1Back to top Go down   Idle & Sounds Empty Idle & Sounds Thu May 24, 2018 7:25 am
George_Pap
George_Pap
Hi all.
After the recent problem i had with the clogged fuel tank vent pipe bike now is back on the road. Put about 150km on it and in general it seems ok.
The only problem i face, since i m totally noob in K bikes is its idle behaviour.
Bike needs more than 5 minutes with the choke on and on the very start actually needs the second scale of the choke lever. For 3-4 minutes. After that period engine needs another 4-5 minutes on the first choke scale and  stabilises its rpm to 1000-1100 a noise is heard from the engine - crankcase (?)
Since a video will give you the picture i would like your experience on this.
Thank you.
K100RT (Early 1985 -nonABS)
2Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 7:28 am
George_Pap
George_Pap
at 00:41 you can hear exactly the  sound that worries me. It goes away after 10 minutes warm up.
After that 10 minutes of the engine working idle sets to steady 1100 rpm and that noise is barely audible.
3Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 7:46 am
Diesel knock! Very Happy I think we've all had that at some point - search the forum for lots of possible answers. The most likely causes are:
1. Dirty injectors
2. Air leak on the inlet stubs
3. Unbalanced throttle bodies.
If the RPM stabilises at 1100, I'd be inclined towards the air leak theory initially because idle RPM is 960-980 according to BMW. It's not something that will do any damage as it's (only) a misfire.
4Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 7:56 am
George_Pap
George_Pap
Dai wrote:Diesel knock! Very Happy I think we've all had that at some point - search the forum for lots of possible answers. The most likely causes are:
1. Dirty injectors
Hey Dai!
I've read almost everything Smile But reading finally made me terrify! Monkey nuts, Crankshaft pivots, Cam chain, Tensioners, even thermostat problems.
God, i m more confused than ever !
Thats why i've posted the sound, hopping somebody to respond " Yes!!! Its the X thing, had the same sound! "
Which places are prone to air leak so to search?By inlet stubs, you mean the four rubber hoses that go into the throttle bodies? Have in mind that this sound became worse after patching the leaking crankcase breather hose !
5Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 9:04 am
The four inlet stubs under the throttle bodies that bolt to the crankcase. Spray some WD40 (or similar) around them when the engine is running. If the RPM suddenly goes up and the knocking stops, you've found the air leak.
6Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 10:28 am
FYI: WD-40 is no longer as flammable as it used to be.  It still says flammable on the can but apparently the safety Nazis got to them so it is no longer as fun as it used to be. (Made great blow torches with dad's when I was a kid.)
7Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 10:33 am
George_Pap
George_Pap
Dai wrote:The four inlet stubs under the throttle bodies that bolt to the crankcase. Spray some WD40 (or similar) around them when the engine is running. If the RPM suddenly goes up and the knocking stops, you've found the air leak.
will blow some butane gas with my flame torch ( Dremmel ). Guess will do. Smile
8Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 10:33 am
George_Pap
George_Pap
duck wrote:FYI: WD-40 is no longer as flammable as it used to be.  It still says flammable on the can but apparently the safety Nazis got to them so it is no longer as fun as it used to be. (Made great blow torches with dad's when I was a kid.)
thank you! i second that!
9Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 11:33 am
What's the condition of the S-shaped hose which you can see near the throttle position sensor, which goes from engine to bottom corner of the airbox? In the brief flash of it in your video it looked like it had been taped up. Any cracks causing leaks will make the idle sound like a box of rocks. One quick way to eliminate the engine breather or vent hose as a source of poor idle/performance is to unscrew the engine oil filler cap on the right hand side whilst idling and note the significant idle drop. If the idle does drop further the hose is likely not a cause.
I use a propane torch with a very, very small stream of gas (not lit, of course), to determine air leaks at the throttle body rubber mounts.
10Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 11:57 am
George_Pap
George_Pap
Two Wheels Better wrote: If the idle does drop further the hose is likely not a cause.
Thank you. I have already checked that S hose. It's the crankcase breather hose as described in clymers . Found out It was cracked at the end that goes into the air box and as you correctly noticed I patched it with a fair amount of soft electrical tape till I receive the original .
Do you think that it might still be leaking? I mean is the pressure too high there?
11Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 12:02 pm
It's a chance. Pop off the oil filler cap and you'll know.
12Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu May 24, 2018 12:07 pm
George_Pap
George_Pap
Read that in a post and did that test already .Engine stalls and almost goes out.
13Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu Oct 22, 2020 1:06 pm
stanthomas
stanthomas
Two Wheels Better wrote:... poor idle/performance is to unscrew the engine oil filler cap on the right hand side whilst idling and note the significant idle drop. If the idle does drop further the hose is likely not a cause.
Can I ask, does this apply to K100 16V? On mine, removing the oil filler cap makes no difference at all to idle speed (or anything else). If everything is as it should be, what would you observe when the filler cap is removed?
14Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Thu Oct 22, 2020 4:40 pm
If nothing changes then you need to look at the crank case breather pipe and vacuum pipes. It means some or all of them are goosed. This is a very cheap repair but slightly fiddly.
15Back to top Go down   Idle & Sounds Empty Re: Idle & Sounds Wed Nov 25, 2020 7:47 pm
stanthomas
stanthomas
The crankcase breather being the Z-pipe that everyone talks about?
Mine looks fine but I have a question about a motronic 16V. How does a leak in the crankcase breather affect the air flow? The breather vents into the airbox, downstream of the filter but upstream of the throttle bodies. Since there's no air flow sensor and the airbox is, in effect, open to the air, how can an air leak here affect the idle?
