253 Re: 85 RS restoration (part #1) Fri Jun 10, 2011 2:44 am
254 Re: 85 RS restoration (part #1) Fri Jun 10, 2011 10:31 pm
Oldgoat
OG
[url=https://servimg.com/view/16262455/209]
[/url]
Last edited by Oldgoat on Sun Jun 12, 2011 5:12 pm; edited 3 times in total (Reason for editing : pics)
255 Re: 85 RS restoration (part #1) Fri Jun 10, 2011 10:41 pm
Oldgoat
Last edited by Oldgoat on Fri Jun 10, 2011 10:57 pm; edited 3 times in total (Reason for editing : edit)
256 Re: 85 RS restoration (part #1) Sat Jun 11, 2011 10:54 am
BIG D
Nice pics OG, seat pan looks great.
BIG D
257 Re: 85 RS restoration (part #1) Sat Jun 11, 2011 10:59 am
Oldgoat
OG
258 Re: 85 RS restoration (part #1) Sun Jun 12, 2011 7:05 pm
Oldgoat
Had plenty left over so went ahead and put some foil on the crank side just for giggles.
Last edited by Oldgoat on Sun Jun 12, 2011 8:05 pm; edited 3 times in total (Reason for editing : edit)
259 Re: 85 RS restoration (part #1) Sun Jun 12, 2011 7:29 pm
but get a new one it'll help with vibrations
under tank looks great....
you know ......um im thinking this resto will make it all too good to ride ...lol
260 Re: 85 RS restoration (part #1) Sun Jun 12, 2011 8:18 pm
Oldgoat
I guess I'm just an odd old thing Charlie, but I really enjoy the process of re-doing a machine, along with a little re-engineering as Bert would say, and than just running the snot out of them. Once enough stuff gets worn out or blown out I enjoy re-doing them all over again. I've never had a motorbike that I don't use for commuting, at least light touring, and fairly regular summer track days to help keep skills up. I plan on doing the same with the "Bismarck" once she is done.
OG
Last edited by Oldgoat on Sun Jun 12, 2011 8:41 pm; edited 3 times in total (Reason for editing : edit)
261 Re: 85 RS restoration (part #1) Mon Jun 13, 2011 3:32 am
262 Re: 85 RS restoration (part #1) Mon Jun 13, 2011 3:57 am
1986 k75, 1985 K100rt, |
263 Re: 85 RS restoration (part #1) Mon Jun 13, 2011 4:01 am
just re-do the other colours to black bert then youll have a match ....huh ??
264 Re: 85 RS restoration (part #1) Mon Jun 13, 2011 4:12 am
265 Re: 85 RS restoration (part #1) Mon Jun 13, 2011 4:16 am
267 Re: 85 RS restoration (part #1) Wed Jun 15, 2011 10:13 pm
Oldgoat
Just read thru this article by Rob Lentini and he recommends running the intakes on the tight side and the exhaust on the loose side of spec.Can one of you motor guys tell me the advantage of this ?
OG
http://www.ibmwr.org/ktech/hop-up.shtml
Last edited by Oldgoat on Wed Jun 15, 2011 10:24 pm; edited 2 times in total (Reason for editing : pics)
269 Re: 85 RS restoration (part #1) Thu Jun 16, 2011 2:42 am
An advance in the ignition timing by 2-4 deg will also help when you do that.
Personally I would rather just put a better set of cams in it and really make it get up and boogie.
270 Re: 85 RS restoration (part #1) Thu Jun 16, 2011 2:50 am
271 Re: 85 RS restoration (part #1) Thu Jun 16, 2011 8:10 am
besides that it tends to accumilate more gum and stuff that passes throught the burn process...and i would suggest that a nice click on closure when it comes off cam, would prolong the seats and valve faces ,,,,as they tend to pit way earlier than inlet valves..
besides the slight advantage that k_freak mentions
hoping you pull that "gnarly shim" and take pics mate
good luck !!!
sad news k-bike ...i have read some of his articles ...
