1Back to top Go down   Painting Disc Centres Empty Painting Disc Centres Tue Feb 07, 2012 8:40 am
The tatty paintwork on my discs really make the bike look shabby and I want to repaint it....
Painting Disc Centres Img_0319
The discs themselves are in good order. My question is what paint/primers do I need and should I be using heat proof paint?
88KE
2Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 8:59 am
normal paint finishes works ok for me 88
3Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 9:11 am
charlie99 wrote:normal paint finishes works ok for me 88
Yeah but what about the bike Charlie ! Painting Disc Centres 447221
Seriously tho' did you use satin or gloss finish?
4Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 9:22 am
i used gloss ...but after a few k s you wouldnt notice ...i thought gloss would be easier to keep clean
5Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 9:54 am
Hi 88KE,
You will need some sort of etch primer to start with. Halfords sell 'U-pol acid 8' in aerosol cans and I am a fan of Plastikote for top coats: I sprayed my sump cover gloss black 5 years ago and it still looks as good as new.
Cheers, Paul.
6Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 10:16 am
Thanks Paul. I'll be passing a halfords in Dublin tomorrow and I'll pick up that primer. I've used the Plastikote myself to good effect on other jobs. So thats a goer! Cheers
Painting Disc Centres Ir-log1188....May contain nuts!Painting Disc Centres Ir-log11
K75RTP - 1994
7Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 4:39 pm
beanoldboy
beanoldboy
All that lovely shiny alloy and it gets covered in paint.
I purchased a cheap buffing outfit -bench grinder and a couple of wheels and compound - and shine whatever comes off, alloys and stainless come up lke new. I could waffle it off as heat dissipation but truth be known , I just like shiny things.
http://www.airware.com.au
8Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Tue Feb 07, 2012 5:44 pm
BTW 88KE, Plastikote responds well to low temperature baking; Say 70 degrees C in a domestic oven for an hour or so. It means that parts can be painted, baked and refitted in a couple of hours.
9Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Wed Feb 08, 2012 12:43 am
marten
I just did mine last week.
Cleaned them up with a brass wire wheel on the drill.
Than degreased and used an etching primer.
Washed that of and when dry I sprayed black caliper paint .
To tape/mask of the disk a vinyl electric tape makes quick work to get clean around the center disk
Marten ( prepping and painting for two weeks now!)
10Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Wed Feb 08, 2012 3:13 am
I media blasted these with soft pellets, taped them off and sprayed them in satin black 2pak, then whacked them into the spray booth oven for a few hours at 70c. The fork legs, callipers and wheels got the treatment, too. It's durable and very nice to look at...Painting Disc Centres Dscf2710
11Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Wed Feb 08, 2012 7:35 am
BIG D
BIG D
Cool
I must say I too have used Plastikote for a variety of jobs and have found it to be a first rate product, and used it on the very job you are contemplating doing 88.
BIG D
12Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Wed Feb 08, 2012 7:43 am
BIG D
BIG D
Cool
Painting Disc Centres Dscf0121
In fact here is a pic off the bike and the fork sliders where also done with plastikote.
BIG D
13Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Wed Feb 08, 2012 6:44 pm
Thanks for the pics guys. I aspire to restoring my wheels and forks to looking that good. A clean k-bike is amazingly current looking in its design, a real sign of a classic.
It's interesting to notice the different effect between GIDH's discs painted out over the rivets and Big D's with just the dish done. I shall study it more before deciding what my finished ones will look like. I picked up the U-pol acid 8 today and I'm planning to tackle into it next week when the family is away for mid term. Then again the urge to ride without having to apply in triplicate to "management" might overtake me!
Meanwhile thanks for the encouragement and input. Keep it coming !!
14Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Thu Feb 16, 2012 10:40 am
Well a couple of evenings prepping and painting et Voila......
Painting Disc Centres Lt_pai10
The forks could really do with being bead blasted but that can wait (as could the wheels). Everything clearned up pretty well with a brass wire cup in the drill including the boltheads and fittings. I couldn't get the plastikote and didn't have enough here so I just used 2 coats of Halfords satin black.
Something had always bugged me about the front of the bike that I couldn't quite put my finger on and it wasn't until I'd stripped it completely, like the kerryman who sat up wondering where the sun had gone, it finally dawned on me......odd discs! One painted (with a few reminents of paint left on the back) and one not bare..never painted at all.
In the end I decided I preferred the look as per GITH's pic further back the thread (thanks for posting that man!). Also big thanks to Sidecar paul for the tip on the U-Pol Acid 8. I was well pleased with the adhesion this stuff gets as tested when getting some overspray off the disks.
Now what's next on the list....Radiator cover mesh methinks Wink
Last edited by 88KE on Thu Feb 16, 2012 10:49 am; edited 1 time in total (Reason for editing : add pic)
15Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Thu Feb 16, 2012 11:59 am
oh yeah ! thats the go 88 ...good work
16Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Thu Feb 16, 2012 12:44 pm
Oldgoat
Oldgoat
Huge difference between the before/after pics...great work 88! Cool
OG
17Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Thu Feb 16, 2012 12:45 pm
88KE wrote:Something had always bugged me about the front of the bike that I couldn't quite put my finger on and it wasn't until I'd stripped it completely, like the kerryman who sat up wondering where the sun had gone, it finally dawned on me......odd discs! One painted (with a few reminents of paint left on the back) and one not bare..never painted at all.
One older disc? BMW start to paint the disc hubs satin black from -86 models on.
Also complete discs that I have ordered afterwards have had painted hubs.
18Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Thu Feb 16, 2012 2:19 pm
Inge K. wrote:One older disc? BMW start to paint the disc hubs satin black from -86 models on.
Yes Inge, one older I'd say. The bike is '88 but the unpainted one looks older. They have almost identical (only .01mm difference) in thickness though so I'll get a few thousand more K's out of them.
19Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Thu Feb 16, 2012 4:38 pm
Well done 88, it's good when everything comes together. I 'u-pol'ed my clutch arm yesterday.
20Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Fri Feb 17, 2012 2:44 pm
MT350Explorer
MT350Explorer
I missed this m88e
Great work, what a transformation! It has to be one of the most satisfying jobs cleaning and repainting bits like this!
Best
Dave
1991 K100 RS 16 valve
21Back to top Go down   Painting Disc Centres Empty Re: Painting Disc Centres Fri Feb 17, 2012 3:10 pm
Excellent work you have made a huge improvement.
