Number of posts : 11701
the auxilary connector in the fuse box has high beam , switched power , low beam too if i remember, and a ground wire , which should make adding relay control of aux lights easy , i say relay control because in most circumstances the high low switch is usually a troublesome issue that will happen in time , if it hasnt already become intermittent
good luck
