Number of posts : 7963
I seem now to hit 20-25,000 miles a year.
Oils have changed so much since Ks were designed.
I don't put mineral oil in anything. While it works its got to be changed a lot more frequently because it doesn't have long life. Diesel cars in 80s were change oil 2,000 miles although that was partly to do with fuel quality. My Honda fours back in the 70s were change at 2,000 miles running on mineral oil because that's all there was. Even then people fought over whether you used Castrol GTX or Duckhams.
Semi and fully synthetic oils last much longer and retain their quality better. For the extended life you need fully synthetic and then you can go for very long service intervals. This works for fleet users because it extended costly service intervals.
I don't get hung up on the brand name, love those debates where 'mine goes 0.002mph faster with X brand or I get 0.5 miles extra per tank of fuel. Reality is none of us will notice the difference and it may be the case its actually the same oil with a different name on the container. You can go to Lidl, Aldi, Halfords or many more and buy oil that meets the spec.
Manufacturing tolerances have improved and improved engine management has allowed closer tolerances meaning thinner oils are needed hence 5 and 10W for cold starts. On old school, old or well worn engines 5W may struggle to get up oil pressure. The upper 30 may be too thin when engine is hot and clearances open up a little, in extreme hot you will see 50W specd.
There are endless heated discussions on oils but while mineral oil will work bottom line is it has been superceded by improved technology.
1971 Yamaha 125 YAS-1
