sensei
Hi guys, I need to remove lower part - left and right side - of the fairing on my LT. How much do I have to remove and do I need to remove the inner (black) fairing part? How is the procedure step-by-step? Question
Thanks for any advise.
/Finn
I sent you a PM with a link.
Removing lower side part of fairing on LT Frog15Removing lower side part of fairing on LT Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
easy ...just time consuming finn ....good luck !!!
Don't lose any screws, whoops probably shouldn't have said that.
Rjtrucker
I had a fan fail at the MOA rally last summer. I had to remove both sides and radiator cover. The hard part was I had to remove the radio to get the left glove box out. You need to remove both glove boxes and the black inner faring. You also need to remove the crash guards.nthat was the hard part for me. I could not find a socket to fit inside the tube of the crash guard. Mine bike is a k11lt but it is the same process on the K100. Lots of screws and does take time. The 100 plus temps didn't help.
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
sensei
Thanks for your advise. Still waiting for the new part to arrive. It's an insurance claim, as the damage to the fairing was caused by the transport company who brought the bike from Germany to my home. But, with temperatures of -15 to -20 in Denmark right now, who cares. I'm not keen to work in an non-heated garage - even if it's on my K100 Blizzard
Man you guys are tough, no wonder your alcohol is so strong.
Best of luck
They use the alchol like antifreeze, purely medicinal purposes you understand.
sensei
Thanks to all for the advise. It's Saturday, snowing and freezing outside - I'll remain in front of the fireplace - and take my 'medicine' Wink
Do not exceed the amount of medication in relation to what the doctor has recommended,
in order to avoid the medical kickback tomorrow morning.
sensei
Hi Inge, I will certainly take your advise, when it comes to 'medication' my experience tells me that you guys knows best.... Wink
/Finn
I agree with Inge! You don't want the "medicine" to be worse than the "ailment". Otherwise you have to take more "medecine" the next morning...In Ireland we actually call this morning dose "the cure" ! Removing lower side part of fairing on LT 187214
88KE
Removing lower side part of fairing on LT Ir-log1188....May contain nuts!Removing lower side part of fairing on LT Ir-log11
K75RTP - 1994
Ewestland
Ewestland
I am new here and just got a 1985 K100RT, I am needing instructions on removing lower fairing also.
I saw that someone had a link or something,
Thanks in advance.
Eric
Hi Eric, stick up an introduction in the new members section and after you've made a few posts you can request access to the download section where there are manuals.
To remove the lower LT/RT panels it is first necessary to remove the inner knee panel. Work from the bottom up to do this. The pocket/glovebox needs to be removed. This gives you access to the screws.
88KE
K75RTP - 1994
15Back to top Go down   Removing lower side part of fairing on LT Empty Removing Lower fairings on a RT Mon Feb 20, 2012 4:25 pm
Ewestland
Ewestland
Crazy Frog wrote:I sent you a PM with a link.
I need that procedure also to remove lower fairings on my RT if you could send me the link also it would be much appreciated!
Thanks in Advance.
Eric
The procedure is in the download section.
Send me a pm to request the password.
CF
