1Back to top Go down   Rear brake master cylinder Empty Rear brake master cylinder Thu 06 Dec 2018, 03:55
Grahame
Grahame
Has anyone successfully fitted a generic rear brake master cylinder to a K75 ABS. If yes I would welcome any advice.
K75RT ABS Mystic Red 1995 7th owner
Engine No.753EA 0294
Chassis No. 03706294134
Mileage 24/12/18  40,399
2Back to top Go down   Rear brake master cylinder Empty Re: Rear brake master cylinder Thu 06 Dec 2018, 04:36
There are a few that have done it and there is no reason for it not working just be sure to get a 12 or 13mm so as to keep the same braking effort.
3Back to top Go down   Rear brake master cylinder Empty Rear brake master cylinder Thu 06 Dec 2018, 05:10
Grahame
Grahame
Thanks Rick, I've ordered one on Ebay, I think it's from China. I'll post my progress once i've got it.
4Back to top Go down   Rear brake master cylinder Empty Re: Rear brake master cylinder Thu 06 Dec 2018, 07:29
https://www.k100-forum.com/t12442-cheap-and-easy-master-cylinder-replacement
Using the forum's search engine is suggested for queries about options. In many cases the subject has been covered extensively and you'll find any number of ideas there. The link above is just one example. I simply typed in 'rear brake master cylinder then followed the trail.
Good luck with your search.
5Back to top Go down   Rear brake master cylinder Empty Re: Rear brake master cylinder Thu 06 Dec 2018, 07:34
There is a thread on replacement master cylinders on Motobrick.com.  I posted photos of my K75RT ABS install on that thread.  So far  I have done the retrofit on two ABS bikes, the RT and a 16v K100RS.  Easy peasy, can be done in an afternoon.
The RT master cylinder now has about 15,000 miles and works perfectly.  K100 only has 2,500 so far.
http://www.motobrick.com/index.php/topic,9364.25.html
My retrofit starts at reply#29.
6Back to top Go down   Rear brake master cylinder Empty Rear brake master cylinder Thu 06 Dec 2018, 09:59
Grahame
Grahame
Many thanks, that is very helpful. I've ordered exactly the same replacement cylinder so will just copy your method.
7Back to top Go down   Rear brake master cylinder Empty Rear brake master cylinder Mon 24 Dec 2018, 01:15
Grahame
Grahame
Just a quick thank you for help and advice, I followed the method described on the Motobrick site and the new master cylinder seems to be working well. Happy Christmas rendeer
8Back to top Go down   Rear brake master cylinder Empty Re: Rear brake master cylinder Mon 24 Dec 2018, 09:37
That's good news!  Happy Christmas!
