1Back to top Go down   When should this bulb be on? Empty When should this bulb be on? Sat May 06, 2017 7:40 pm
Bucky
Bucky
When should this bulb be on? B0002051
When should this bulb be on? OKq48yK
Anything worth doing is worth overdoing! (B-52 Crewdog Phil Smith)
1985 K100RT
2Back to top Go down   When should this bulb be on? Empty Re: When should this bulb be on? Sat May 06, 2017 7:41 pm
Bucky
Bucky
I should have stated, I'm speaking about #13 in the print.
1985 K100RT
3Back to top Go down   When should this bulb be on? Empty Re: When should this bulb be on? Sat May 06, 2017 8:45 pm
On my '94 K75RT it comes on when the ignition switch is in the park and run positions.
On my '92 RS it comes on when the ignition is turned on.
4Back to top Go down   When should this bulb be on? Empty Re: When should this bulb be on? Sat May 06, 2017 8:45 pm
When the key is in the first position and if you have the headlight switch on the right switch block then when that switch is in the middle position.
5Back to top Go down   When should this bulb be on? Empty Re: When should this bulb be on? Sun May 07, 2017 4:21 am
BobT
BobT
It is a parking light so can be on when the ignition is off too.
6Back to top Go down   When should this bulb be on? Empty Re: When should this bulb be on? Sun May 07, 2017 6:48 am
Basic2
Basic2
On my 11/87 K100CJ the parking light is on when the ignition key is at the "park" position. The key can be removed in that position so the bike can be left locked with the parking light on.
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
7Back to top Go down   When should this bulb be on? Empty Re: When should this bulb be on? Sun May 07, 2017 9:19 am
Bucky
Bucky
Thanks, I have determined that my bulb is bad, I'll throw a new replacement bulb in and check it.
1985 K100RT
