Go to page : 1, 2
52 Re: 1983 K100 RS Project - back to the 80’s Fri Feb 07, 2020 5:52 am
I just used Rustoleum satin black on mine and it hasn't been heat effected yet. So heat proof will definitely stick.
53 Re: 1983 K100 RS Project - back to the 80’s Fri Feb 07, 2020 7:25 am
Brilliant paint but not sure how it works. Used it on part of the frame of my K100RT in 2013 and still looks like new. Used in on my heat shield and not so good but I used bike in winter and there is salt ends up trapped under it. My RS got a new heat shield last summer and it wasn't in great shape when I swapped it this time for another brand new one. Might put Rustoleum on the now old one as it came off in one piece.MartinW wrote:I just used Rustoleum satin black on mine and it hasn't been heat effected yet. So heat proof will definitely stick.
I love the disc, mine was one of those too ....while you are there with that heat gun crack out the two bolts holding the disc on and put them back with anti seize.....
1971 Yamaha 125 YAS-1
54 Another job completed, Callipers Thu Feb 13, 2020 5:10 am
StandardK
Another job done, all 3 callipers overhauled & refitted. Not without some drama, the overhaul kits were bought from Motobins that quoted a kit (Ariete branded) to suit early K100 and some R series, so without any thought I ordered the 3 sets. HOWEVER on rebuilding the first calliper the pistons/pots refused to pass through the new seals, at first glance the old & new seals looked identical size wise - both to suit 38mm pistons, however without a set of digital verniers to check it was impossible to tell if there was a difference in seal profile size. The following corresponding OEM number is quoted by Motobins for the Ariete overhaul kits, however after researching that BMW number it appears it is ONLY for various R series:
34 21 1 237 234
So, after scratching my head (and feeling a tad cranky) 3 more sets of overhaul kits were ordered, this time genuine Brembo kits with the following corresponding OEM number:
34 11 2 310 493
Which DOES match the BMW recommendation for the early K’s.....and fit perfectly. My guess is (without measuring with callipers) is that the K100 calliper seal relief is marginally shallower than an R calliper....or is it an Ariete thing? All I know is it is appears to be impossible to use the Ariete kit seals.
You live & learn, to check & check again.
Much better....
New Brembo seal on left, Ariete branded new seal on right....
34 21 1 237 234
34 11 2 310 493
Much better....
55 Re: 1983 K100 RS Project - back to the 80’s Thu Feb 13, 2020 6:35 am
That's the same problem I ran into but I never got to the end of it....now I know. You did it by the book as you saw it, just like I did but the book was wrong.
56 Re: 1983 K100 RS Project - back to the 80’s Thu Feb 13, 2020 4:36 pm
StandardK
Very annoying indeed, serves me right for not checking the OEM numbers I guess.92KK 84WW Olaf wrote:That's the same problem I ran into but I never got to the end of it....now I know. You did it by the book as you saw it, just like I did but the book was wrong.
BTW Motobins have refunded the kits, can’t fault their service in that regard.
57 Nothing exciting update Wed Feb 26, 2020 10:12 pm
StandardK
The rebuild progresses, After all external fuel & vacuum hoses/plugs were replaced, the original injectors had a birthday by being cleaned & tested, all 4 were pretty much in spec surprisingly & flowed pretty much the same, albeit still being full of crap.
On first startup after the external work she still wasn’t too happy until warm and took several hits of the starter, and throttle could not be touched. I was putting off changing the in-tank filter & piping until the tank was painted, but gave myself a slap and pulled the filter....she was shagged, you could barely blow through either way and had a manufacture date of 22/04/03... not to mention the rubber lines perished and swollen. Funnily enough, after the in tank work she started up first hit of the button dead cold. Not enough pressure for a cold start?
The build’s now at the far end, with the brakes to finish off, tyres, battery & fresh paint.
And yes Martin, you’re tuning skills may have to be booked in in the near future
Regards
Dan
Regards
Dan
58 Re: 1983 K100 RS Project - back to the 80’s Wed Feb 26, 2020 10:25 pm
No problems Dan anytime. Are you going to the swap meet?
