1 Drive shaft removal Thu Oct 06, 2011 11:08 am
ushes
Hi Guys,
I've started work on the bike today, I plan to grease the clutch splines and the drive shaft splines and I cant remove the driveshaft. I've got the rear diff off but I just cant shift the driveshaft. My bike is a K100RS 16V and the driveshaft arrangement is different to all the videos etc that I've seen. The shaft is recessed in the swing arm and I've tried mole grips etc to drag it out with a snatch type jerk but it just wont budge. Would it be wise to just grease both the rear splines at the diff end and leave the front alone, or should I persevere to remove the shaft ?
Regards
Steve
Regards
Steve
