1Back to top Go down   Hello for cork ireland Empty Hello for cork ireland Sat Jun 18, 2011 6:46 am
irishger
hi all
I just bought a 1991 K100 LT.
there is only 26000 miles on the clock and the bike is in good condition
just a few small jobs that need doing
Hello for cork ireland Bmw4
Hello for cork ireland Bmw2
Hello for cork ireland Bmw1
2Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 7:12 am
wow nice looking bike irish .....enjoy
and Hello for cork ireland 177912 to the forum
3Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 7:20 am
BIG D
BIG D
Cool
Hi and welcome irishger, a nice looking bike you have there.
BIG D
4Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 8:41 am
irishger
Cheers for the welcome
I need to repair the side stand, a new set of tyres,
and replace the front brake light switch. Then the bike will be sorted.
Must try and find a top box for it as well.
Is there much involved in fitting a rack for a top box to the bike
5Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 11:03 am
Oldgoat
Oldgoat
I like that color. Cool Welcome to the board!
OG
6Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 12:19 pm
BIG D
BIG D
Cool
Look for an original one on e-bay or even motorworks you have the base already there looking at the last pic, the topbox locks onto a centre coupling, could you provide us with a pic of the rack you have on the bike just to be certain its all there.
BIG D
7Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 4:45 pm
Comberjohn
Comberjohn
Hi irishger. Welcome to the forum. Good to see someone else from the same island. Get a lot of aussies on the forum though, and once they all start talking to each other I can't understand a word! Must be the dizzy soup they drink. Very Happy
BIG D is right. There is an original box that clips straight onto the rack on the seat hump with a slopping base and a locking bracket. They do come up regularly on eBay but be aware that a good one can go for nearly as much as a new one. Check new prices before you bid.
The original top box is not big. If you want a bigger one there are brackets available from box suppliers that allow you to fit a conventional one.
You can get a colour matched aerosol to match that nice gold paint scheme. There will be a few on the forum nashing their gums at your purchase.
8Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 6:59 pm
Wow, that is one nice looking bike. The colour of the seat really completes it.
Welcome, from one of those "what are they talking about now?" Aussies.
Very Happy
9Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 7:55 pm
Hi Irishger,
Great to have you on board and the bike looks excellent, there is a lot of info on the forum about fettling a new acquisition of a secondhand bike so as to get it sorted. Looking forward to reading about your experiences motoring in the Emerald Isle.
10Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 8:59 pm
club_c
club_c
Welcome Irish. Is that an original BMW security system I see?
11Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 10:51 pm
Welcome from Down Under, Irishger! I agree with others that the original equipment topbox is a bit small for anything other than what normally goes into a glovebox. Well, not that small, but you get the idea. Here is one answer to the problem, done the backyard Aussie way! My Da' always said make form follow function!
It's a shaped timber platform on bent steel rod which is bolted through the back cowling where the original bits would have gone, so no new holes had to be drilled. The platform's carved and shaped here and there so it sort of replicates the factory mounting plate to fit a larger, later type topbox from a F650GS/R1150R, etc. The 'box locks on using the original mounting points and when it's removed for solo flying the platform looks reasonably discreet. It also has the capacity for a fullface helmet sitting right side up and other assorted bits and pieces.
Hello for cork ireland Dscf2421
Hello for cork ireland Dscf2422
Hello for cork ireland Dscf2423
Hello for cork ireland Dscf2424
When I'm not using the topbox for my passenger a waterproof dufflebag sits right on the platform.
Hello for cork ireland Ozlong10
12Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 11:36 pm
irishger
lads is this the correct front brake light switch for my bike
Hello for cork ireland ELA59569
and what way is it routed before I start to strip down the bike
13Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sat Jun 18, 2011 11:54 pm
club_c
club_c
Hmm that looks rite to me but my bikes are not quite as new as yours. It should plug in under the tank. Need to remove tank to get there.
14Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sun Jun 19, 2011 4:50 am
geordnz
geordnz
Welcome Irishger. I should be able to understand you, my mother is from Cork!!.
Have you tried contact cleaner in the switch. I had to do it a couple of times to mine, and it's still going. It was making the brake light stay on. Took the switch out, sprayed it with contact cleaner while pushing the plunger in and out. Lots of dirty liquid came out and when it ran clear, it worked.
15Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sun Jun 19, 2011 4:56 am
geordnz
geordnz
Oh , and great looking bike, looks you got a good one, with everything in good shape, well done! :-)
16Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sun Jun 19, 2011 5:16 am
just so you know this is the bracket for the 22 litre top box
Hello for cork ireland Pictur34
and the box itself
Hello for cork ireland Pictur33
17Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Mon Jun 20, 2011 2:19 am
Just to clarify the black plate with the hole in is a removable plate that is fitted into the bracket and then the top box is latched down on to it. It is taken off when the box is not present, otherwise the plates are inclined to fall off the bike.
18Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Mon Jun 20, 2011 3:21 am
crikey k-bike ....never knew that ....mine seems fixed pretty well and no amount of bumping and shoving lets any movement become obvious ...
i bet theres a trick involved ....like turning it clockwise with your mouth held a certain way , whilst lifting and placing a thumb underneath the slot near the back and then pulling the whole thing off .............huh ? did i do good yet ?
Hello for cork ireland 44271
19Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Tue Jun 21, 2011 3:35 am
It is difficult to get it out but a good pal who had two K's said he lost a couple before he realised that some gymnasics his bike would get up to would enable it to buck the plate off. I thought fair enough since as they say experience sometimes teaches you things you wish you didn't know and not wishing to repeat his experience I have always wrestled mine out.
20Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Tue Jun 21, 2011 3:47 am
im still learning k-bike ......i hope i always will ....your advice is aways held in high esteeme and appreciation
21Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Wed Jun 22, 2011 12:22 am
Hi Irishger, they went off on a world of there own. My brake lead was routed straight up behind the foot peg plate and came out just forward of the rear master, then along the frame with cable tie under the right side cover and into the socket. Trouble is when I re did the brake piston and took the footplate off, the cable had been jammed
by P.O and had cut the chord. So be careful that it doesn't get squashed if you have that plate off.
That's my 5c worth.
22Back to top Go down   Hello for cork ireland Empty Welcome from Tasmania Thu Jun 23, 2011 5:29 pm
Rob Mc
Welcome to the forum Irishger, that is a very impressive K Bike.. Cheers affraid
23Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sun Mar 25, 2012 6:57 pm
Just saying hello also from Cork.
24Back to top Go down   Hello for cork ireland Empty Re: Hello for cork ireland Sun Mar 25, 2012 7:18 pm
krambo
krambo
Great looking bike and welcome aboard Wink
"Aut viam inveniam aut faciam." Hello for cork ireland Uk-bmw12
http://www.its-personal.net