59 Re: 1983 K100 RS Project - back to the 80’s Wed Feb 26, 2020 10:31 pm
StandardK
I hope so - i’ve pencilled it in, barring anything else coming up I’m keenMartinW wrote:No problems Dan anytime. Are you going to the swap meet?
Dan
61 Re: 1983 K100 RS Project - back to the 80’s Sat Feb 29, 2020 3:47 am
When you get to the seat Mick67 is really good with upholstery he just redid one of my spares. He did a really professional job.
62 Re: 1983 K100 RS Project - back to the 80’s Sat Feb 29, 2020 6:32 am
StandardK
Ok thanks Martin - I think the seat (early pattern with the hand holds) is actually in reasonable nick, but I'll def keep that in mind if it turns out not so.MartinW wrote:When you get to the seat Mick67 is really good with upholstery he just redid one of my spares. He did a really professional job.
Your spare seat turned out great, very impressed. Don't know about the thought of you three playing around with vinyl though - sounds suss
Regards
Dan
63 Re: 1983 K100 RS Project - back to the 80’s Sat Feb 29, 2020 7:14 am
GF Wollongong
It is Mardi Gras night in Sydney
Maybe there was a Brisbane float with space
64 Re: 1983 K100 RS Project - back to the 80’s Sat Feb 29, 2020 3:23 pm
Mmmm there is enough scrap vinyl to add fringes to the seat and my jacket. It might be possible to slip the Brick in amongst the Hardly Ableto riders.
65 Re: 1983 K100 RS Project - back to the 80’s Sat Feb 29, 2020 9:15 pm
Your exhaust isn'tMartinW wrote:Mmmm there is enough scrap vinyl to add fringes to the seat and my jacket. I might be possible to slip the Brick in amongst the Hardly Ableto riders.
66 Re: 1983 K100 RS Project - back to the 80’s Sun Mar 01, 2020 12:25 am
I could tear the sleeves off one of my shirts and I could then add a couple of lick and stick tattoos. The only problem with them is they're off my granddaughter and they're of llamas.
67 Re: 1983 K100 RS Project - back to the 80’s Sun Mar 01, 2020 5:12 am
WOT NO UNICORNS!!!!! (sigh) I dunno. Young people today...
68 Another small update... Fri Mar 20, 2020 2:50 am
StandardK
Still plodding along with the renovation, a before & after shot of her backside -
The rear shock was overhauled by RAD on Brisbane’s southside (thanks for the head’s up Mick & Co), new Avon hoops front & rear, new rear brake reservoir, master cyl overhauled, pretty braided lines front & rear, etc etc
Pretty much now on the home straight - a battery to be purchased, the front master cylinder to be re-kitted (I KNEW it would start bloody weeping the minute the front brakes were bled....) then it’s time to start thinking about paint I guess.
Regards
Dan
Regards
Dan
69 Re: 1983 K100 RS Project - back to the 80’s Fri Mar 20, 2020 5:24 am
70 Re: 1983 K100 RS Project - back to the 80’s Fri Mar 20, 2020 10:03 pm
StandardK
Thanks Martin - I’ve got a kit for this one & the bore looks OK, but will keep in mind for future reference. Def worth thinking about.
Regards
Dan
71 Oh so close.... Wed Apr 22, 2020 3:59 am
StandardK
Greetings all
Lotsa bits back on the K this week after receiving my freshly painted bodywork on Saturday, just the radiator surround mountings & grill to sort out now.
I did have the pleasure of a quick "trial lap" around the block, she appeared to get along quite ok. The fuel tank non- return valve is a noisy little devil when it chimes in though...why didn't i pull the guts of it out when I had the tank apart
Hopefully the next post may just be a "completed!" post.
Regards
Dan
Regards
Dan
72 Re: 1983 K100 RS Project - back to the 80’s Wed Apr 22, 2020 4:18 am
Looking good Dan looking forward to the time when I can view in the flesh.
73 Re: 1983 K100 RS Project - back to the 80’s Wed Apr 22, 2020 5:13 am
Mick67
Love that you've kept it 'stock'...Gee they are good crisp clean lined looking machine..not at all dated....Love em undressed like that!!
Top job - many many k's of fun when we are allowed out again.
