201 Re: Starter or Sprag clutch failure Fri Jul 23, 2021 5:35 pm
Danish biker
Point-Seven-five wrote:The sprag locks onto the smooth part of #9.
The friction between the sprag cams and the smooth part of #9 cause them to lock onto the smooth surface. They grip the smooth part the same way the wheels of a train engine grip the rails under it. Because of the way they are shaped, the more friction there is the harder they grip. Once the engine starts the sprag is moving faster than the #9 gear and the cams release.
Have you ever seen the type of door stop that flips down and holds the door? The harder you pull on the door the harder it grips on the floor to hold the door open. The sprag works on the same principle. Each one of the cams in the sprag is like that door stop.
Sorry for my total ignorens
And Viking (I don’t need no BS)
Do the teeth on my picture in last post, with the 3 red arrows lock on the blue arrow or the red arrow part on the drawing??????
And i ask in this rude no BS way, because I just don’t understand many of the technical explanations (sorry my bad).
But keep it KISS. Blue arrow or red arrow?????
