1Back to top Go down   WANTED - Flasher Relay (89 RT) Empty WANTED - Flasher Relay (89 RT) Mon Oct 13, 2014 8:40 am
Just spent half the day troubleshooting and looks like my flasher relay is done. Keeps blowing #7 fuse.
Had a quick look on ebay but could'nt see any there.
Anyone have a unit they can sell?
 WANTED - Flasher Relay (89 RT) Austra12    Fuel:  95 Octane
2Back to top Go down   WANTED - Flasher Relay (89 RT) Empty Re: WANTED - Flasher Relay (89 RT) Mon Oct 13, 2014 8:45 am
can also happen with a shorted globe or holder ... or wiring on the way back to the rear ...have seen a couple with wiring trapped under the rear suspension unit bolts and washers along the frame, tightened up on the wiring .
best advice I could give is to undo them all and test for a short circuit somewhere ?
good luck
3Back to top Go down   WANTED - Flasher Relay (89 RT) Empty Re: WANTED - Flasher Relay (89 RT) Mon Oct 13, 2014 8:59 am
Thanks charlie
I've removed all the bulbs (they're all ok). Checked all the wiring front to back and back into the electrical box. All seems to be ok.
When I plug the flasher relay in, #7 fuse blows.
