1 Flywheel/Clutch housing Wed Aug 14, 2013 1:37 pm
the.postman
1985 K100 RS 104EA49840092 #0081788 SILVERish (Madison) Prod. date 05/12/84
1984 srx 600
1986 cbr1000f/h
I don't think so. That large washer is steel and is too big to find its way through the seal:
K75 doesn't seem to have them.ibjman wrote:I just checked my K75 spare engine....I don't see the washer so I probably included it in the kit when I sold the used clutch assy.
1986 k75, 1985 K100rt, |
If you check the pick on Jez's posting Romoving cover plate from clutch you can see the washer behind the seal and looking closely can see that it is worn, it has a little lip on the outer edge, Definitely Plastic or as CF has corrected a fiber washer.MikeP wrote:I don't think so. That large washer is steel and is too big to find its way through the seal:
Good show jez so we can expect to see you at Smithys Jolly Jaunt through the Mountains in a couple of weeks?Jez wrote:Just to finalise, my own submission to this thread,
Washer fitted, rattle gone!
Jez.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Flywheel/Clutch housing
Similar topics
