1Back to top Go down   Wanted blinker relay unit for a K75C Empty Wanted blinker relay unit for a K75C Tue May 16, 2023 12:29 am
Rockman
They are probably all the same for the K75 & K100. Mine is either slow, or not at all..
i have one similar , slow on right hand side only .
let me work on it , possibly fix it soon ....if nothing comes up Phil .
Don't forget to give him some blinker fluid to go with it.
Rockman wrote:They are probably all the same for the K75 & K100. Mine is either slow, or not at all..
Have you swapped the regular incandescent bulbs in the signals for LEDs? What wattage bulbs are you using if you are using incandescents?
Dai wrote:Don't forget to give him some blinker fluid to go with it.
Razz
Rob  , i would be thinking phil is using all standard equipment.
Rockman
Yes all standard. Checked bulb wattage etc etc. I took the cover off the blinker relay and all looks pretty good in there so I'm thinking a connection further back, or the switches on the handlebars. I have noticed that they work properly sometimes and sometimes they self cancel. TBA I think. For now I wont worry about a new relay.
Possible corroded switch contacts in the rhs ?
Rockman
charlie99 wrote:Possible corroded switch contacts in the rhs ?
Very possible, except in my case it would be both sides. I noticed yesterday that if I push the switch a bit harder it works better sometimes. When I get a chance I'll take them apart and clean the contacts.
