1Back to top Go down   Charging K100 battery Empty Charging K100 battery Mon 20 May 2019, 12:00
moenv
moenv
Does anyone know if the K100LT battery can be charged through the cigarette lighter socket or the auxiliary plug socket on the upper dash?
2Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Mon 20 May 2019, 12:20
Chocolate
Chocolate
Yes, you can and I’m doing that too.
You shoud NOT try to jumpstart through this plug.
The cables are NOT made for this!
3Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Mon 20 May 2019, 15:17
Yes you can.
Charging K100 battery Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
4Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Mon 20 May 2019, 15:40
Here's an inexpensive way to get the plug.  Buy one of these. You can unscrew the cover on the plug part and then wire it up to the battery charger:
https://www.aliexpress.com/item/DC12V-24V-EU-Plug-For-BMW-Hella-Motorcycle-Charger-Car-Cigarette-Lighter-Adapter/33012049614.html
5Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Mon 20 May 2019, 17:32
moenv
moenv
Thanks for the info
6Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Wed 22 May 2019, 08:47
Bumblebee
Bumblebee
moenv wrote:Does anyone know if the K100LT battery can be charged through the cigarette lighter socket or the auxiliary plug socket on the upper dash?
Yes you can.  BMW sells a charger, Part number 71 60 7 688 865 charger that is intended to do this.  You plug it into the mains and plug the jack into the socket, and done.  The K-100 has no "smarts" controlling the jack so if you get the plug just about any charger will work, but this charger will communicate with the CAN bus controller on later machines, like my R-1200 RT and R-1200GS.
This link will take you to the plug:
https://www.advdesigns.com/stgepopl.html?gclid=CjwKCAjw5pPnBRBJEiwAULZKvslZkMcQcMYJKE7yxT-uzvqdzKtQ1gfPYgZP800kWRme8cMwqF6PMxoCNvwQAvD_BwE
BB
http://Bugsmashers.org/phpbb
7Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Wed 22 May 2019, 09:37
No need to get a BMW charger and our old Ks are not CANbus.
Electrons don't care about brand names.
Battery Tender Junior is a great product.  I have several of them.
8Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Wed 22 May 2019, 11:28
moenv
moenv
The only reservation I have with the Battery Tender Junior (new version will do lithium too) or other plug and leave chargers is the potential for overcharging if the microprocessor fails to go from charger to maintainer when a battery is left for months on the BTJ.
9Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Wed 22 May 2019, 11:33
I've been using BTJs for well over a decade and never had any issues with them. (Except for the one that I left out in the rain that got really soaked but I consider that one to be my fault. DOH!)
The circuitry in them is seems to be very good.  DAMHIK but they even detect and avoid issues if you accidentally reverse the polarity. Embarassed
10Back to top Go down   Charging K100 battery Empty Re: Charging K100 battery Tue 28 May 2019, 07:33
td5
td5
Any decent charger will do, you just need to wire up the plug.
Charging K100 battery K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
