1Back to top Go down   Drive shaft broken Empty Drive shaft broken Thu Aug 30, 2012 1:56 am
Rompunmaan Kunkku
Rompunmaan Kunkku
Hello, My bike Cardan shaft joint broken (120 000 km). But also gearbox spit up oil and this is amazing, bike swing turned even thought swing bearing seems in trim.
https://i.servimg.com/u/f36/17/76/30/44/29082015.jpg
https://i.servimg.com/u/f36/17/76/30/44/29082014.jpg
My bike is BMW K100 RS year. 1984
Last edited by Rompunmaan Kunkku on Thu Aug 30, 2012 2:36 am; edited 1 time in total
2Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 2:19 am
Hello Welcome to the forum.
Can you supply the year model of your motorcycle. This will help with the shaft replacement.
Early model had 16 spline at rear of shaft and late model had 20 spline.
Do you wish to do the repairs your self.
3Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 3:08 am
Thanks the shaft will be the early type with 16 spline or should be.
Do you want to do the repairs your self or are you trying to find the parts.
4Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 3:23 am
This forum has a member in Norway but he is not on line now. He should come on line soon.
He may be able to help you better than I can from Australia.
5Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 3:45 am
Rompunmaan Kunkku
Rompunmaan Kunkku
Rick G wrote:This forum has a member in Norway but he is not on line now. He should come on line soon.
Thx, I will fix it's myself, I hope so. In here Finland drive season is over, so we have long winter made repair our bike.
6Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 3:52 am
I thought you may have needed help quickly and you were broken down.
We have many people here who are very clever and willing to help with parts and advice for your BMW.
7Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 4:25 am
ReneZ
ReneZ
From your story it seems a simple drive shaft replacement (Ebay's your friend) and a new seal. From your second foto it looks as if your rear wheel is not straight upright, but assume that's a visual thing.
What have you got and what do you need?
Rene
BMW K100 - 1985 (0030029) Scotland Drive shaft broken Rain
8Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:08 am
Rompunmaan Kunkku
Rompunmaan Kunkku
ReneZ wrote:From your story it seems a simple drive shaft replacement (Ebay's your friend) and a new seal. From your second foto it looks as if your rear wheel is not straight upright, but assume that's a visual thing.
Real wheel is really warped ! I think that is worse than drive shat failure, becaus swing bearings seems good.
9Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:25 am
The only way to find out is to remove the swing arm. To do that first you need to remove the foot peg plates and that gives you access to the bearing.
I can see from the pictures that either the swing arm or the mounting on the gearbox is broken. You say there is oil comming out, from that I would say the gearbox may be damaged.
10Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:28 am
This is the second picture of a broken driveshaft I've seen this week.
How did it happen?
Sean.
11Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:53 am
I have not seen a front uni joint go off like that before but the usual reason is that they can't be lubes and if they get water ingress then they rust and that is when the fun starts.
12Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 2:39 pm
Rick G wrote:I have not seen a front uni joint go off like that before
Here you got another one..........
Drive shaft broken Drivle10
13Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 5:20 pm
walfish
walfish
Has your swingarm not dropped off to the right??
Drive shaft broken Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
14Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 5:44 pm
I was trying to read the newspaper but cannot understand anything Sad
Drive shaft broken Frog15Drive shaft broken Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
15Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 6:27 pm
Limited edition (one page).
Drive shaft broken Norweg10
16Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 6:52 pm
Norwegian and practical.....sounds oxymoronic! Cool
17Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 7:34 pm
Saxon7 wrote:Norwegian and practical.....sounds oxymoronic! Cool
My mother in law spoke Norwegian but my wife cannot read it. No luck on my side.
A one page dictionary sums up what I knew of English when I immigrated to Canada: 3 words....
Guess what they were. Yes, No and Fu#@k
I was able to manage for the first few weeks but rapidly had to extend my vocabulary Very Happy
18Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:27 pm
Let's derail the thread a little more.
I though the three words were going to be; beer, more, toilet.
19Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:48 pm
personally, I can't think of what else you might need......
Well ok....some technical vocab such as " My driveshaft is broken...."
20Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 8:50 pm
I have seen 2 like yours but that one has completly parted company with the front section.
21Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 9:16 pm
Drive shaft broken Hpim1010
Sorry Bert, did forget a fresh newspaper.
22Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Thu Aug 30, 2012 9:24 pm
Ah Ha and now I have greasy gunk all over my screen and finger prints to give to interpol lol!
23Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Fri Aug 31, 2012 3:09 am
24Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Fri Aug 31, 2012 4:12 am
Inge K. wrote:Limited edition (one page).
Drive shaft broken 44271
25Back to top Go down   Drive shaft broken Empty New Pictures my project Sun Sep 16, 2012 2:31 pm
Rompunmaan Kunkku
Rompunmaan Kunkku
Hello,
I am finally find time make my dismantle out.
Following parts are broken.
-swing bearing
-driveshaft
-protective rubber
-bearing oil seal ? (Oil leaked from there ?)
Drive shaft broken 16092011
26Back to top Go down   Drive shaft broken Empty bearing oil seal change Sun Sep 16, 2012 2:38 pm
Rompunmaan Kunkku
Rompunmaan Kunkku
Hello again,
Does anyone know ? Can I change oil seal outside gearbox ?
Drive shaft broken 16092012
27Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Sun Sep 16, 2012 2:58 pm
Shouldn`t be any problem, drill a couple of small holes 180o apart, use self tapping screws and a plier.
Be careful to clean out all drill shavings afterwards.
28Back to top Go down   Drive shaft broken Empty Swing bearing housing Sun Sep 16, 2012 3:20 pm
Rompunmaan Kunkku
Rompunmaan Kunkku
How about this ?
Should be replaced new ?
Drive shaft broken 16092014
29Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Sun Sep 16, 2012 3:33 pm
Not easy to judge on the picture, but if the surface where the outer race is mounted is undamaged.....it shouldn`t be any problem to reuse it.
I do see that the grease cup is destroyed, Oldgoat did find a solution for that in his resto thread.
30Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Sun Sep 16, 2012 3:53 pm
The grease cup could easily (cheaply) be replaced with a disc of thin aluminium cut from a drinks can.
31Back to top Go down   Drive shaft broken Empty Re: Drive shaft broken Sun Sep 16, 2012 8:23 pm
It's OK just a bit of thin aluminium behind to replace the shield like paul suggested.
