1Back to top Go down   Kill switch not killing!!! Empty Kill switch not killing!!! Thu May 30, 2019 10:30 am
yamarider
yamarider
Got a 1999 K1100 with modified cable tree (ABS removed). When I switch on ignition, I can start engine regardless of kill switch position. I've checked kill switch itself and it is able to break the circuit. So power must come from somewhere else when kill switch is engaged
Any ideas where to look/trouble shoot/fix this problem?
I'm running out of ideas. Please help...
http://www.yamarider.com
2Back to top Go down   Kill switch not killing!!! Empty Re: Kill switch not killing!!! Thu May 30, 2019 10:38 am
yamarider wrote:I've checked kill switch and it is working.
Would you please clarify? If the engine can be started regardless of the kill switch's position, then the kill switch does not seem to be working.
3Back to top Go down   Kill switch not killing!!! Empty Re: Kill switch not killing!!! Thu May 30, 2019 3:42 pm
yamarider
yamarider
Yes, engine starts regardless of kill switch position. The switch itself is working as intended ie. breaking the circuit that goes to the kill switch on the right hand side handlebar control unit, however power is still flowing on the circuit, regardless if the kill switch is engaged or not. Hence power must come from somewhere else overriding the intend off the kill switch...
Any ideas would be greatly appreciated...
4Back to top Go down   Kill switch not killing!!! Empty Re: Kill switch not killing!!! Thu May 30, 2019 6:08 pm
Lift the fuel tank and check the switch connector block to make sure no-one has jumped the green and green/yellow wires. The othe place this could have been done is in the relay box: load shed relay pin 86 to fuel injection relay pin 86.
