1 Battery charging light - absolutely necessary? Wed Oct 22, 2014 10:22 am
Everything that I've found on this forum says 'yes' and it's certainly an absolute requirement for the charging on my Guzzis but... I've been riding around for the last month or so without a battery charging light and the battery has been charging quite happily.
Now... that's not quite the full story. I have a K100LT 50amp alternator on the RS and further, I converted the 50amp alternator to 60amp output by using the guts from a K1200(??) lichtmaschinen. So, I guess the real question is; did BMW change the charging regulator on later bikes, even though the visual appearance is the same? You can see the voltmeter is registering a charge after revving the engine to about 2300rpm.
