1 K100RS Injector Cleaning and Internal Filter Replacement Wed Nov 25, 2020 11:52 pm
AUBIEBMW
I was able to clean the injectors based off a neat method found on web, parts available at Autozone and Home Depot. New 9V battery and a momentary switch pulsing by thump worked perfectly. Fuel Injector Clean
Then I read up on rebuild kits. When I looked into the stock filter on each individual injector, it appeared as if there was no bottom to the screen mesh filter. After removing the stock filters, sure enough the screen mesh was open at the bottom. The new replacement filters appear to have finer mesh than original stock screens.
Two questions for the forum members:
1) Has anyone had any problems with what appears to be the smaller mesh screens with plastic frame?
2) Has anyone seen this open bottom screen before? Could it have been intentionally broken through to improve fuel flow or something weird like that?
Thanks for all help and advice.
Jim
Jim
