51 Re: cranking engine Sun Nov 22, 2020 6:41 am
If you've got this far then yes, Moriati's right. Do it.
Go to page : 1, 2
You were probably recollecting Lars, the drill thrall. I won't ask why.Dai wrote:I just completely misread that as in 'how the hell can a compression test be inside a disused slave?'. Don't ask . . .
Reason: Distracted driving remedy. Saab was the first of automakers to limit distracted drivers from endangering others. Habitual smokers, pastry eaters and beverage drinkers discovered that the ignition switch wouldn't function with all the crud that accumulated in it.redrockmania wrote: Location of the ignition switch on the centre console was a departure from the then usual location of the switch on the side of the steering column. Reason: Safety.
Go to page : 1, 2
Similar topics