K100RS 1984
VIN 0013414
74 1983 K100 RS Project - back to the 80's Wed Apr 22, 2020 6:58 pm
Great work Dan. I reckon you must have done a crash course in polishing with Charlie. Keep up the good work.
Cheers Tom
Cheers Tom
75 Re: 1983 K100 RS Project - back to the 80’s Wed Apr 22, 2020 7:24 pm
Mick do you realise you can no longer win the oldest K bike award if Dan comes along. Dan keep an eye on Mick he might resort to sabotage in order to keep his crown.
76 Re: 1983 K100 RS Project - back to the 80’s Wed Apr 22, 2020 8:15 pm
StandardK
Thanks for the kind comments Gents, looking forward to the first show n tell at the K Klutch.
I’ll swap VIN plates with Mick so as not to de-thrown him, my relic will be then “updated” by a few months/years too...
In saying that, Brisbane Ian’s Nekkid (basic) K100 is pretty bloody early, 08/83....couldn’t be too many K’s over here earlier than that
Regards
Dan
Regards
Dan
77 Re: 1983 K100 RS Project - back to the 80’s Wed Apr 22, 2020 9:42 pm
nice result Dan
lets hope the radiator shield comes together soon
79 Re: 1983 K100 RS Project - back to the 80’s Sun May 03, 2020 1:14 am
Looking really good Dan, looking forward to a meet up.
80 Re: 1983 K100 RS Project - back to the 80’s Sun May 03, 2020 1:35 am
volador
Bonzer!
1984 K100RS 1991 K100RS Reap The Wild Wind... Ever Commute Is An Adventure
81 Re: 1983 K100 RS Project - back to the 80’s Tue May 12, 2020 6:44 pm
Oooooh Nice result!
88....May contain nuts!
K75RTP - 1994
82 Re: 1983 K100 RS Project - back to the 80’s Tue May 12, 2020 8:11 pm
Basic2
Very neat!
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
83 Still tinkering.... Tue Jul 28, 2020 3:44 am
StandardK
Is a project ever really finished? Still tinkering at this end....apologies for probably boring you all
The low RS bars position was starting to niggle me, with Martin’s help & some locally sourced upper K clamps the bars have been raised a little -
I’ve also managed to source a VERY cheap OEM toolkit within Oz which required a decent clean up, I think it scrubbed up OK, luckily it was 95% complete with the shock & spark plug tools -
Oh, and refitted the First Aid kit from 1983 that was found in the filthy rear tail upon stripdown....I think I need help
And a recent winter’s evening urban “arty” pic too, why not...
Regards
Dan
Regards
Dan
Last edited by StandardK on Tue Jul 28, 2020 3:48 am; edited 1 time in total (Reason for editing : Spelling dumkopf)
84 Re: 1983 K100 RS Project - back to the 80’s Tue Jul 28, 2020 4:54 am
Looking good Dan, I've got my original very much out of date first aid kit stashed in a cupboard. Now that you have your very own tool kit and first aid kit, does that mean that you can venture out overnight.
85 Re: 1983 K100 RS Project - back to the 80’s Tue Jul 28, 2020 5:13 am
Very nice job
Just a detail;
The wiring to the headlight and cluster is routed wrong, it goes under the bottom yoke in the bottom of the mask.
Just a detail;
K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
86 Re: 1983 K100 RS Project - back to the 80’s Tue Jul 28, 2020 6:04 am
StandardK
MartinW wrote:Looking good Dan, I've got my original very much out of date first aid kit stashed in a cupboard. Now that you have your very own tool kit and first aid kit, does that mean that you can venture out overnight.
Touché mein herr....
Regards
Dan
87 Re: 1983 K100 RS Project - back to the 80’s Tue Jul 28, 2020 6:09 am
StandardK
Arlina wrote:Very nice job
Just a detail;
Ah, good spotting.... I did try to reroute the headlight harness as per the Basic K100 spec, but it seemed like the RS harness was shorter & it was too stretched...may have been me of course, perhaps if I had cut every ziptie in the harness I may have had a bit more room...oh well, next time...
Regards
Dan
88 Latest Mods Sun Oct 10, 2021 1:09 am
StandardK
Finally got around to fitting the RT/LT bars & pad I sourced from kmodelbeamerbits. As well as the bars the old girl got all 3 cables replaced (which I should've really done a while back) and a longer front master cylinder line down to the steering stem.
