Number of posts : 7967
daveyson wrote:I think the starter motor is spinning the wrong way.
From your video, it looks to me like the idler gear is turning clockwise. See in the picture from Laitch it should be turning anti clockwise. The post by Olaf has a link how to fix it.
The earlier posts say the sprag clutch only spins free in one direction meaning it seems to be performing correctly. The usual issue is that it can spin in both directions.
I see only 2 possibly issues then, one is that the sprag clutch is installed
wrong
way round [I don't think that's possible] or far more likely starter is assembled
wrong
way round and that's very easily done. Many have done that. Despite the manufacturing marks on the body its easy to do this and making marks as you disassemble can be problematic if you clean it up after to look like ne
w.
For bench test the live goes on to the starter electrical connection, the ground/earth is through the body into the engine and via the casing back to the battery through the earth strap lug on the gear box. I imagine this part is correct.
1971 Yamaha 125 YAS-1
