Number of posts : 7967
We are saying same thing on the headlights, as in if you do fit higher wattage headlight bulb don't even consider doing it without the relay and associated wiring.
The ceramic bulb H4 holders I got came with higher rated wiring attached for connection to the relay so the original bike wiring is reduced from powering the headlight to simply controlling/switching the relay, much less load on the switch. Due to age fitting the relay will inevitably bring some improvement in light quality. None of the original bike wiring should be used for high wattage headlight bulb power. That will be new wiring from the battery to the relay, with the new ceramic bulb holder having the wiring from the relay to the bulb holder and bulb terminals.
I use the K all year and live on rural roads like BobT's, in winter being further north our days are much shorter and the headlight improvement is badly needed.
Sound advice on the charging light, as in don't change it.
And....the indicators bulbs are not a straight swap. So what is the flasher modification?
As for buying LED bulbs, they all seem to come from China.....
Just like all Christmas puddings come from the land of Eccentrics.....
1971 Yamaha 125 YAS-1
