1Back to top Go down   Need to kill the killswitch Empty Need to kill the killswitch Mon Apr 08, 2019 1:02 am
Chuckinator
Chuckinator
So my kill-switch/start button is fried. (It's a long story that won't get into at this time)
I am going to use simple push button to use as a start button without a kill switch. I am need to pull the wires from the assembly but I don't know which which wires to connect. I'll get a new assembly later, but for now I am in a pinch and I need to do it this way. I know this is probably super simple for most people, but I get nervous with anything electrical that I am going to do something wrong.Anyone able to draw up a simple digram for me to follow? it would be super helpful.
Need to kill the killswitch Screen10
2Back to top Go down   Need to kill the killswitch Empty Re: Need to kill the killswitch Mon Apr 08, 2019 1:56 am
The start button gets power from one of two sources (black/green wires):
1: Gear indicator in cluster being in neutral
2: Clutch switch when clutch lever is pulled
It outputs 12V to the starter relay via the black/yellow wire.
3Back to top Go down   Need to kill the killswitch Empty Re: Need to kill the killswitch Mon Apr 08, 2019 3:10 am
Chuckinator
Chuckinator
I see the wires you speak of and I think I see what I need to do. This temp switch will get me home from where I am because I am not going to keep push starting with all my gear and stuff. I'll do a proper repair when I get home. Thank you.
4Back to top Go down   Need to kill the killswitch Empty Re: Need to kill the killswitch Mon Apr 08, 2019 3:14 am
Chuckinator
Chuckinator
The button wires (black/green) will go to new button. The red kill switch lever is blown out of the assembly, so will I need to connect the two kill-switch wires together as well?
5Back to top Go down   Need to kill the killswitch Empty Re: Need to kill the killswitch Mon Apr 08, 2019 4:42 am
This show what needs to be connected to run and what is connected to start, if your wiring colors are the same.
Need to kill the killswitch Screen51
6Back to top Go down   Need to kill the killswitch Empty Re: Need to kill the killswitch Mon Apr 08, 2019 1:55 pm
Chuckinator
Chuckinator
That looks like what I've got. Thank you!
7Back to top Go down   Need to kill the killswitch Empty Re: Need to kill the killswitch Mon Apr 08, 2019 2:03 pm
Chuckinator
Chuckinator
Switch hooked up. Bike started. Time to get on the road and high tail home and get this fixed proper. Thank you for helping me get unstuck.
