Go to page : Previous  1, 2, 3, 4, 5  Next
View previous topic View next topic Go down  Message [Page 2 of 5]
51Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Thu Apr 15, 2021 10:46 pm
That's why I recommended riding Route 100. Cool
52Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Fri Apr 16, 2021 9:10 am
It was an excellent tip!
53Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sat Apr 17, 2021 4:58 am
Danish biker
Danish biker
Thanks for all your replies.
As fare as I know the part that came out the right side of the engine (and also blew a hole up the top), is a part of the “thing”, that holds the “piston” (might be called something else) that runs up and down in the cylinder.
I’ll be riding until the sprang clutch makes trouble again. Then I’ll do the following:
1. Do the WD40 job, this time using no flammable carb cleaner.
2. Let out 1 liter of oil and put in 1 liter kerosene or a engine cleaner solvent.
3. Run (not ride) the bike for 15 minutes.
4. Drain all oil and remove oil filter.
5. The consider the advice about truck diesel oil and maybe do this job.
6. Try to find yet another oil (look at recommendations in this post).
7. Wait for the sprang clutch to fail again Rolling Eyes
You have enemies? Good. That means you've stood up for something, sometime in your life.
-Sir Winston Churchill
54Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Sprag Sat Apr 17, 2021 5:45 am
daveyson
daveyson
I googled plejlstang and got con rod, which matches your description. By the way, which number cylinder did it pop out of?
Your plan sounds good.
Good luck.
 ~120,000 km
55Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sat Apr 17, 2021 6:07 am
Danish biker
Danish biker
daveyson wrote:I googled plejlstang and got con rod, which matches your description. By the way, which number cylinder did it pop out of?
Good luck.
Not sure haven’t taken the engine apart yet but looks like it came from the front part. It was shot out in the low end of the cover, between the front and second (from front) cover bolts.
56Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun Apr 18, 2021 4:32 am
Danish biker
Danish biker
Apparently I can post pictures if I don’t chose the web version so here we go
Starter or Sprag clutch failure  - Page 2 68abce10
57Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun Apr 18, 2021 4:33 am
Danish biker
Danish biker
Starter or Sprag clutch failure  - Page 2 F1110410
58Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun Apr 18, 2021 4:37 am
Danish biker
Danish biker
It took me a lot of research to get here, still don’t know how I could have managed with out the help from a great Irish guy and a great girl from Holland.
Starter or Sprag clutch failure  - Page 2 7d85b310
59Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun Apr 18, 2021 8:31 am
You are always welcome to what help can be given from a distance my Viking friend. Looking at that damage again there is no way that damage is related to the cleaning fluids used. They would have evaporated/burned off long before you got up to that speed.
The failure looks similar to that on my own K1100RS engine. I bet if you strip it you will find major sings of high speed failure on the crank shaft bearings (shells) causing the crank and piston to interlock and shattering the Con rod to come out the top of the block. Interestingly mine went on number one cyclinder too!
If you do have to replace the sprag clutch you know where to come for help.
You split the gearbox and final drive as before the you can remove the intermediate flange to get at it.
Easy Peary Starter or Sprag clutch failure  - Page 2 8157
Starter or Sprag clutch failure  - Page 2 Ir-log1188....May contain nuts!Starter or Sprag clutch failure  - Page 2 Ir-log11
K75RTP - 1994
60Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun Apr 18, 2021 9:44 am
Danish biker
Danish biker
88 wrote:You are always welcome to what help can be given from a distance my Viking friend.
You are the wizard 👍👍
Without your guidens I would NEVER have accomplished.
Not only did I find a “online” mechanic but also a friend.
61Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon Apr 19, 2021 8:07 am
Danish biker
Danish biker
And here it is:
Starter or Sprag clutch failure  - Page 2 4ec33d10
62Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Sprag Mon Apr 19, 2021 8:15 am
daveyson
daveyson
Bonus, thanks for the pics.
 ~120,000 km
63Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon Apr 19, 2021 12:00 pm
Danish biker wrote:Starter or Sprag clutch failure  - Page 2 F1110410
I thought the crank case vent into the airbox is through the Z pipe??
