1Back to top Go down   These Two Connectors? Empty These Two Connectors? Fri Aug 26, 2022 7:47 pm
bmwk100rs
bmwk100rs
I either failed to label them or they we were not originally connected to anything. Does anyone know what these two connectors next to the left-turn signal and horn are supposed to be connected to? TIA!
These Two Connectors? This2c10
2Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 8:35 pm
Parking light?
3Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 8:45 pm
bmwk100rs
bmwk100rs
Point-Seven-five wrote:Parking light?
Nope, parking light is working. Any other guest?
4Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 8:59 pm
Second horn?  Those are the only things under the fairing that I know of that use that style connector.
5Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 9:30 pm
Looks to me like a Grey/White and Brown wires which is the colours used for the park light. I cant find anything else in that area that uses those colours.
6Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 9:38 pm
What color stripe is on that white wire?
7Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 9:47 pm
bmwk100rs
bmwk100rs
Sorry Point-Seven-five, but it seems that you were correct the first time. I missed to notice that one of the wires is actually white/grey as Rick G pointed out. It's indeed white/gray. However, the parking light is working. Are those connectors suppose to be plugged into an indicator or is that park lamp inside the original headlight?
These Two Connectors? Img_3020
8Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 9:51 pm
What is connected to the parking light?
9Back to top Go down   These Two Connectors? Empty Re: These Two Connectors? Fri Aug 26, 2022 10:05 pm
bmwk100rs
bmwk100rs
Point-Seven-five wrote:What is connected to the parking light?
Sorry, I figured this out. I thought by "parking light", it meant the tail light. I can see now that the bike originally had a front parking bulb, which I am not longer using with the new headlight. My apologies for not noticing that before posting. Thank you all for helping me with this. You guys are invaluable resources to this forum and to newbies like me. Cheers!
These Two Connectors? Img_3021