272 Re: 85 RS restoration (part #1) Thu Jun 16, 2011 11:09 am
Oldgoat
OG
273 Re: 85 RS restoration (part #1) Thu Jun 16, 2011 11:10 am
Oldgoat
RIP
OG
275 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 3:46 am
club_c
276 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 3:55 am
club_c wrote:That bench is a sign of a sick mind OG.
yeah i agree club_c ....far too clean to be doing any work .....giggles
oh!!! to have a nice bench space ....but crikey....a whole shed ....sniifle
277 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 5:03 am
geordnz
Great job og,
When you have finished that baby, it will be better than new. Man,.. it will be amazing to hear what it's like to ride a brand new bike!!
P.S. If I send parts over one at a time can you do mine up as well. I think the postage from NZ would be worth it!! You are doing such an amazing job!!!
278 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 5:20 am
279 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 11:11 am
Oldgoat
OG
280 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 8:27 pm
Oldgoat
OG
Last edited by Oldgoat on Fri Jun 17, 2011 8:40 pm; edited 3 times in total (Reason for editing : pics)
281 Re: 85 RS restoration (part #1) Fri Jun 17, 2011 10:06 pm
Oldgoat
OG
282 Re: 85 RS restoration (part #1) Sat Jun 18, 2011 2:30 am
club_c
283 Re: 85 RS restoration (part #1) Sat Jun 18, 2011 3:49 am
I have seen it many times before but most offen on tapered roller bearings. They get bruised when they are put in with a punch instead of a press. The punch comes of the shoulder of the outer race when hit and strikes the bearing surface causing a bruise which shows up as a bearing failure much later.
It actually happened to me with my F250 front wheel bearing and only showed up after 60 to 70 thousand k later. When I took the bearing off to repack it I found it and recalled damaging it a couple of years earlier.
284 Re: 85 RS restoration (part #1) Sat Jun 18, 2011 5:29 am
but i see the leading edge of the cam lobe is in tact and i guess the trailing face is in reasonable nick too .....
good find on the exchange program ...that should make things easy mate .
nice result i would say
285 Re: 85 RS restoration (part #1) Sat Jun 18, 2011 12:00 pm
Oldgoat
OG
286 Re: 85 RS restoration (part #1) Sat Jun 18, 2011 12:01 pm
Oldgoat
details & discussion are back on page three, but the short answer is unfortunately this is the way I found her when I removed the valve cover.
OG
287 Re: 85 RS restoration (part #1) Sat Jun 18, 2011 5:12 pm
club_c
288 Re: 85 RS restoration (part #1) Sun Jun 19, 2011 9:07 pm
Oldgoat
OG
289 Re: 85 RS restoration (part #1) Sun Jun 19, 2011 9:09 pm
Oldgoat
Just wanted to give a quick shout to these guys: http://www.autolumination.com/
Great customer service, big selection, and were very helpful with the process of determining LED bulbs for the old girl.
OG
290 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 12:20 pm
291 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 1:24 pm
walfish
292 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 1:58 pm
Oldgoat
OG
Last edited by Oldgoat on Mon Jun 20, 2011 2:48 pm; edited 1 time in total (Reason for editing : edit)
293 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 2:05 pm
Oldgoat
I'm just re-doing my insrument cluster/guages and going to a full LED conversion and the bulbs needed are 194's. They have a big selection and I went with the oval wide angle and the inverted lense.
http://autolumination.com/194.htm
OG
295 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:01 pm
watching with interest .
i gotta come up with a solution for the fuel guage and temp guage ....they have tiny 2 watt globes and are quite hard to see at night (odd fitting on them also ...makes it hard to find a good replacement )
296 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:05 pm
Oldgoat
OG
297 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:23 pm
but still looking
298 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:27 pm
Oldgoat
OG
299 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:34 pm
dont loose the piece of rubber ...as you will have a foggy meter after wards.
i have some heat shrink to replace my lost one , but im waiting to find a solution before going back in there again
300 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:36 pm
Oldgoat
301 Re: 85 RS restoration (part #1) Mon Jun 20, 2011 8:46 pm
figure 6 is the one mate
Similar topics
