StefanMajonez
StefanMajonez
Hi!
I was riding around on some wet asphalt, pressed the rear brake. It worked well, but the moment ABS activated, the brake lever slowly (~1 second) went all the way down.
Now when I press the brake, the lever slowly goes down. My first thought was that I bust a brake line and have a slow leak somewhere, but the brake fluid level stays the same no matter how many times I press it.
I'm posting this here for a sanity check and to make sure what I'm thinking is the problem - the master cylinder seal isn't sealing properly and i
EDIT: Found this, is it a good idea?
Also, fun photos for all to rejoice upon my luck.
Rear brake not working - master cyllinder? LxejvT4
Rear brake not working - master cyllinder? Zzm89bf
Rear brake not working - master cyllinder? OKaPDxg
From what I've read this is non-serviceable and I have to buy a new one.
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
mike d
I would be checking the flexible brake hoses. With age they can suffer internal damage. This may be seen when you apply the brakes as the pipe can swell up like a balloon, but return to normal size when you release the brake.
Mike
StefanMajonez
StefanMajonez
mike d wrote:I would be checking the flexible brake hoses. With age they can suffer internal damage. This may be seen when you apply the brakes as the pipe can swell up like a balloon, but return to normal size when you release the brake.
Mike
Just checked it, no swelling anywhere on the lines.
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
brickrider2
brickrider2
Hi Steven,
You can apparently get a new (Chinese) rear brake pump for very little money.  There have been a few posts on this here in the forum.  Buyers report the quality of the Chinese replacement is very high; they are satisfied with it. Good luck.
1996 K1100LT
StefanMajonez
StefanMajonez
brickrider2 wrote:Hi Steven,
Yeah, I found this thread, and actually found the exact pump they're talking about locally. I'll have it this week probably.
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