Long time since i have seen a photo like that.
64Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon Apr 19, 2021 12:06 pm
Danish biker
Danish biker
I’m glad I’ve lived a life with a challenging job, and along with this alway been a wild boy and therefor been in many unpleasant situations. It was a “blast” but luckily I kept my head cold and only thought about getting safe to the emergency lane. With this been said I could have been with out this experience 😜
65Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue Apr 20, 2021 10:25 am
tinyspuds
tinyspuds
I guess we can’t talk about bullet proof bottom ends anymore?
66Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue Apr 20, 2021 11:54 am
When it comes to blasts, this event might just have been a case of what goes around comes aroundSmile
67Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed Apr 21, 2021 3:10 pm
Danish biker
Danish biker
Laitch wrote:When it comes to blasts, this event might just have been a case of what goes around comes aroundSmile
The only bad side of this story is that I after many thoughts and great help from my Irish friend, I got kind of high and said to myself:
GREAT now I’m getting a engine, where the sprang clutch isn’t fuc... up.
You should have heard me and seen my face, when the sprang clutch failed to engage twice on my first ride.
68Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed Apr 21, 2021 3:20 pm
Danish biker wrote:
Laitch wrote:You should have . . .  seen my face, when the sprang clutch failed to engage twice on my first ride.
Now that you know how to post photos, don't miss the next opportunity. Use a selfie stick, too. Smile
69Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed Apr 21, 2021 3:21 pm
Danish biker wrote:You should have . . .  seen my face, when the sprang clutch failed to engage twice on my first ride.
70Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed Apr 21, 2021 3:26 pm
Danish biker
Danish biker
Starter or Sprag clutch failure  - Page 2 A56bd710
71Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Sprag clutch sticking Mon Apr 26, 2021 9:55 am
Kr4mo
Kr4mo
daveyson wrote:When you say the former owner claimed the sprag is OK, that made me think it's second hand. Even a new one that slips a lot will soon have more wear than normal.
You have a few options now to consider. I'd consider the easy ones first, that don't require dismantling the engine.
I have heard of people using a product like Rislone to clean the system and end this problem.  I have used it in other vehicles to free up sticky lifters.  Add the amount recommended to your oil and run the bike for a couple hundred miles then change the oil.  You can push/bump start your bike if needed to start and run it for this.
72Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Still Sprag Clutch problems Sun May 23, 2021 7:02 am
Danish biker
Danish biker
I’m back Cool
Page up and down has been postet about the fact that some brick owners like me have a sprang clutch issue.
The clutch doesn’t engage, but spins and spins and spins. You can get it to engage by jerking the bike forward and especially back in 2. gear. Or you can do the WD40 job.
It is clear to me that if I do a oil change the problem will disappear for about 1.000 km.
So I’m researching the “choice of oil” but only from a “I got Sprang clutch problems” point of view.
I’ve been told I should stop listening to all the advice about semi- or full synthetic oil, and shift to a mineral oil like Motul 4T 3000 20W50. Someone on this forum had same problem as I’m facing, and shiftet to this oil and the problem went away. Obviously I’m going to try this oil in the near future, how ever I just changed oil (Spectro 4 SAE 20W50) and filter and cleaned the engine with a “solvent” running in the oil for 20 minutes before oil change so I’ll be good to go for the next 1.000 km or so.
My question to the experts is:
What oil (if any) did (does) BMW recommend for a 1992 K1100 RS. Is it a mineral, a semi synthetic or a full synthetic?
73Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 7:47 am
moriarti
moriarti
Hi D/B,With respect your question should be, What oil will safely lubricate the engine and at the same time cure Sprag Clutch problem. Answer,MINERAL DEISEL ENGINE OIL. WHY?? Because it contains more cleaning agents,Regular oil changes with this oil WILL cure the problem of Sticking Sprag Clutch. Very Happy
74Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 9:03 am
Danish biker
Danish biker
moriarti wrote:Hi D/B,With respect your question should be, What oil will safely lubricate the engine and at the same time cure Sprag Clutch problem. Very Happy
With evne more respect 😇 I though that was obvious 😀
So why would someone use mineral Motul 4T 3000 20W50? As fare as I can read it is for a wet clutch???