Early days but liking the comfier ergos so far.
Regards
Dan
Regards
Dan
Regards
Dan
89 Re: 1983 K100 RS Project - back to the 80’s Sun Oct 10, 2021 2:49 am
Get your motor runnin, head out on the highway try, to void dementia. Tassels and fingerless gloves are in your future.
90 Re: 1983 K100 RS Project - back to the 80’s Sun Oct 10, 2021 3:59 am
StandardK
.....and saddlebags too?MartinW wrote:Get your motor runnin, head out on the highway try, to void dementia. Tassels and fingerless gloves are in your future.
Regards
Dan
91 Re: 1983 K100 RS Project - back to the 80’s Sun Oct 10, 2021 7:27 am
Jamie64
Looks Great Dan
92 Re: 1983 K100 RS Project - back to the 80’s Sun Oct 10, 2021 7:33 am
Nice job
93 Re: 1983 K100 RS Project - back to the 80’s Sun Oct 10, 2021 12:34 pm
RS Rider
Man, that turned out nice! Would like to know your process for cleaning and polishing the aluminum. The paint job looks amazing as well. Would like to have my RS redone but I'm afraid the cost would be more than the bike is probably worth even though it's in great shape.
A local body shop wanted $600 just to do my black belly pan I got from Flat Racer. Jeez!
94 Re: 1983 K100 RS Project - back to the 80’s Mon Oct 11, 2021 12:49 am
well done Dan
95 Re: 1983 K100 RS Project - back to the 80’s Mon Oct 11, 2021 1:13 am
RS Rider GB777 had really good results using a colour matched can of 2 pack paint. It looked professionally done.
96 Re: 1983 K100 RS Project - back to the 80’s Mon Oct 11, 2021 10:30 pm
StandardK
Hi All, thanks for the kind comments.
RS Rider the aluminium cleaning is via other's members tips on this forum - stainless steel wool, water & sunlight soap, followed by a wipe over with Inox from time to time. Seems to have kept clean so far.
Agree with MartinW, GB777's spray job looked pretty good to me
Regards
Dan
Regards
Dan
Regards
Dan
97 Re: 1983 K100 RS Project - back to the 80’s Tue Oct 12, 2021 12:53 am
RS Rider
Martin,MartinW wrote:RS Rider GB777 had really good results using a colour matched can of 2 pack paint. It looked professionally done.
Would you happen to know what brand he used? I’m thinking about getting RS aerosol from the UK (they do ship to Canada) and then trying that on some of the smaller pieces, such as rad shroud or front fender. The only thing is that I would want the 2K clear which is nasty smelling stuff. I have a garage but it is attached to my townhouse. I don’t know how well spraying that stuff in my garage would go over with my neighbours.
Ideally I would like to find someone that has a set-up at home and would do the work for cash and I would supply the products.
Tom
98 Re: 1983 K100 RS Project - back to the 80’s Tue Oct 12, 2021 1:32 am
RS I'd just PM Gary (GB777) and he'll give you all the information, you'll need. I do know he used a mask and a disposable suit.
Regards Martin
Regards Martin
99 Re: 1983 K100 RS Project - back to the 80’s Tue Oct 12, 2021 2:06 am
In the past, I have done the prep and base coat on my parts and then taken them to a professional collision shop for the clear coat. If you ask around, you should be able to find a shop that will shoot the clear for a reasonable price.
The big part of any paint job is the time that goes into the prep, the actual work isn't rocket surgery if you take your time and don't cut corners. By doing the prep you can save as much as 80% of the cost of the paint job.
The only important part is to shoot your base coat within a day or so of when the shop can do the clear. This is to get the best bond between the coatings. You can do everything up to the primer and then have the shop let you know when they can shoot the clear. Then do your base coat and get the parts to the shop for the clear.
I had a local shop clear all the painted parts for a K1100RS for $150 and a dozen donuts for the shop crew. The finish was better than I could have done with my Harbor Freight gun and didn't require any more than an hour or so of buffing to look fantastic. It's amazing how well a 40cfm compressor and a $300 gun in the hands of someone who shoots 5 days a week can apply paint.
Go to page : 1, 2
Similar topics
