1 Kill Switch Sat Jul 10, 2021 12:29 pm
Kjell.Martinn
Hey guys! Was currently riding my bike, after using the kill switch. Suddenly the headlight stop working. And the bike wouldent start. While searching for the problem, ive checked the starter relay, gave it som power and the bike started. It has good ground. And i recently found out that i think it is problem with the Kill Switch itself, it stuck in "kill" så it wont give me the power to start the bike.
No instruments on the bike. I also think that maybe that is some reason to it also. I tried give it som 12v through the instrument wire, and bypassing the kill Switch. And it started just fine?
And still only 12v on the same green cable while the clutch handle is pressed.
Here some pictures of the kill switch, currently only 12v on the cable i marked red.
Some ideas? Maybe some faults in my description here, but maybe some of you guys understand it either way :-)
Thanks again!
Thanks again!