If I’m actually going mineral shouldn’t I go Full Monty and find one for a dry clutch?
And obviously one that lubricates the whole engine etc.?
75Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 9:25 am
moriarti
moriarti
Too many choices on the market, scratch so i use what i know works that way problems are avoided  Very Happy Very Happy   lol!
76Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 9:58 am
Danish biker wrote:If I’m actually going mineral shouldn’t I go Full Monty and find one for a dry clutch?
All auto and truck engine oils lubricate the whole engine and work in vehicles with dry clutches. Take your helmet and some canteens to the base's garage to collect some from there.
77Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 10:08 am
I used Shell HX5 10W 40 all year round and have recently changed to Penrite fully Synthetic at the same weight, both performed quite well and I have never had the sprag clutch problem on any of the Ks I owned or serviced. There are quite a few here who have tried the diesel engine oil with varying degrees of success, I have not used it mainly because the need has never arisen, however there is one here who berated me for being stupid and using but you will find out who he is if he wishes to chime in and tell us all just how smart he is. Very Happy
78Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 11:09 am
Danish biker
Danish biker
moriarti wrote:Too many choices on the market, scratch so i use what i know works that way problems are avoided  Very Happy Very Happy   lol!
So the $100.000 question that remains to be answered is:
“What oil do you use?” Cool
79Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 11:12 am
Danish biker
Danish biker
Laitch wrote:All auto and truck engine oils lubricate the whole engine and work in vehicles with dry clutches. Take your helmet and some canteens to the base's garage to collect some from there.
I hear you brother. How ever I’ve been through many oils, how ever not minerals.
I’m not sure I’m ready to actually use a Diesel engine oil, how ever a mineral oil for a bike is my next move. Just trying to get some good pointers.
80Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 11:14 am
Danish biker
Danish biker
RicK G wrote:and tell us all just how smart he is. Very Happy
 In any other subject that could sound like me 😎
81Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 11:19 am
Danish biker wrote:I hear you brother.
Starter or Sprag clutch failure  - Page 2 447221
82Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Sun May 23, 2021 7:26 pm
Danish biker wrote:I’m back Cool
I am using that Motul oil and its great, problem disappeared and it meets the requirements for a K engine.
Last edited by Arlina on Mon May 24, 2021 4:29 am; edited 1 time in total (Reason for editing : Separated the answer out of the quote.)
83Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon May 24, 2021 4:23 am
moriarti
moriarti
Comma XFMOTIG X FLOW 20/50   OR TripleQX 15/40  Smile
84Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon May 24, 2021 6:02 am
Danish biker
Danish biker
Our mutual friend told me so.  Cool Cool He just didn’t say who Olaf was. Know I know I’m definitely going for the Motul👍👍👍
85Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon May 24, 2021 3:44 pm
I have merged these two threads because, well, they're the same thing; a continuation of information and easier to locate for those interested, not an entirely new thread.
study
86Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Mon May 24, 2021 6:50 pm
I used Shell Rotella T6 15w40 for a couple years after having some sprag issues. Cleared the problem right up and it never came back.
K bikes have dry clutches so you can use any motor oil in them. No need to use special motorcycle oil that has special friction modifiers to prevent slippage in wet clutches.
87Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 12:13 pm
Danish biker
Danish biker
Two Wheels Better wrote:I have merged these two threads because, well, they're the same thing; a continuation of information and easier to locate for those interested, not an entirely new thread.
study
Thanks my bad
88Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 12:24 pm
Danish biker
Danish biker
Ok this is point for point since Saturday
1. I did put cleaningliquid in my engine Saturday. Left it running with a bit of gas like recommended, for 20 minutes.
2. I drained the oil and took out the filter.
3. New oil and filter in. The oil was the Chris Harris recommended full synthetic Spectro 4 SAE 20w50 (that is what I could get and I needed the bike today).
