1Back to top Go down   Flashing ABS Light Empty Flashing ABS Light Mon Jul 29, 2013 1:55 am
larrikin
larrikin
My ABS lifgr and brake are flashing. Normaly I just turn the bike off then restart it and it stops flashing. But now it doesn't.
Any ideas on what is causing it?
Flashing ABS Light Au-log11Flashing ABS Light Au-log11
88 BMW K100RS
It increases my paranoia
Like lookin' at my mirror and seein' a police car
2Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Mon Jul 29, 2013 2:05 am
No but try a reset. Go here for all the info you need. http://bmwk10075abs1fix.web.fc2.com/
Tosi is the master of K bike ABS
3Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Mon Jul 29, 2013 3:36 am
larrikin
larrikin
Thanks, I think I know what the problem is now.
88 BMW K100RS
4Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Wed Aug 07, 2013 7:04 pm
larrikin
larrikin
I finally found out why the lights were flashing. It was a bad earth. It took Mick Dyer 2 hours to find it. The Tester kept saying it was a failed relay, front and rear modules, front and rear senses and a failed computer module.
88 BMW K100RS
5Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Sat Jul 12, 2014 2:54 pm
Tenox
Tenox
I would like to know excactly where is that plug which is needed to reset the ABS.
BMW K100RT Scrambler (86)
6Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Sat Jul 12, 2014 5:02 pm
You should normally find this connector zip-tied or taped at the upper RHS
frame tube under the seat.
7Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Sat Jul 12, 2014 8:34 pm
It will be a 3 pin plug with only one wire to it and that is to the centre pin.  Usually tied to the frame tube but sometimes left dangling behind the right side cover.
8Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Sun Jul 13, 2014 11:14 am
Here you can see what to look for, as Rick allready have mentioned the middle
connector (brown/white wire) is for the ABS.
Flashing ABS Light Kontak11
9Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Tue Jul 15, 2014 3:14 am
Tenox
Tenox
Thanks guys! If something there is information and knowledge in this forum.
My bike has a bit poor battery (will change it during wintertime) and I keep the bike on charger (intelligent one) when not driving. Still twice the abs light has not stopped blinking. I have not have to reset it yet, but I think that that day will come. So I would like to be prepared!
10Back to top Go down   Flashing ABS Light Empty Re: Flashing ABS Light Wed Aug 20, 2014 9:43 pm
Noopernipe
Noopernipe
I had the same issue on my 2001 R1150gs, went through all the earthing issues, and then the ABS pump failed about a 1000km later. Expensive repair  Evil or Very Mad
