1 Flashing bulb monitor dash light. 91 K75s Sun Nov 22, 2020 6:45 pm
A new to OZ Kiwi brick and owner has been trying to get his bike registered. The bike has obtained a mod sticker but now needs a roadworthy. I've talked the owner through most of the problems except for one. I have yet to see the bike but a few of us will be descending on him on Wednesday. The bike had two problems one was the ABS light on permanently, this was temporally fixed by removing the ABS relay. When time permits we'll look further into either fixing it or removing the ABS, owners choice. The next problem is puzzling, the bulb monitor light is flashing when the ignition turned on and continues to flash when started. He has checked that all the globes are functioning and applying the brakes does not stop the flashing. I have never seen a brick with a flashing bulb monitor light. I've traced the wiring diagram and I can't see a reason for it to flash. We will be taking a full set of relays and test lights multimeters and jumper wires to hopefully sort out the problem. The problem has only occurred since the bike landed in OZ. Any ideas appreciated. In the mean time I'll puzzle over the diagram.