4. I started it 2-3 times to get the oil level correct after doing the above mentioned.
5. Went to work this morning (14 km ride). No problems.
6. I went home from work to my local town (17 km) where I had to do stuff. No problems.
7. After doing stuff I got on the bike to ride home. The Sprag clutch didn’t engage. Just spinning.
8. Put the bike in 2. gear backed and made a drop out on the clutch and hit the starter. The bike started.
So with a engine cleaning and new oil this shouldn’t happen?? I road 800 km with out the engine cleaning, after last oil change (still Spectro 4) with out problems and the weather is warmer now???
So either it’s not the oil or the oil is simply too thin/slippery/“or what ever”.
Give me your best shot???
PS I ordered 5 liter MPM high Zinc 20w50 (and a new filter) since this is what Olaf recommended. So when it arrives I’ll do the engine cleaner again. And new filter and then the zink oil. If the sprag fails again I know for sure it’s not the oil.
First poring away 3,5 l of expensive Spectro oil after only 800 km. Now 3,5 l more after only 31 km (plus 2 filters), and 2 x experience engine cleaner……..I know I don’t need to clean the engine again after only 31 km, but I’m not leaving anything untried 😥😥😥
PS it’s ok to ask about “doing stuff” 😂
89Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 12:42 pm
Leave the filter for a bit and just change the oil.
90Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 1:08 pm
Danish biker wrote:So with a engine cleaning and new oil this shouldn’t happen??
Most of the engine can be clean but the sprag clutch assembly can still be so clogged with residue—or defective in other ways—that cleaning products only result in the kind of unreliable performance that you are experiencing. If Olaf's recommendation doesn't result in reliable performance, you can keep trying one dosage after another or the application of other products. If none of them increase the reliability of the clutch, it should be removed, inspected, hand-cleaned, sprags and/or springs replaced where necessary then reinstalled, like in Alby's thread here about this problem.
91Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 1:27 pm
moriarti
moriarti
To keep costs down and get best results give the engine a DIESEL FLUSH, If that  doesn't work Strip down required.
92Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 2:15 pm
Danish biker
Danish biker
moriarti wrote:To keep costs down and get best results give the engine a DIESEL FLUSH, If that  doesn't work Strip down required.
And DIESEL FLUSH being???
Some say: “Put in 3,5 l Diesel engine oil and ride for a while (what is a while?)!”
Some say: “No no only 1 l of Diesel engine oil, and leave your remaining 2,5 l oil and ride for a while (what is a while?)!”
I really need a no BS step by step recommendation since I’m so very confused.
93Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 2:46 pm
moriarti
moriarti
OK Don't Panic System A. Drain all engine oil refill to max with DIESEL FUEL. Remove spark plugs, spin engine 10/20 seconds, repeat a few times, over say 15/20 minutes remember you are trying to WASH the sprag clean. Now drain engine and mix engine oil with diesel fuel 50/50 fill to max replace plugs run engine up to 1500rpm until fan kicks in stop engine wait 20 min, repeat 3/4 times. Drain engine change filter fill with new oil .Should problem reoccur grab your spanners Very Happy
No B/S just years of experience ,
PS You can use the old engine oil to make the mix that you have to keep cost down
PPS PM me if you need any more info
94Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 3:04 pm
Danish biker
Danish biker
moriarti wrote:OK Don't Panic System A. Drain all engine oil refill to max with DIESEL FUEL. Remove spark plugs, spin engine 10/20 seconds, repeat a few times, over say 15/20 minutes remember you are trying to WASH the sprag clean. Now drain engine and mix engine oil with diesel fuel 50/50 fill to max replace plugs run engine up to 1500rpm until fan kicks in stop engine wait 20 min, repeat 3/4 times. Drain engine change filter fill with new oil .Should problem reoccur grab your spanners Very Happy
No B/S just years of experiance ,
Ok so NOT Diesel engine Oil but diesel fuel (what you buy at a gas station and makes your diesel car move/run)?
Do I need to take out the spark plugs or is it enough to take off the spark plug caps??? If “remove”, why? Compared to just taking off the caps?…….only asking because I need to know why I’m doing what I’m doing 😀
“Spin engine” 10/20 seconds”. Meaning press the starter button, but engine won’t start because the spark plugs (or caps) are off?
