1Back to top Go down   How whirr-ey is your gearbox  Empty How whirr-ey is your gearbox Fri Oct 02, 2020 7:25 pm
stanthomas
stanthomas
On my '91 K100RS 16V, 85k miles:
At idle, in neutral with clutch engaged, i.e. gearbox is spinning, there really seems to be a lot going on in that box. Just mechanical whirr, no knocks, rattles or rumbles. And nothing noticeable on the move. Now it's a long time since I had a bike that was this quiet, well silenced, no top-end clatter, no induction roar. But I can't remember the gearbox being as noticeable on, say, a CBR600. Goes away when clutch is pulled in so definitely down to those shafts a-spinning.
I'll add that it's had a new clutch, new seals, everything tight, splines greased etc. And yes, the gearbox has oil in it. There was a bit of water in the gear oil when I got it, and it had been standing for 4 years before that, but I've seen a lot worse. On the bench, rotating the input shaft by hand, you could definitely hear the gears turning but again, not really any different to other boxes.
So I'm just trying to gauge what I'm hearing. I am mindful of all those straight-cut gears spinning away on three shafts and it wouldn't suprise me if "they all sound like that". But confirmation would be appreciated.
2Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Fri Oct 02, 2020 8:22 pm
I've never heard a quiet one yet. Two skeletons having it off in a tin bucket comes to mind.
3Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Fri Oct 02, 2020 8:24 pm
What Rick says. Straight-cut gears are noisy by definition.
4Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Sat Oct 03, 2020 2:19 am
It might be time to unpack the otoscope. Laughing
5Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Sat Oct 03, 2020 8:25 am
Snod Blatter
Snod Blatter
I've actually been meaning to make a post about this! Mine didn't used to whine but since it passes the 80K mile mark there's a noticeable whine in all gears.. Normal or time for an oil change?
6Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Sun Oct 04, 2020 1:08 am
jjefferies
jjefferies
THought the K-bike whine was patented by BMW. All of mine have. K100, 2 K75's.
7Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Sun Oct 04, 2020 9:29 am
stanthomas
stanthomas
First time I encountered a K was in the mid-80s as it pulled away from Creg ny Baa during the TT. And I was stuck by the elecric motor-like whine, very different and noticeable because otherwise is was so quiet. Maybe airhead BMWs and bevel twin Ducatis would sound the same if the general row was removed.
Can't say I notice that gear whine on my 16V when driving along. Think I'll have to go somewhere where Ks gather and compare. But I haven't seen a K out and about for years. Mind you, I've only seen three running airheads in the past 2 years. There used to be a BWM owners meet at the TT, is that still going?
8Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Mon Oct 05, 2020 12:50 pm
moriarti
moriarti
lots of us Ks still around, problem is you don't see or hear us coming(stealth mode) just that Ksound when we are gone. Some of us get to Horse Shoe Pass now and again.Coffee and chat should you spot us  Chatter
Don't know about BMW TTClub/meeting. santa
9Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Mon Oct 05, 2020 1:29 pm
stanthomas
stanthomas
moriarti wrote:lots of us Ks still around, problem is you don't see or hear us coming(stealth mode) just that Ksound when we are gone. Some of us get to Horse Shoe Pass now and again...
Horseshoe Pass is a regular route for me, although mainly under pedal-power. Always seemed to be Repsol Fireblades and 1200GSes but now I know, I'll keep a look out. Maybe I'll see you there. Thanks
Not that anyone can go there at the moment of course.
10Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Tue Oct 06, 2020 7:19 am
No... and next year's Dragon Rally is cancelled... Sad Sad Sad
11Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Tue Oct 06, 2020 10:35 am
moriarti
moriarti
Couple of things not cancelled BILLS RAIN and hopefully BREATHING.Just got back from a ride,like a drowned rat.Ha Ho Happy Days Laughing Laughing
12Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Mon Oct 12, 2020 10:27 am
I put  a tea spoon of Molydenum disulphide powder in the final drive and gearbox on my K100LT. (Prescribed and dispensed by Dr. BobT) it made a bit of difference to the noise and smoothness of both.
Worth doing if you can get it in a small quantity.
How whirr-ey is your gearbox  Ir-log1188....May contain nuts!How whirr-ey is your gearbox  Ir-log11
K75RTP - 1994
13Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Mon Oct 12, 2020 11:04 am
88 wrote:I put  a tea spoon of Molydenum disulphide powder in the final drive and gearbox on my K100LT.
John Muir, author of HTKYVWA–AMFTCI, prescribed that for VW transmissions in 1969. I was one of his votaries. The transmission always performed flawlessly when I pushed the bus out of traffic to the curbside because it stalled.Laughing
14Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Mon Oct 12, 2020 5:11 pm
I had that book as well. One thing he never covered was how to keep the clutch cable on the split windshield bus from freezing in the tube in the winter time. Several were the times I had to drive home without a clutch in the dead of winter.
15Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Tue Oct 13, 2020 6:50 am
No idea but I did get the longest distance award.  1990, I think.
16Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Thu Oct 29, 2020 3:11 pm
stanthomas
stanthomas
Little did I imagine that the event in question might be the TT itself:
Manx Radio 4 October
... strange times.
Getting back to the point, I've changed the gearbox oil and it's much quieter. What came out looked more like a 5 year oil change, not 1 month and 200 miles. I had flushed the gearbox with 10/40 while it was on the bench to try to clean out water and residue from it's 4 year 'rest'. Perhaps some of the 10/40 was left in the box and thinned my first fill.
Anyway, the box sounds much more normal now and not something I'll worry about. Another oil change planned after 500 miles to flush out more of that residue then fill with synthetic.
Thanks for your comments.
17Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Thu Oct 29, 2020 6:24 pm
Snod Blatter
Snod Blatter
stanthomas wrote:I've changed the gearbox oil and it's much quieter.
Now this is interesting, probably time for me to do the same then!
18Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Thu Oct 29, 2020 9:53 pm
Aged speed freak
Aged speed freak
Do not use synthetic oil for final drive or gearbox use ep80/90 it will be more than good enough
19Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Fri Oct 30, 2020 6:26 am
moriarti
moriarti
#18.Where angels fear to tread :sunny1:For  the past 20 odd yrs iv used standard gear oil with a dash(300ml) of Moli slip additive,Resulting in a quiet silky positive gear change It works for me. Very Happy Very Happy
20Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Sun Nov 15, 2020 8:08 pm
cycleman
cycleman
From what I understand about these old K bikes is that the bulk of the whine comes from the alternator. I wouldn't think you would hear much whine from the tranny or rear end if they where in good shape.
21Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 7:35 am
Snod Blatter
Snod Blatter
To come back to this, I finally changed the oil in the gearbox and the whine is reduced although not completely gone. The magnetic drain plug had a bit of an afro but not too bad for having done 10K miles so I'm not worried about it, it may just be that they start to whine a bit after 80K.
cycleman - this is definitely gear whine from the box, some gears are louder than others.
22Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 10:24 am
stanthomas wrote:First time I encountered a K was in the mid-80s as it pulled away from Creg ny Baa during the TT. And I was stuck by the elecric motor-like whine, very different and noticeable because otherwise is was so quiet. Maybe airhead BMWs and bevel twin Ducatis would sound the same if the general row was removed.
3 of them beside my back door....out and about all the time!! I think they have all passed your house too.
23Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 12:13 pm
stanthomas
stanthomas
Doubt you've been past my house, it's a bridleway more suited to GSes; not that I've seen one of those go past either, just knackered old DT175s. Did see my first  brick for many a year about a week ago, a K100RS 8V at the A49 lights just outside Northwich.
To go back to the box, it's like a very loud ssshhhhh sound. Sometimes I confuse it for the cooling fan - until the fan kicks in for real. Sounds like a lot of shafts and gears tunring away in there. Very noticeable when I pull up outside the metal door to my garage, less so in the open.
24Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 12:24 pm
stanthomas wrote:Very noticeable when I pull up outside the metal door to my garage . . .
It was whirrey but now it's ssshhhhhey. Is it ssshhhhhey when it's idling in front of your garage door?
25Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 12:56 pm
stanthomas
stanthomas
The sound is the same, just trying to find the words to distinguish it. I'm familiar with the whine from straight-cut gears and it's not that. And yes, when idling after the engine is up to temperature - don't hear anything above the wind, induction and exhaust on the move. I assume the garage door is reflecting the sound back at me making it much more noticeable but it's there even at the back of Tesco's car park. And this with my helmet on. I don't have to crouch down by the side of the bike for it to be evident.
It is more apparent than other bikes, even water-cooled Hondas, and I wonder whether this is normal for the breed and it's simply more noticeable because the rest of the engine is quiet or whether it suggest something not right after 4 years of lay-up with some water in the gear oil. But I guess I'll just ride it and hope it doesn't get any worse; for now, the bike's got some serious handling problems to sort out
26Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 1:07 pm
You might be hearing an alternator bearing. Put your long-shanked screwdriver on it and listen through its handle.
27Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 1:22 pm
Noise related to engine speed.......possibly alternator or input side of gear box or engine output or engine components like oil/water pump. Test on this one, pull clutch, hit rear brake and noise remains.
Noise related to wheel speed.....output side of gear box or final drive. Test on this one is pull clutch, hit rear brake and see if noise stops.
28Back to top Go down   How whirr-ey is your gearbox  Empty Re: How whirr-ey is your gearbox Wed Nov 25, 2020 7:37 pm
stanthomas
stanthomas
Definitely gearbox - pull in clutch, noise stops, let out clutch it's back.
I've not studied the box but I think in neutral both input shaft and intermediate shaft will be spinning together with all gears. I should run it up on the centre stand to check whether there is any difference when in gear.
Now it's not a bad noise, just noticeable and, to my mind, out of character with the rest of the bike.
