ffbikersa
ffbikersa
Hi,
I need rear brake master zylinder (used) for my K1100RS
Cheers,
Tarik
WTB Rear brake master cylinder 12mm from 10/1988, used BRA58142
A lot of guys are now running Chinese rear master cylinders with great results. Check Aliexpress  they can be had for around $15.00 complete. There are posts on fitting procedures which are not that complicated. See Link http://www.motobrick.com/index.php/topic,9364.msg76252.html#msg76252 or https://www.k100-forum.com/t14939-replacing-rear-master-cylinder-with-a-chineese-one#175459 WARNING do not use the reservoir supply hose that comes with the master cylinder it can degrade and disintergrate.
Last edited by MartinW on Thu Oct 24, 2019 11:51 pm; edited 1 time in total (Reason for editing : Added Warning)
ffbikersa
ffbikersa
MartinW wrote:A lot of guys are now running Chinese rear master cylinders with great results. Check Aliexpress  they can be had for around $15.00 complete. There are posts on fitting procedures which are not that complicated. See Link http://www.motobrick.com/index.php/topic,9364.msg76252.html#msg76252 or https://www.k100-forum.com/t14939-replacing-rear-master-cylinder-with-a-chineese-one#175459 WARNING do not use the reservoir supply hose that comes with the master cylinder it can degrade and disintergrate.
Hello Martin,
Thanks - I will leave it as a last option, before try to trace the original one also on eBay and from Motorworks UK
