1 non starting prob Sun Jun 20, 2010 4:18 pm
Rob Roy Mcgregor
Hi again just had a go at getting my bike started (84>85 100 rs), its been dry stored for a couple of years and the last owner said it had a new fuel pump fitted before it was laid up
here are a few things about it
1.new battery fully charged (turns over no problem)
2.plugs spark and are new (bone dry when taken out)
3.wires connected to the tank
4.relays under the seat click when ignition switch is turned
5.tank drained and filled with new fuel
6.no signs of broken or disconected wires
Is the fuel pump meant to make a noise if so what should i hear, if there is no noise does this mean the fuel pump is broke or can i check it by putting a meter on some of the wires
Any help or advise on this will be greatly appreciated as i know your all busy people polishing and riding your own iron horses
