1Back to top Go down   Which Headlamp Bulb? Empty Which Headlamp Bulb? Tue May 05, 2020 3:15 pm
Bonzo
Bonzo
I've carried a spare around in the tail section for years and it came in handy today as my bulb blew.
I'm gonna stick with halogen, but there so many on the market these days.
Which do you recommend?
2Back to top Go down   Which Headlamp Bulb? Empty Re: Which Headlamp Bulb? Tue May 05, 2020 5:21 pm
moriarti
moriarti
Hi Bonzo,in the dark depths of Yorkshire BOSH /OSRAM works for me with a twin
headlight setup,any BRIGHT ideas anyone idea2 Chatter
3Back to top Go down   Which Headlamp Bulb? Empty Re: Which Headlamp Bulb? Tue May 05, 2020 5:38 pm
I use the Osram/Sylvania bulbs from the local auto parts shop.  I stick with the stock wattage since the high output 100W bulb that came with the bike melted the connector and welded it to the bulb.  Boy, was that fun!  If you do go high output change the connector to ceramic.
LED and HID bulbs aren't compatible with the optics of the old K bike headlights yet.  They generate a lot of scatter that annoys oncoming drivers at night as well as putting a lot of light away from where you want it.  They're getting better, but still not perfect.
4Back to top Go down   Which Headlamp Bulb? Empty Re: Which Headlamp Bulb? Tue May 05, 2020 5:40 pm
Osram Nightbreakers FTW!!! Phillips Xtreme if you can't get the Nightbreakers.
5Back to top Go down   Which Headlamp Bulb? Empty Re: Which Headlamp Bulb? Tue May 05, 2020 6:11 pm
volador
volador
PIAA Xtreme White Plus 4000K
6Back to top Go down   Which Headlamp Bulb? Empty Re: Which Headlamp Bulb? Tue May 05, 2020 6:46 pm
Best thing you can do for your headlights is to add relays. I wired from the OEM headlight socket to the relays and from the relays to a new ceramic socket. I've just upgraded to a 100W high beam a couple of day's ago when my 20 year old globe blew low beam.
7Back to top Go down   Which Headlamp Bulb? Empty Re: Which Headlamp Bulb? Tue May 05, 2020 7:00 pm
volador
volador
