1Back to top Go down   1983 K100 Money Pit Empty 1983 K100 Money Pit Fri Nov 11, 2022 8:42 am
TJ
TJ
Not entirely sure where I'm going with this, but I can tell already that this bike is going to take a lot more work than the K75S ever has. I'm not very mechanically minded but eager to expand my knowledge and understanding and I guess hoping for help where its available.
Decided to start the clean up by getting the slipstream deflector off during my lunchbreak and even that is not going well.  Front bolts were a bit corroded but did come off allowing me to unclip the indicators and get the front off. Took it back inside to take the defector off and clean it, but bolts are rusted to the nuts and the heads rounded. Can't seem to get the damn thing off without drilling it. Which is more than I can manage in my lunchbreak at work without a drill. Need to also go get some replacement nuts and bolts it seems.
Anyway great start 🤨
2Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Fri Nov 11, 2022 5:43 pm
TJ
TJ
Today has not been a success. Front came home with me and bike stayed behind.1983 K100 Money Pit 20221113
3Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sat Nov 12, 2022 8:09 am
TJ
TJ
Okay need some advice please. Managed to drill out the corroded deflector bolts and accidentally drilled my palm too when it went through unexpectedly 😫. Got the front back on anyway and it's looking much nicer with fresh steel I got from the marine yard. Managed to ride it back home finally and its at least moving. The sitting position isn't as nice as my K75s though. Hunched further forward isn't so nice for me with a bad back. I presume the 75 has longer handlebars? Think I once heard that there can be issues with the length of cables etc when trying to put bigger bars on... anyone with experience able to let me know what to expect if I switch them?
4Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sat Nov 12, 2022 8:39 pm
All depends which model you are talking about.  The 75C along with the RT has longer bars and cables.  The 75S/100RS will be the same size bars and cables which should be similar to the '83 K100.  Then there is the oddball 75T which can have the large perspex fairing which I think has the longer bars as well.
C bars are like hens teeth nowadays although there is an alternative.  Munich motorcycles here in Oz stocks LUCAS Touring Low handlebars (22mm) which are a suitable style.  Recently we fitted a set to a K100 Basic with the longer cables.  You will also need the longer upper front brake line to the RH switchgear, if the front brake line is routed through the steering head.
Also you may be able to adjust the handles bars so they are higher.  Twisting the bars slightly upwards or fitting spacers to the bar mounting points may do the trick.
Hope this helps.
5Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sat Nov 12, 2022 9:11 pm
The K75T has C bars. It's just a K75C with a K100 headlight surround and the big handlebar mounted windscreen. BMW NA did that to make it a better K75 for touring before the K75RT came out in 1990.
A K75S has a different throttle cable and choke cables than the C or standard but has the same 1510mm clutch cable as the C and standard.
All of the RT/LT models have longer cables than came on the non-RT/LT models.
Flanders also makes 22mm handlebars.
6Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 3:45 am
TJ
TJ
Thank you so much guys. I thought I'd said so, but if not, the one I was referring to that I find more comfortable is my 1994 K75S, pictured. Just thinking about it, though the chap I purchased that from had said the only two non original BMW parts on it were a taller screen and wider handlebars. Had forgotten about the non original bars until now.
1983 K100 Money Pit Img-20101983 K100 Money Pit Img-2010
7Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 3:54 am
TJ
TJ
Oh and I guess a picture of the K100 would help too, but I haven't any clear ones right now. Just this. Will revert when I have some that might help with the sort of position I'd prefer
1983 K100 Money Pit 20221114
8Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 10:06 am
TJ wrote: Just thinking about it, though the chap I purchased that from had said the only two non original BMW parts on it were a taller screen and wider handlebars. Had forgotten about the non original bars until now.
Right. That isn't the original S handlebar. It could be a C bar or an RT bar. The cables for an RT bar will work with a C bar but not with an S bar. Measure your bar and compare it with these photos from Max BMW. The upper one is an RT; the lower one is a C.
1983 K100 Money Pit Scree2161983 K100 Money Pit Scree217
9Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 12:33 pm
TJ
TJ
Will do. Based on what you say, thinking it must be an RT bar or something else altogether as when I asked if he'd had to fit new cables he said they all fit as was. Much obliged.
10Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 12:47 pm
TJ
TJ
Guess it might also be worth me asking since this is the first K100 I've ever owned or worked on.... do these look like the original bars too? Absolutely clueless on what it would have rolled out the factory looking like
1983 K100 Money Pit 20221118
1983 K100 Money Pit 20221117
11Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 1:11 pm
Those look like C bars.
12Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 2:14 pm
It's kind of hard to tell from those pics but the upper bend in the second pic looks more like RT bars to me.
C bars:
1983 K100 Money Pit 5KwBc8h
RT bars:
1983 K100 Money Pit TyK6s59
13Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Sun Nov 13, 2022 2:19 pm
1983 K100 Money Pit ICXcEwR
14Back to top Go down   1983 K100 Money Pit Empty Re: 1983 K100 Money Pit Wed Nov 16, 2022 5:05 pm
TJ
TJ
Quick update. Found a decently priced set of RT bars and will look to put in
