1Back to top Go down   TPS tweak  Empty TPS tweak Tue Apr 09, 2019 3:47 pm
audibob
audibob
I know this is an old subject , but a  recent tweak of my TPS gave me an unexpected bonus.
I previously had adjusted my TPS counter clockwise, so the the unit would not shut the fuel off at closed throttle, and richen
the mixture a little sooner at the other end..
I was never really happy with the closed throttle feel, so I decided to take the easy way out and cut the
black and white wire.
Low speed fuelling is definately a little smoother , with  wide open throttle acceleration remaining really strong.
I recently noticed at idle the motor was hunting a little , not a lot,  as if one cylinder was slightly  out ,  but it
was there .
Since I cut the TPS wires, the hunting has gone, and she idles at 1k steady as a rock.
There has been a slight reduction in the buzz  during 5th gear roll acceleration.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   TPS tweak  Empty Re: TPS tweak Tue Apr 09, 2019 6:35 pm
I had been running with my TPS unplugged to make it smoother at car park speeds. It made a difference, definitely smoother at low speed at the cost of occasional backfire. I reconnected it a few days ago and so far I can't feel any difference. The only difference was the loss of the occasional backfire.  TPS tweak  610153 I was thinking about doing what some Brick owners had done and fit a switch into black and white wire. However seeing as it seems to be running smooth at low speed maneuvering I think I'll run it as it is for a while and see what happens.
