Number of posts : 7967
The whole fan issue is one in cooler climates. Hot climate its run on virtually every outing, even slow moving traffic in 35c so it gets regular use and plenty of it. Been there.
But back here in more temperate climates a K can go for weeks without the fan running, even going to town. I am using a different base in town now that involves a different route and the fan comes on at the exact same location, whether on the K100RT or the K1100LT. Previous location it never came on. Other than that the fan sees very little use.......which causes them to seize.
So for here a switch is definitely good. My K100LT had the manual over ride. It worked. My K10RT didn't have the over ride......result fan seized through lack of use. Replaced it when I did the clutch/rear main seal. The K1100LT will get a manual override too.
The Ducati does have a switch for the over heating rear header. A Kill switch. But it should never be used.
1971 Yamaha 125 YAS-1