“Fill to max”? So over the red dot on the glass where you check oil level or “only” up to the red dot?
95Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Tue May 25, 2021 3:26 pm
moriarti
moriarti
Yes DIESEL FUEL from gas station, YES remove spark plugs, allows engine to spin faster and is less stressful on starter. Engine must NOT start/run with pure diesel in the oil system OK. YES use starter button to spin engine over. FILL to ABOVE red dot or measure 5ltr of mix. Very Happy
96Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed May 26, 2021 12:57 pm
Danish biker
Danish biker
Ok I drained the oil
Took out the spark plugs
Filled in a lot of diesel fuel
Hit the starter for 15 seconds 4 times during 30 minutes
Put in the spark plugs
Drained the diesel fuel
Mixed half engine oil and diesel fuel and filled the bike
Started the bike and left it running at about 1500 rpm until the fan started
Turned off the bike and waited for 20 minutes
Tried to start the bike but the sprag clutch didn’t engage WHY THE F… WOULD IT NOT?????
Put the bike in 3. gear on the center stand and jerked the wheel back. Hit the starter and it started.
Turned it off when the fan started.
Did it again and now I’m waiting for 4. and last run until fan starts then drain diesel fuel and oil
Take out filter and replace
Put in the “Zink car oil”.
But my hopes are not up in any way, since the sprag clutch didn’t engage after engine being soaked in diesel fuel and one start with half diesel fuel and engine oil
I’m a bit like: Crap
Starter or Sprag clutch failure  - Page 2 D21b5210
97Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed May 26, 2021 1:58 pm
moriarti
moriarti
Starter or Sprag clutch failure  - Page 2 61740 Starter or Sprag clutch failure  - Page 2 61740 Starter or Sprag clutch failure  - Page 2 61740 OK  you tried your best time to move on and dismantle the bike.
You will find all the help you need on the Forum, Good Luck  Smile
98Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed May 26, 2021 2:32 pm
Danish biker wrote:I’m a bit like: Crap
You have a nice garage, anyway. What's the dog—a fluffy Pembroke Corgi? If that's you in the photo, what are you drinking after a few hours saturated with diesel and diesel oil?
99Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed May 26, 2021 3:52 pm
Danish biker
Danish biker
The dog is a Papillon (butterfly), called that because the ears looks like butterfly wings. I also have a Labrador (formula 1).
The beer is a Grimbergen Double Ambrèe. And yes it’s me.
My “garage” which we actually call the “horticulture” is ok after I made a new floor (it was earlier loos bricks and dirt).
100Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed May 26, 2021 3:54 pm
Danish biker
Danish biker
moriarti wrote:Starter or Sprag clutch failure  - Page 2 61740 Starter or Sprag clutch failure  - Page 2 61740 Starter or Sprag clutch failure  - Page 2 61740 OK  you tried your best time to move on and dismantle the bike.
Maybe go to Germany or Holland and buy a bike with less km on the clock and take the engine and put on my own frame.
Oh well I did the job and the new oil and filter is on, so I’ll see how it goes.
Or maybe take off the engine and take it to a BMW garage and have them replace the Sprag clutch.
But can I actually buy a new Sprag clutch?
101Back to top Go down   Starter or Sprag clutch failure  - Page 2 Empty Re: Starter or Sprag clutch failure Wed May 26, 2021 5:44 pm
No workshop will touch the bike because it's too old. Getting to the sprag clutch is a ballsache because you have to dismantle the bike but it's a relatively easy job. When you take the idler gear/sprag clutch assembly apart, do it in a clean bucket because the sprag has 12 small springs in it that will do their best to disappear out of sight. Sprag clutches are still easily available:
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=10&M=40&Ct=CA&SbCt=BA_10_40_CA_20&spPage=2
My bet is that yours just needs a really good clean. I had a similar problem a few years back and I did get a lot of dirt out of the sprag; I've had no problems for the last 70,000 miles / 112,000 Kms.
View previous topic View next topic Back to top  Message [Page 2 of 5]
