks got deeper than the crankcase ....i was laughing with joy that i didnt draw blood as i rolled down the side of the chasm throught the lantana end over end over end ...and the k was happy to idle away till i got back ...just jammed the mirror back on ....ahem...in the approved manner ...and kept going up the hill
5Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 4:53 pm
To remove the mirrors, I strike them from the bottom but yes, it may be easier to strike them from the top. The reason is that it has only 1 holding pin on the top, but 2 on the bottom.
Check this post as it explains how to remove the pod as well as the mirror.
CF
Mirror Housing on LT/RT Frog15Mirror Housing on LT/RT Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 5:17 pm
GARYSTIGER955i
GARYSTIGER955i
Crazy Frog wrote:To remove the mirrors, I strike them from the bottom but yes, it may be easier to strike them from the top. The reason is that it has only 1 holding pin on the top, but 2 on the bottom.
CF
I have removed both mirror housings now, they were both greased and came off with a bit of persuation but easily.. Mirror Housing on LT/RT 212902
1989 K100 RTIC.....
7Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 5:38 pm
twincarb
twincarb
to using the wall of the garage to remove it.... oopps
8Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Apr 10, 2012 7:21 pm
charlie99 wrote:lol
What a well trained bike!! cheers
Mirror Housing on LT/RT Ir-log1188....May contain nuts!Mirror Housing on LT/RT Ir-log11
K75RTP - 1994
9Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Sep 18, 2012 9:37 am
AJ.Valente
AJ.Valente
twincarb wrote:+1
+2.
Didn't know they popped off like that. Now I have to learn to put it back on.
10Back to top Go down   Mirror Housing on LT/RT Empty Re: Mirror Housing on LT/RT Tue Sep 18, 2012 3:34 pm
AJ.Valente wrote:
twincarb wrote:+1
+2.
As it says in the Haynes manuals.."refitting is the reverse of the removal proceedure" but better to use your hand than garage wall Laughing
K75RTP - 1994
